Chevy Express/GMC Savana Accessories & Modifications
in Chevrolet
Hello, Someone ask about adding seats to their van.
I added three bench seats to my Express cargo van by getting the tracks, seat belt winders, and seats from an older Savana van and installing them in my Express cargo van.
It worked out really well. I can now haul 11 people!
I can tell more about it, If someone is planning to do this.
Bill
Bill
2
Mel
A turkey vulture actually ripped off the entire passenger side mirror, I thought, I'll just replace them with the new and improved heated with turn signals version, I believe 03-06.
Based on your experience, what are your comments on these mirrors?
I added a bench to my 1500. worked out fine.
Did you have any issues with installing seat belts or did you have belts that were GM? I got all my seat belts for $114 and I know if I buy belts that are GM it could cost $100 each.
Brian
van's great
Did your retractor and belts look exactly like the rest of the stock seat belts that were in your van? with no plastic around the retractor and two seperate belt clips to attach the belt on both sides of the seat? On my after market belt it attaches to the seat by bolts on one side and a standard belt clip only at the end of the belt. Below is how my after market belt looks like:
The challenge that I am having is how to mount the retractor part of the seat belt on the back wall. I bought some factor bolt from a GMC dealer so that I would have the correct bolts (right strength and size) but I do not see how I am going to fit this retractor on the back wall of the van. Any suggestions.
I recently bought a 1995 Chevy G30 cargo van. I need to put in a bench seat but don't know where to bolt it down to. I don't want to just bolt it to the sheet metal, because I don't want it to tear out in the event of an accident. It seems like the main frame beams are U shaped. Any suggestions?
Brett
Nick
i have a 2009 chevy express cargo 1500. What's the best way to install a rear seat for 3. i sure do want to leave ample space in the middle. i was thinking maybe installing it close to the end. can i get some advice in installing the seat securely? thanks.
merlo
Prepaid Professional Install Card - Mobile Video/DVD Player 1 Will arrive between Friday, 09/04/09, and Friday, 09/11/09. $99.98
DP Video 9" Flip-down Monitor with built-in DVD player, DZD9500 1 Will arrive between Friday, 09/04/09, and Friday, 09/11/09. $168.88
We also bought things from this website:
www.discountvantruck.com
We bought our seat from them and it worked out well also!
Can i ask if you have the rear a/c - heat? Did the controls interfer with the dvd player at all whether during the installation or during operation / screen blocked from a/c heat controls?
Does anyone know if the 2009 1500 8 passenger van can except a fourth row seat?
I purchased a 2007GMC 2500 Explorer conversion van for a wheelchair transport for my son who was born with spina bifida. I have lift in it. Its a 6L. I am having some traction problems I have tiger paw snow tires that I run at low pressure. Any suggestions on size of tire and type or jjust weight back end ? I dont think it has stabilitrack. Its a very important vehicle for us and I really could use some help thanks.
Here's what I'm guessing I would need:
* Electric trailer brake controler
* Weight distubution hitch
* Transmission cooler
What else do you all think I need to install?
If you are looking for a used van, I am selling my 2009 chevy express dark green in color. It seats 11 (I added a 3rd row). I am buying a 15 pax as my family has grown and I do not have enough room.
Thanks for the information, I guess I'll have to call a dealer. boo.
I've found a donor 2009 model that's being parted out locally.
Does anyone know if the 2003+ interior parts and be installed in a 2002 or earlier without serious modifications?
Also, the factory drivers seat has no right side arm rest, what other seats can I replace it with?
thx.
I talked with the local dealer, but they could not offer any help.
- infrared
1. What years (or only 2006) will fit on this van?
2. Will Savana doors also fit? If yes, same question, what years or only 2006?
I need to add 1 backseat to my 2002 GMC Savanna Cargo 3500.
I'm converting it to a full camper so not much room but just found out
my 10 yr old son isn't legally allowed to sit in front seat till he's 13.
I'm hoping to put it in the "row" behind the front seats and directly in the middle
( directly behind where a small jump seat would go )
Or, If I have to directly behind the passenger seat.
Need to be removable.
Thanks very much
I install a ford transit seat bench in mine that came with seatbelts already mounted on them. I had to be careful of installing it since one bolt was above the gas tank. https://www.ebay.com/itm/2018-Ford-Transit-OEM-Seat-Black-Cloth-55-Triple-Seat-2nd-Row-/264643208417
