Buick LeSabre Electrical/Lighting
124
  • jcb6jcb6 Member Posts: 3
    i have a 94' lesabre and i cant get the lights to turn off sometimes.When i push the switch in and out they will usually turn off this time not so much.I opened the pass. door to get manual(which i dont have) and the lights went off.any ideas
  • imidazol97imidazol97 Member Posts: 27,802
    Which lights?
    the headlights.when i push the headlight button in and out the dash lights and light indiactors all come on correctly but the headlights wont turn off.like i said i opened the pass. door last time and they went off,kinda wierd i know but i've seen your sceen name on here and sounds like you know your stuff any ideas please
    Does your car have twilight sentinel where you can adjust how long the headlights stay on after the key is off and the door opened?
    Does it have automatic on and off headlights that us a light sensor on the dash that "sees" the light of the sky to determine when to turn the headlights on and off.
    It's very easy to get the light switch and the twilight sentinel controls confused in their operation with each other.
    Also does your car have the battery saver feature where if you leave the headlights or any others on, they are turned off after 10 minutes or so?
    I'd have to dig out my 93 manual and see which features were available then. The battery saver may have been on Limited models with certain option packages.
    I know that the twilight sentinel switch on my 98 holds the lights on and if I turn the headlight switch on, I'll get confused as to how to get them off.
    it has no twilight or automatic lights.they dont come on till you turn them on and you have to shut them off to turn off,im not sure if they turn off after 10 min and i am scared to turn them on if i dont have to.haven't had to since i got them off and made this post hope this helps you help me thanks again.if it does have the lights that turn off after certain time what controls that,is it a relay or something i can just unplug,guess i should find out if it has auto shut off before i ask those questions shouldn't i but i do appreciate your help
  • rbakkerrbakker Member Posts: 2
    My 1992 Buick LeSabre has an issue with the headlights. The brights work just fine, but the regular headlamps do not go on at night. I have running lights during the day, but when it gets dark, no lights. What would cause that and how do I fix it? I've already gotten a traffic ticket for driving with my brights on! Any help is very much appreciated.
    You can check for voltage at the light bulb socket to a ground (not the other wire in the socket) when on low beam.
    OR you can check the switch for high/low beams. which I think is on the bottom of the steering column connected to the turn signal arm at the top by a wire link that moves the switch.
    I have a 93 book but I can't check on it now. If you know how to use a meter, you can check that switch. When you pull on the turn signal level do you hear and feel a switch clicking like it's switching between connections for high beams and low beams?
    It does make a click when you switch between high and low beams. Also, the twilight sentinal stays on for a pretty long time, even when set on low. Would that have anything to do with it?
    I still think you need to check the bright/dim switch. The twilight sentinel should work the same on both.
  • stephen987stephen987 Member Posts: 1,994
    my money is on the main headlight switch itself, not the high/low beam switch
  • niceride3niceride3 Member Posts: 17
    Hello I am new to Edmunds and a new owner to a great vehicle. We love our 2003 LeSabre. What a nice ride and reasonably economical for a large car...better than my Honda Element!!
    A little disappointment, though after driving at night
    My problem is there are a lot of lights out in the radio buttons.
    All of the lights are out in the Automatic Heat/Cool panel. I have read in a "Fix-Ya" and others that these are typical problems that keep re-ocurring, what gives? Poor design? I have a '97 Regal and all the dash lights work!
    I am a technical person. I am willing to learn how to remove these units and find out how to replace the bulb(?) or are they LED's? Or is it something utterly impossible for any human to fix?
    Any help would be really nice.
    BTW I Googled my problem and Google directed me here and I could not find the thread addressing this Dash light, HVAC panel/Radio problem.
    fred
  • nctarheel704nctarheel704 Member Posts: 1
    I just bought a 93 LeSaber. The alternator was bad and the battery was dead. I replaced both with new(not rebuilt) parts. The light next to the battery gauge will not shut off. I have drove it for a while and the voltage gauge stays centered on 13 volts. Can someone help me please? I am also having an issue with the left turn signal. The light for it on the dash stays on, when you turn it on it just stays on and doesn't blink.
