Chevrolet Malibu TSBs/Recalls/Problem Codes
I remember seeing a bulletin number some time ago on either this or the Malibu Maxx thread here. I don't remember that specific number at the moment.
Perhaps Chevrolet's "answer" is premature? Perhaps the "new" part they thought would work failed in extended testing?
I do not know.
Then again, Toyota is now recalling a million Priuses world wide with defective steering columm components. We are not alone :sick:
I do not know.
I took my '04 Maxx in this morning for an oil change and tire rotation and mentioned this "rough road clunk" that I've had for a while. (The folks in Edmund's still haven't hit on the answer, but I have it). (e2helper, feel free to enlighten them).
Turns out that there's a Preliminary Bulletin #PIC3747 dated 10/24/05 that addresses this issue. Per the Bulletin, "the root cause has been determined and corrective action is in the validation process". Which means that the fix isn't ready yet. "Service parts are expected in the first quarter of 2006".
The Bulletin specifically advises against replacing either the intermediate shaft or rack&pinion, or reloading the steering system, because the system will reset and the rattle/clunk will return (folks in Edmund's swear that these recent fixes work. They're in for a letdown).
This issue most often appears between the 3,000 to 5,000 mile mark. And never goes away. Appears to come from the left front suspension.
That's all I know for now.
Issue also affects '05-'06 G6s.
Another post on the forum said fix is delayed to third quarter '06. But at least I have something to wave in the face of my dealer!
At the top of the page is a Document ID# 1819760. Subject is labeled:
Subject: Knock, Clunk or Rattle Noise at Low Speeds with Suspension Input - keywords intermittent shaft steer steering #PIC3747B - (04/21/2006)
Models: 2004-2006 Chevrolet Malibu/Maxx 2005-2006 Pontiac G6
#05-08-44-017 Radio Static Noise on AM Stations when Using Rear Defogger (Install Capacitor)- Sedan only
Anyone know the procedure and the codes, and the procedure for clearing the codes.
My check engine light came on today. I need to check it out and clear it
I have a question though. Do you a problem with the blinker light bulbs going out on a frequent basis? My husband has to replace at least one every 3-4 months. I have never had lights go out on a car that frequently.
The info that I got about having 3 recalls was or had been provided by "Edmunds".
