Buick LeSabre Transmission
I've got an '00 with a strange problem. At a steady speed anywhere between 40-50 MPH (about 1600/1800 RPM)the LeSabre will feel like it's got a miss, or it's trying to shift out of overdrive lockup. It will "buck" two or three times until I either speed up, of take my foot off the gas pedal. This happens about twice a day. The check engine light hasn't come on, so could this be a transmission issue? There's only 59,000 miles on it. I would appreciate any ideas and suggestions.
I'd recommend AC Delco plugs, and or new wires standard equipment level-no fancy red ones from the box auto parts store with the hot rod equipment. I think I got Belden from NAPA. You can change plugs first and see if that fixes it. You might note the color and buildup on each plugs. Label them with tape when you take them out; if one's different than others might indicate other problems.
I still recommend changing wires before 100K miles. If wires break down and create higher voltages, other parts of the spark system are stressed and may fail later.
Thanks, Guys!
Thanks Again!
:confuse::confuse: Has over 100,000 miles. Runs nice and smooth, But will slip when going from 1st into 2nd, will shift fine going from 2nd into 3rd, but will slip some more while in overdrive,or when i push the gas and reach between 50mph and 60mph,It kinda gives a feel as if the car is in neutral. when I let off the gas a little it will then go back into gear again.... Reverse works fine as well. Dose these mean my transmission is going???New fluid may unstick the solenoid. It sounds like it's sticking occasionally since you don't mention it happening everytime you slow down...
I'll check my 98 service manual and see if it's an easy change while changing the fluid and filter...
It could be a motor/transmission mount allowing movement causing the car to feel like it's quickly speeding up and slowing.
It could be a drive axle constant velocity joint (you don't mention the right kind of noise sound though)
It could be the differential in the transmission.
It could be the transmission.
Does it do it if you put it in 1 and start up? Or in 3 (uses a clutch pack instead of the regular overdrive setting start.
Have someone move car in a parking lot with hood up while you walk beside it to watch for movement in the whole motor/transmission unit.
With car jacked up and jackstands look under at the motor mounts and transmission mount.
I think the fact it only does it turning left is a sign. I think that the low torque of a gentle start is a sign. My vote is motor mount...
Thanks, Mike
Does it go into reverse after a few minutes of idling? Sounds like it needs a major diagnosis by someone on the scene.
Miles on car? Plugs wires changed in the last 60-70K miles with AC plugs and OEM level wires? Possibly a coil problem reacting to heat. Check each coil tower for cracks or tracing of spark jumping. Check bottom of coil for poor contact to base to which they bolt.
Check connector at the end of the base for poor contacts.
LBM
Check the wheel bearing for play, up/down, left/right with the wheel jacked up.
How are the tires? Worn unevenly? More than 5 years old? Tire tread hardens with age and can cause a sound from the knubs that is reminiscent of snow tires at a low volume in the old days.
Has anyone put the car on supports in front and driven the wheels with the motor through the transmission?
Number 1 would be wheel bearings if the tires are okay.
Number 2 would be the differential inside the transmission.
Frankly you might save yourself some trouble by going to a good Buick garage for a diagnosis, whether or not you intend to let them fix anything.
What is the cost of the differential inside the transmission ? $2,000 or more ? If yes, I'll just trade it.
Thanks much!!
LBM
What tires do you have? I'm curious about the tread causing a vibration.
But actually I believe it's a wheel bearing.
Jack it up. Rock the wheel around and compare one side to the other looking for looseness. Be sure you're not getting ball joint movement, though.
Have someone rotate the tire and put your hand on the solid frame of the car to feel for vibration from the bearing.
The description sounds like a wheel bearing I had. You're at 157K miles. A bearing is possible.
BTW, I learned something about transmission in my search. If any of you have a hard thud at times when shifting gears, and it is only now an then - according to the transmission guy AND the dealership - it is the computer - but neither knows how to fix it, or what makes the computer do that. And also, it will not show any code when checked. If you park the car, turn off the engine long enough for the computer to reset, and re-start the engine, the probloem goes away - until the next occurance, of course.