  • pligmanpligman Member Posts: 1
    This site and Buick will be hearing of this problem a lot more as the years move on. I have a 2004 LeSabre and most of the steering wheel lights are now out as well as some in the Climate Control and Radio. Others tell me of the same problem. The lights are accessible in the wheel but not easily. A paint can lid lifter works well to pry the assemble up but actually replacing the bulbs is extremely touchy. I removed the Temp/Vol assembly and opened it to get to the bulbs. The bulbs are miniature something or other, soldered to tiny pads on the circuit board. I have scanned pictures of the parts that I will be happy to email if anybody is interested. The next exercise would be to find replacement bulbs and blue sleeves. Don't know, but suspect, GM would stock only the complete assembly for repair.
  • soonerdewsoonerdew Member Posts: 26
    I have an '04 Lesabre with precisely the same problem. I think it is less an issue specifically tied to the lights, but to the kind of abuse the switches absorb in the course of regular use, which gets transferred to the mechanical device/light/contact that sits behind the button.
    As a case in point, my cruise control stopped working about two years ago, and when I finally got sick of not having it, I took a small screwdriver and wedged up the steering wheel button for the cruise control. When it popped off, I noticed that the cruise contact microswitch was broken into three tiny pieces. There was enough cord to allow me to pull out the switch, and disconnect it. I ordered a replacement switch from a local GM dealer (seems like it was about $12 or so) and popped it back in...voila, my cruise was fixed.
    The bottom line is that the switches and lamps behind the button faces were not designed to absorb the constant finger/thumb pounding they apparently receive, and those components simply fail under the abuse. Very poor design, and it makes an otherwise very pleasant car look rather slipshod when the lights start failing.
    Then we wonder why American manufacturers are in trouble. I work in electronics and find it hard to believe that all of these indicators are hard to replace. I need info on how to remove the HVAC controls and possibly the radio out of the dash. There are numerous lights out. If whatever secret is to remove these units from the dash could be shared here, I would be able to figure out what components need to be replaced and the individual indicators can be replaced.
    Of course GM will only sell assemblies and not the bulbs or L.E.D.'s It keeps Delphi going. But let's try to break the un-repairable curse on these lights.
    If someone would respond, I would appreciate.
    If CHILTON's is the answer on "how to remove these assmblies, THEN I WILL buy a Chilton's and disect the HVAC and radio lights and find out availability. MOUSER or DIGIKEY have almost anythng imaginable for lamps/indicators.
    Fred
    BTW if some brave soul has already broken the "code" :surprise: how to remove the HVAC controls or radio, or has the assembly in hand for the steering wheel indicators, pls take a real good detailed pics of these mysterious lamps the pic to email me, and I'll see what I can come up with. My email in long hand is ?????flintstone7415 at yahoo dot com??????????? If you really trust me....after we pass some emails back and forth, send the assemblies to me and I'll try to trace some id numbers or compare the lamps to what is available from major electronic suppliers. Thanks
    Fred
    Sorry for many posts BUT a forum called TOPIX seems to have more responses to these light problems than Edmonds. For folks who are handy with a soldering iron, in most cases, you can replace these lamps with a WESTINGHOUSE ## 8111 bulb from
    www.atlanticelightbulbs.com
    It's a 14 volt bulb that should last longer than the 12volt bulb that was "engineered" in the USA. Why pay $40 for a replacement switch/bulb (Steering Wheel controls) when it's only a $1.15 bulb?
    CAMOWN America wake up!!
    Fred
    Send your donations for my solution to the following PayPal address............just kidding
  • earpsterearpster Member Posts: 1
    Does anyone know if the IP or the Gauge clusters are interchangable? (one has idiot lights, one has gauges) Thanks for the help.
  • jasminerjasminer Member Posts: 1
    I posted this in the Answers section as well, so sorry for the repeat!
    I have a silver 1998 Buick LeSabre that has many, many electrical problems. The first problem started when the battery holder broke off inside my main electronic transmitter (I guess you could call it "keyless entry," since it has the lock/unlock buttons) and the spare just stopped working altogether. I replaced the battery and everything and still no luck. Couldn't lock my doors after that, but I could still drive the car. The second problem is that shortly after that, the horn starts randomly honking by itself. I could be sitting at a stoplight and the horn would suddenly go off for no reason. The only way to turn it off was to keep pushing the horn until the noise stopped. Couldn't lock the doors and could'nt beep the horn if I needed to. Kind of dangerous, but I could still drive. The third problem is that shortly after the horn problem, the alarm AND the horn start to go off simultaneously at random times as well. The only remedy to this problem was to disconnect the battery and leave it unplugged for at least an hour. Couldn't lock the doors, couldn't beep the horn, and couldn't go long distances for fear that the alarm would go off (thus enabling the anti-theft feature and preventing me from starting the car.) But I could still drive, as long as I had a wrench (or whatever it is :p) to disconnect the battery. The final problem is that now, after all of these other problems, the car will not start. I still have auxillary power (all the lights come on, the radio plays, windows roll down, etc.,) but the car won't run. Any guesses as to what may be happening? I was going to take it to the dealership to see about it, but they want $85-$100 just to look at it, let alone attempt to fix it and as a college student, I just can't afford that much for a diagnosis. Any help would be greatly appreciated! Thanks!
