Dodge-Plymouth Neon Routine Care & Maintenance
Was curious if anyone has a comparison on the
Champion RC9YC vs Autolite 3923 spark plug for a SOHC Neon?
Which plug makes the Neon more responsive?
Farout
Farout
Farout
Farout
can anyone help me?
New here and my 2000 Neon ES just ht 72K and is starting to have some minor issues. I just had 4 new tires put on (3rd set) and this time I was told that the factory settings "aren't there anymore" and I need to have 3 camber kits installed and "soon." So said the tire man. He said if I don't have these installed, it will wear the tires prematurely. As an aside, and I will be going back, since the tires and allignment, now when the car hits 60-65, the wheel shakes something fierce. Do I really need these camber kits? He wants $80 each just for the parts. If I do need them, I'll get them elsewhere and take them to my regular mechanic. He is good, fair and reasonable but usually keeps the car for a couple of days so I try to find out as much as possible before hand. He also just recently recommended new water pump and timing belt as preventative maintenance. Also, at 42K th eengine light started going and staying on and dealer said it needed 02 sensor, which they replaced. It was still under the extended warranty so it wasn't expensive. At 70K it went on again and stayed on. A couple of weeks later, I had the air filter replaced and the light went off. A month later it went on again. Then I had the battery replaced and it went off for a couple of weeks. Back on again 2 weeks later. I saw some posts re: 02 sensors and faulty warnings. I know this is a lot, but I like my car and am in no hurry for another car payment. So any advice is helpful. I am on the road a lot and except for many dents (not due to my driving) it has run pretty well. I get regular oil changes and tune ups.
Thanks for reading!
Farout
http://www.chrysler.com/owners/index.html
farout
If you look for transmission fluid at your local automotive store they usually have some substances their that will greatly improve the slippage. of your transmission. Mine sounded awful one day and I was severely short on funds to pay for a rebuild of the transmission. Here I am and it's been just over a year and no notice of it as a problem. But if it even starts to seem like it's slipping I get this stuff for it. It only costs about $5.00 and I get it usally about every two months. I do drive my car alot to work and back too. Maybe you can check into it and save some major bucks. It seems to me it just has more to do with fluids in the transmission than actual wearing down of the parts. Hope this helps.P.S. I do all the minor work on my Neon and my hhusband doesn't touch it. Get yourself a Haines book for your car too it will help you learn better. I have to read it three times before I start the work to make double sure I know what I need to do before doing it. You will feel better about doing it yourself too. RedPath
Today, it started to make the godawfullest noise, first only when I hit the brakes, later just when the wheels were turning, like it was rubbing metal to metal, and it didn't feel like I had ANY breaks when I got it home.............. Any suggestions I can take to the dealership tomorrow (other than some I can't print, and probably shouldn't tell them about)?
My questions: What's on schedule to be done? Roughly how long do these cars run before major issues? What would you recommend having done?
You might need to tighten up whatever belt is making noise and if it is glazed (polished and smooth on the interior surface of the belt) you need to replace it right away--because it will continue to slip and encourage over-tightening.
Second off my check engine light is on and I have been told that it is a heating and cooling sensor. I can not find this sensor that they are talking about any one have any ideas?? I have checked all the fuses inside the car and they are good. :confuse: :confuse:
