Visitor Agreement.
*sigh* will b glad when this is all over tho!!!
To test ball joint place car on lift and pull tire in an up and down motion. Is there play. If there is you need a new ball joint. The same goes if the upper control arm are free play.
Over the past couple of weeks I have replaced several items on my 2000 Lincoln LS VB with 74,000 miles. The first were the faulty sway links. They are easy to replace just loosen large bolts with either an allen wrench or small open ended wrench and the other a larger on the main bolt. These were $40 for both left and right side. The second was the driver side lower ball joint. This was a difficult task but can be done if you have the right tools to remove the old one. The best product I found was a MOOG ball joint. They say you have to buy the entire knuckle with ball joint installed for around $300 but with $58 and your own power tools and ball joint removal kit you can do on your own with the MOOG. The final item installed was an driver side upper control arm for $116 from Rock Auto. This item is difficult to remove to the rear of tire bolt. This is how I did it. Car on lift loosen shock 4 bolts on top and the large bolt on the bottom. Do not remove the center bolt of the shock. Go into the engine and remove the inner bolt located just behind the air filter. The second bolt is underneath the brake reservoir. This is rough best to loosen from top it will be tight though and take a psuematic
air socket from the bottom. Place in position the new control arm and tighten bolts on top. Pull through the top ball joint and tighten up. Once cannot tighten any more use two wrenches on end going opposite directions. Then reinstall shock ensure all bolts on top and the lower is also tightened properly. This is how I did this job.
:sick:
Any info you could give as to how to go about changing bushings will be much apprieciated.
i have 02 LS and was quoted a crazy amout to replace control arms when all I need is bushings. I have located bushings only.
I own an 02' LS 3.0. Recently I was turned down inspection do to the steering rack leaking. I had the work done on the car got the sticker and a week later it seemed to be leaking worse. I could actually see the fluid on the ground where I had never noticed it before. Took the car back and had another rack installed. this time it was placed off center. I could turn the wheel right and go in a circle standing still basically and could hardly turn left so again I brought it back. The mechanic has told me that alot/all of the replacement racks made for my car were built defective and that his supplier is having one made... I personally find this hard to swallow and I cant find anything online about it. They have had my car for about 2 months now. does this replacement part defect hold water or should I get a refund and go elsewhere???? thanks in advance.