    Wow:
    The battery holder posts broke off in the remote. I assume that means you're using a different remote? If they broke off they probably can't be soldered back into place on the circuit board or repaired. I replaced one of mine that did something like that with an Ebay with the same code number on the back. Then they can be reset to the car by connecting posts 4 and 8 in the assembly line diagnostic connector underneath next to steering wheel and then pushing buttons. I believe the directions are in the owner's manual in the glovebox. Both remotes have to be done at the same time or it only learns one.
    >couldn't lock doors
    Are you saying the doors won't lock from the remote? Or won't lock from the buttons in the car?
    Is there an aftermarket alarm on the car? If so I'd personally take it off.
    I don't know much about the alarm system that was an option on the certain option packages--I ordered my 98 with only the load leveling struts and avoided the other options in the package because I didn't want the alarm. People have trouble with the sensor on the trunk lid in Bonnevilles and suggest disconnecting it.
    If you're talking aftermarket alarm, I don't know.
    As for the door locks not working from the inside buttons or the remote, all I think of is the problem with buss connections which get wet and salted in some areas of the country. Then they corrode. like this or this
    The pictures are ones found on the net. I did not take them.
    I posted one picture to show you it's under the carpet and the plastic door sill. There is also one on the passenger side. It's wrapped with lots of tape against the bundle of wires leading to the rear portion of the car. I had a '93 leSabre where the door locks occasionally wouldn't work and the AC would revert to default control of AC on and defrost mode because this buss was occasionally not making contact.
    Anytime funny things happen, check grounds. This buss is one. But your main battery cables are another. Check the grounds at the battery and where they connect to fenders, motor, etc. At the battery look for corrosion down into the plastic covering the battery cable. Check the double layer positive cable where there's a lead spacer between the top and bottom cables.
    Remember to turn off the AC with the key on before disconnecting the battery. I turn everything else off.
    You'll find Bonnevilles are even more popular with people doing their own trouble shooting, so you might check some Bonneville forums as well. You'll note I mentioned them.
  • budlbudl Member Posts: 1
    In taking the advice about using a Westinghouse 8111 bulb from www.atlanticlightbulbs.com, I first check with the Buick dealer. The new switch unit was 43.00. Then went to atlantic light bulbs. The bulbs were, as you said, 1.15/bulb. But there is a minimum of 10 bulbs, so it is 11.50, not 1.15. Then there is 7.50 shipping, so it is 19.00. But wait, they have a minimum order of 24.50, so it is 24.50 + 7.50, if you can find an exactly 13.00 item to make up the 24.50, so now it is at least 32.00. Might as well spend the extra 11.00 at the Buick dealer, not have to mess around soldering and have a new switch, unless someone can tell me where I can really buy 8111 bulbs for 1.15.
  • chow_chowchow_chow Member Posts: 1
    I have a 97 LeSabre that doesn't have the power trunk latch option.
    I would like to retrofit one.
    I would like to know what parts I need and what parts are already there (wiring, etc)?
    The existing latch has a wire to it but does not appear to have an actuator. I am assuming I will have to replace it, but I wonder what the existing wire is for?
  • bigbluebuickbigbluebuick Member Posts: 6
    Hello All,
    Just wondering - I have a '95 LeSabre Custom & would like to swap out the instrument cluster with that of a 96/97/98. Is this possible? I want a tach & other guages rather than just the idiot lights & speedometer.
    -J
  • swampguyswampguy Member Posts: 1
    My rear left blinker randomly quits working. It lights up when I open the door like it suppose to but does not blink at times. I have changed the bulb and it worked for awhile but then it started again. Any ideas?
    Hey Bud
    I realize there might be hestitation with min orders, but those bulbs are probably used through out the vehicle, in the dash, the radio, and the HVAC controls, and the steering wheel controls..
