Ford Windstar Care & Maintenance
I have a 1995 Windstar (price was right 0) but am looking for a repair manual that is not Chiltons (for mechanics) but not "auto repair for dummies" (which walks you thru checking your oil) I am hoping to find something in between ...like a "readers digest how to fix" manual.
Do you have any suggestions, cause I can't afford to keep taking it to the auto shop (starter 250; fuel pump 500; brakes 660; water pump 250; axle cjoints/tie rods 650 and now the battery isn't holding a charge or isn't being charged up (alternator my guess). For a "free' car it isn't turning out to be so free....lol I understand an older car is going to have things going wrong/breaking but if I could locate a manual that I can understand with step by step instructions I could do some of the work myself
Any suggestions you have I would greatly appreciate.
Barbara Banks
Barbara Banks
36097 - Windstar Mini-Van all models '95 thru '03
here is the website, but you can order from any mainstream automtive center, in Canada we use Canadian Tire.
Mike
This is very easy. Draw a picture of how the belt is routed before starting.
Turn the wheels as far as they will go to the right.
Go under the vehicle and take a standard 13mm open end wrench; turn the belt tensioner bolt clockwise until loose.
For this next part you will need to put your game face on!
From the top of the engine, pull the belt toward the alternator this creates excess slack from the loose tensioner, so you can remove the belt.
Install the new belt, you will need your game face again when putting the belt on the alternator!
Then tighten to belt tensionor by turnin it to the left.
This is a 30 min jog and you can get the belt from Auto Zone for $16.99.
Good Luck!
Check out this article on Edmunds.
Where To Find Your Car Owner's Manual Online
http://www.genuineservice.com/genuineservice/en/default?page=Home&nav=glovebox
Any help?
Thanks again to all the smart people ou there.
Jim
Did you find the reason why your driver side door power window was not working? If yes how did you repair it? You answer is very much appreciated.
Jagadeesh
I have trouble with the power locks not working good. Just the side doors though. The passenger one is the worst one. No matter how often you hit the unlock button from either front passenger or driver side doors, it will not come up so you can open it. You have to unlock it by hand usually. Both side back doors do this but the worst is that passenger one. It's like it's dirty or something...anyone have this problem???
I have also had problems with the dome lights staying on when you have turned it off and walk away, you think they are going to go out...and they do not. All doors are closed, locked, and the next morning you find out you have a dead battery. Now it's just habit to always wait on the dumb lights inside to go off so I don't have the problem. There has been times I've had to get back in the van and turn the key on and then off and then close the doors again and they lights will finally shut off.
These vans definetely have some sort of electrical problems.
We are constantly changing tail and reverse light bulbs too. What's with that??
Otherwise it's been a pretty good vehicle...if these little things don't drive you bonkers!
Happy Driving...
Seasand
