Greybaby
http://www.myford500.com/forums/viewtopic.php?t=7336
Make sure your dealer is aware of the updated version and tell them again that you had noticed a lot of brake dust on the rear wheels leading up to the 15,000 mile service and that you had stated so at the time. Good luck.
People need to remember that a TSB is not a recall and therefore does not necessarily give you a free fix. They are issued to dealers to assist them in diagnosing problems that are often common to a particular vehicle type. There are literally hundreds (if not thousands) of TSB's issued by car manufacturer's every week.
Merry Christmas!
Greybaby
Greybaby
Mark.
I always park and set the parking brake, but I don't think the parking brake uses the regular brake calipers, so that may have no affect on the rear brake wear. :shades:
BTW, mine is a new 2005 awd limited, rear sets(pad & rotor) have to be replaced at 8.5k.
I don't think hand brakes is associated with normal brakes.
My accord's brakes lasted over 75k before replacement.
:sick: :P :lemon:
I'm going to file a complaint.. If we don't let Ford know what's going on how will they know....
Simple. Just drive around with the parking brake on. Unfortunately, people do it all the time. It only has to happen once to basically ruin the rear-wheel brakes. Two or three miles would do it. Some people are easily capable of driving that far before paying attention to what might be wrong. Might also explain the overheated rear-wheel bearings someone mentioned. It's not the sort of thing that people will admit to. It's easier to blame the manufacturer.
As I said before, I have 19,143 mostly city miles on my '05 SEL FWD. The braking feel and performance is no different now than the day I bought it with 4 miles on the odometer.
http://www.ford-forums.com/ford-freestyle/3590-rear-disc-brake-pads.html
http://www.carreview.com/cat/automobiles/suv/ford/PRD_368841_1524crx.aspx
http://www.myfordfreestyle.com/all.php
That doesn't sound like a DESIGN problem, then. More like defective pads?
But with "only" 5% experiencing it, I'd be inclined to say it's more "user error" than a design defect. Unless the design is such that it's easy to end up with drag and not notice it for very long periods of time.
I had my car in for a scheduled rear brake replacement on 12/21. Dealer gave me the car back and said that the new pads were on order even though I had given them a week's advance notice. I thought maybe they were trying to brush me off since another local dealer said they would not do the work on Freestyles with more than 18k mi. To my surprise they called back the first week of 2007 and had me schedule a time to replace the pads. Dealer told me he used the pads recommended in TSB 06-22-17 and mine was the first Freestyle he did with those pads. My 05 Freestyle SEL had 25200 at the time and the service and parts were free of charge because I was under 3 yr. 36k miles. I have a long commute (in the 'burbs heading toward NYC) and I'm always in heavy highway traffic but I am also among those who feel that there's a defect of workmanship rather than my driving habits that are to blame.
I have studied pads for this and find high-end ceramics available (Akebomo, EBC RedStuff, etc.), and low cost ceramics (Raybesto, Satisfied, Durlast, etc.).
A big surprise is the Motorcraft* pads are listed to be ORGANIC, 'not' ceramic and maybe not even semi-metallic. I don't think I have used pure organic pads in 30 years.
*I don't know if Ford P/N is same as MC part. This could certainly explain the short life.
After everything I've read here I fully expected to need a full brake job. After his inspection he said that the rear brakes were fine and I had at least 10,000 miles to go before needing pad replacement. He suspected the squeaks were just some sand or salt getting in the brakes.
Interestingly he did say that the pads that were on there appeared to be organic but his computer specified ceramic. I suspect Ford has changed the spec to address this issue.
- Chad
I have been following this brake discussion for some time, and it sounds as though there might be multiple factors in the brake problems people report. The design of the brake system may be rear brake-oriented (at least some people have stated that),some are defective, some have sticking pistons or handbrakes, etc.
How about the CVT transmission, though, as it seems to provide far less braking effect than a regular automatic transmission? Therefore, for someone who drives in crowded conditions or with many lights and so brakes often, the cumulative effect would be for much quicker wear. Combined with the design towards more rear braking, that could lead to fast wear out.
Just a thought.
This is true of highway speeds, but I have noticed that on city streets at around 35 - 40 MPH, if you let off of the accelerator, the FS just wants to keep going - it takes a long time to slow down.
http://www-odi.nhtsa.dot.gov/ivoq/