    When the snow starts flying here in West. Pa. the LeSabre will be parked in the warm garage for some TLC and all of the bulbs burned out in the areas mentioned.
    EDIT: I just ordered 35 bulbs from Atlantic for $43 something.
    Fred
  • 2001lesab2001lesab Member Posts: 3
    The driver door works, but suddenly the others don't (windows nor locks).
    Switches on the dead doors neither so I'm skeptical it's the door controller. Also checked the fuses (why, right? ... sheesh...)
    Is there another controller? What else?
    Thanks very much.
    By any chance have you had water in the car under the front seat area? You might check. Some Bonneville owners have had corrosion on a wire splice that joins three wires there from the other three doors to the wire from the driver's door controller. If I can find a picture, I'll show you. I think the wires are light brown or tan.
    Check fuses in the rear fuse block under the seat, but I think those controll the two rear doors. I don't know that the right passenger door is through that area.
    Thanks for your help... no water (I don't think) under the front seat and did check the fuses (there's one for door, one for windows).
  • maras016maras016 Member Posts: 1
    We have a 91 buick lesabre with 63k miles on it the fuel pump runs constantly even though we put a new fuel pump and a new fuel filter on. Our thoughts are that it is a fuel pressure regulator. We don't know if it has one or where it would be. Any ideas anyone?
  • grizzly85grizzly85 Member Posts: 1
    imidazol97 i have the same year car and the same problem with window and door lock and everything else not working i checked fuses and grounds and went to junkyard and got pdml for passenger side but they might not be good, i will try tightening th bolts on the fuse panel what was the fix to this
  • gomfrddy1gomfrddy1 Member Posts: 1
    I have a 01 lesabre, my speedometer stopped working, replaced the vehicle speed, sensor, the cluster and still nothing, any ideas????????
  • goji54goji54 Member Posts: 1
    edited April 2010
    So here is the problem. The front passenger side door seems to have no power. The interior lights don't come on when the door is open, the power lock doesn't work, and the window doesn't work either. The only thing that seems to is the speaker up near the window. I checked the fuse that was associated with the door and it looked fine so now I'm stumped. Any thoughts?
  • steph_708steph_708 Member Posts: 1
    :sick: so about 1 year ago i took my car to get an indash on it. the shop installed the stereo right then and there but ever since my has many problems. the power locks, reverse light, trunk release won't work. and my air bag light won't go off, and when i put my seat belt on, the light won't turn off after about 1 minute. also when i turn the key to the on position i can't put my windowns up/down and the stereo won't turn on. if i want to do anything with my car i have to turn it all the way on. and before they put the stereo this didn't happen. also my batteries were getting drained so about 1 week ago i disconnected the indash. yes i have tried taking it to the shop but they deny doing anything to it. and i can't figure out what's wrong with it! i checked the fuses and they all seem to be working fine. can someone please help me!
  • norse81norse81 Member Posts: 4
    I have a 2005 LeSabre and notice the operators manual does not call for a fuel filter change. I just started using a small amount or Startron which is a fuel additive containing enzymes that are supposed to negate the effects of 10% ethanol which all the stations seem to have nowadays. In the fine print it suggests that the enzymes might flush certain crud from the fuel requiring an ultimate fuel filter change. What do you think of fuel additives like Startron and just where is the fuel filter located on a 2005 LeSabre. Thanks
    A company called Starbrite produces a fuel additive called Starforn which contains enzymes which is supposed to negate the bad effects of 10%ethanol. One cautionary note says the enzymes may remove crud from the gas which may result in fuel filter changes. The company seems to have many testimonials that favor the use of Starforn. I bought a bottle and added the prescribed amount to the tank in my 2005 LeSabre. I may be a little late but wht is the consensus of opinion on this forum regarding an additive like Starforn?
    I'm trying to figure out what ethanol in the fuel is supposed to cause as a problem. The alcohol is a cleaner. It picks up water in the tank and mixes it with the gasoline.
    In my opinion. add a can of Techron by Chevron sold at various box stores maybe twice a year and that will take care of any crude. Follow directions. Otherwise use a quality brand of gasoline and you'll not end up with tank goop.
    I haven't had a car that I changed the fuel filter before 110K miles. And then it probably didn't need it.
    I suspect they're commenting about filter change to try to make it sound like their chemical does something special.