It sounds like the transmission computer has gone into safe mode and makes a firm, quick shift to protect itself. If I understand the programming from what has been explained, the computer is always measuring the length of time for the shift to occur; that it adjusts the next shift to get the proper firmness. If it measures too long a shift period, that particular solenoid is taking too long to effect the shift and the clutch pack is slipping. So the computer speeds up the shift time to prevent slipping excessively which is hard on the clutch packs.
When the computer restarts it probably is retesting to see if the problem is really there. It finds no problem so it's back to normal shift times. My guess is the problem could be something other than computer. It could be connections or something else erratic in the transmission.
My guess and comment would be to drive the car briskly to make the transmission do more adaptation to the shift quality and time. The occasional problem might go away.
Thanks for reading!
Really not sure where to go next. Thought trouble might be temperature related but there is no pattern to when it happens.
Any clues would be a great help. Rudy
Can you explain a little more. Are you saying the motor shut down, stopped, and you were coasting, and then the motor restarted all on its own? The motor won't restart by the transmission turning it while the car is moving.
Is it possible the motor just slowed but kept turning at idle speed then picked back up.
My two things to suggest would be to carefully check all battery cables for corrosion at both ends. Especially check between the two positives if yours has the one on top of the other. Pull back the plastic layers on cables to see if the copper is corroded down into the cable. Check for battery post problems.
Next would be based on the statement from another board Pontiacs that the computers in 94 and 95 have a higher probability of flaking out. The computer itself is not expensive. I believe someone got one at AdvanceAuto for $100+. You reuse the PROM chip from your old computer.
You need a competant mechanic. If he can't connect to the OBD 1.5 cables for H bodies in 94 and d95 for his code scanner, find someone else. If you're into throwing money at it, I'd replace the computer myself. Junkyard, Advance, elsewhere. Do some shopping. Some new parts are bad also so don't buy junk!
I know little about problems because they usually are rare, unlike with some other cars. Are you sure the mileage is 85K? and not more? Was a carfax run to look for mileage change since you bought the car used?
Otherwise the pressure control is the only thing I've heard mentioned as occasionally causing a problem. I don't know if the whole transmission needs to come out. It may just be the side plate removed to access. But that's not easy! In this case if you take it to a trans shop they'll probably try to sell you a replacement transmission or a complete teardown. I'd take it to a good Buick deal to get a diagnosis. Find one with a good referral.
BTW, what color was the transmission fluid? Remember additives are like going to the hospital and telling them to just remove something in case it helps your problem! Changing the fluid and filter is good. And I believe one poster in another discussion suggested that Lucas is meant to be put in and then drained shortly after rather than being a long term use item. Maybe I'm mixing up a different Lucas product someone talked about... so don't take my word as gospel.
Just get her checked--I'm betting on the pressure control module.
Will tackle the MAF sensor next. Thanks for the ideas.
There is also another 3 lead sensor beneath this unit with an orange connector on it.
Can you identify these sensors?
The other sensor is a throttle position sensor. It measures how the throttle is opened. You can put an analoge ohmmeter across two of its leads and move the throttle. The resistance should change gradually. If it jumps that means the potentiometer windings have a worn section. That sends info to the computer telling it how much you have the throttle opened requestion GO. If the windings give the wrong throttle opening, the computer tries to give fuel for a different amount of air than the throttle plates are letting through.
Thanks again.
Received and replaced the IAC. Ran great on a 40 mile run. Next day it burped again and today it burped frequently and stalled completely twice.
I'm wondering if the fuel could be cutting off intermittently. I had the fuel pump replaced about a year ago but this problem didn't start till months later.
The first time I brought it to my mechanic he drove it around and said he didn't notice a problem. Any thoughts.
It could be transmission/motor mounts allowing movement causing the shifting change. Could be internal.
Well I found a guy selling a trans out of a 1995 LeSabre (front wheel drive like mine, with the same engine. The 3800.) He is selling the trans for $350.
My question is a parts dealer told me that Buick made two transmissions with different gear ratios.
Does anybody know how to tell if the trans for sale will work in my car?
Or how to tell the gear ratio of the transmissions?
Thank you for taking an interest in my post.
This just started last night. I was going through a drive through and I was hearing a creaking noise coming from the left front wheel while just idling through the parking lot. It does not make the noise when I use the brakes.
What could be wrong? Bearing, or disc?
Jim