  • andrewtheredandrewthered Member Posts: 1
    Des anyone know where ground fault 202 is on a '95 LeSabre? The fault is, well, faulty, and it cuts the power to the fuel pump when the circuit is loaded up too much. I haven't been able to find fault 202's place on the car, though. Can anyone help me?
    Longtime for an update!!! Got back from a long trip and 2mos vacation. Made up my mind while the battery was disconnected on my 2003 LeSabre to bite the bullet and change all of the bad bulbs in the HVAC unit and the radio. I used almost the entire bag of lamps I bought from Atlantic Lighting, mentioned somewhere else in this thread. They are a little smaller and are rated for 14 volts instead of 12 volts soooo they should last a lot longer. A pain to replace (2hrs), and waiting to drive at night to see my results, but worth the savings of $700 for a new HVAC module....................
    Typical dealer ripoff.
    Fred
    edited November 2010
    Had this, fixed today, the solution is corrupted wiring at two spots.
    1) Under the center of the driver seat, in the plastic sheath (that is only taped closed), you'll see four tan with white stripe wires connected with with a little white splicer... cut it out, splice together. This is the serial data lines.
    2) Also fixed, cause it was corrupted, yellow wires connector box inside the wiring canal box underneath the carpet and along the driver's side door. 8 yellow wires connected into a little plastic box... clean the contacts.
    Fixed!
  • rayznrayzn Member Posts: 3
    I have a 97 Buick Lesabre. I just tried to start my car and it acted like it was out of gas so I got 2 gallons of gas and put it in there. Now my car occasionally will start but shuts off almost instantly after. I recently hit a tire on the interstate it beat on my undercarriage pretty badly. I have been hearing a noise like a bang on the back of my trunk, like someone is closing a door right by my car while driving and sometimes right after I shut off my car. Any ideas or what other info might be needed?
  • jedd2jedd2 Member Posts: 1
    i just bought a 1995 buick lesabre my 2000 cts had to go to much $$$ involved the power windows or power seats dont work but the power mirrors do any clues :confuse:
  • bob252bob252 Member Posts: 48
    Anybody, have an answer to why these lights just quit? Is there a relay for them? The headlights work properly with the switch, but when the switch is off the lights go out, also had a problem with having no brake lights when they do have good bulbs, although the signal lights work, I have checked all of the fuses and they are good, I have a '97 Olds LSS,(which is similar to a LeSabre) After playing with the light switch (which is barely ever used) the running lights came back on once when I was looking at the fuses, but not since, can't figure this one out...also when I checked,(using the high beam switch) the indicator light on the dash lights up when holding it but goes out when released. (Imadoz? Mike? Anyone?)
  • advent70advent70 Member Posts: 4
    The pulsing horn and blinking lights goes off at randum times about 2 or 3 times a day for no apparent cause. The only way to stop this is to not set the alarm by locking the car manually. My manual does not show any Diagonistic Trouble Codes for the Theft Deterrent System.
    How do I start troubleshooting this problem?
  • hooper496hooper496 Member Posts: 1
    I have started to experience the same problem with my 1999 Lesabre Limited in the past couple of days. Nuts.
    Did you ever find a solution to the problem?
    Jim H.
  • patrick216patrick216 Member Posts: 6
    i have a 94 lesabre with 160,000 miles and all of sudden my dome light power locks and power antenna all went out at the same time i checked all my fuses under neath the driver side behind the glove box and under the hood inside the max fuse center and none of them were blown i also checked my relays....two were bad changed them still no help so im wondering if it could be a wiring problem?? but which wire could be connected to those three things?? please help
  • ultraprivateultraprivate Member Posts: 1
    On my 2000 Buick LeSabre, my turn signals don't work at all, but the hazards work fine. It was my understanding there are two separate flasher control units under the dash, one for the hazards and one for the turn signals. So I bought a turn signal flasher unit. I can find one for the hazards under the dash but do not see one for the turn signals to save my life. Does anyone know where this is, or if it exists at all? Also, my speedometer is also completely dead, I don't know if that is related or not, this all happened when I tried to replace a turn signal bulb socket and I seem to have shorted out a few things. Does the speedometer have a fuse or relay? Thanks
  • normangienormangie Member Posts: 1
    need help
  • cruz1982cruz1982 Member Posts: 1
    I am having the same problem with my buick. Have isolated the problem?
  • hjfadehjfade Member Posts: 1
    did you ever find an answer to your problem? i'm having the same issue with my 1999 lesabre.
