Mazda5 Tires & Wheels
in Mazda
:shades: I am very interested in getting some new wheels for my Mazda5. I was thinking of getting 18inchers w/low profile tires. Of course something nicer than stock. I am a bit worried about how the tire pressure sensor is going to react. Any info on how I should do this? Has anyone upgraded their wheels. What are your experiences? :shades:
If not... then it is a bit more complicated.
1. Can I upgrade my 17"inch wheels to 18" wheels on my Mazda5?
2. Will I lose any warranties if I upgrade my wheels to a bigger size?
3. The new wheels I am looking at DO NOT have or accept TPMS sensors, will that become a problem?
4. Are there any tire size considerations I need to be aware of?
Any help would be greatly appreciated...
Does anyone know for sure?
The tire pressure system comes as part of the GPS Navigation system, I believe.
http://www.msprotege.com/forum/attachment.php?attachmentid=77249
2. Not sure about that one... maybe you wouldn't if the dealer sold you the 18" wheels or tires
3. Not a problem as long as you don't care about the TPMS light on the dash staying on... Actually, you may want to check the fuse box and you might be able to turn the light off by pulling a fuse... maybe.
*Forgot to add that we also have the navigation option which may be the option that adds TPMS
Also some of the trade-offs have to do with the tires. The Mazda5 have fairly aggressive tires for handling purposes, and I suspect the RAV-4 tires are for mud & snow in keeping with the SUV imagine. So the Mazda will out handle the RAV-4 in dry weather and have a less likelihood of tipping over.
As for the long sound related to brakes in the wet weather. Again, I personaly have not experiences that in 12 months of ownership.
It takes time to learn to be gentle with the gas pedal.
I think this is normal with newer, lighter cars. I always see other car's front wheel spin when accelerating from 4 way stops.. on a wet/icy pavement.
we had a protege 5 and as soon as the factory crap dunlops wore out I put Kumhos on and it was like driving a different car. our fuel mileage actually increased also.
Has anyone else experienced this? What type of rims and tires can I buy to avoid this in the future?
When I bought my MZ5 (USED) it had two wheels with bent inner lips, which the dealer replaced with another set of MZ6 wheels. So although they may look plasticky or are aluminum or whatever they are made of, they do bend. Just FYI!
Anyway, I didn't notice the noise until AFTER the tire rotation and balancing. The shocks and suspension are totally fine - the car's only a year old. But, before the balancing, I noticed a slight tremor over 60 mph, which indicated that one of my wheel weights had fallen, right? Well, after the balancing and rotation, the tremor is completely gone and the car is completely smooth again, BUT I hear that high pitched noise at highway speeds on CERTAIN very SMOOTH roads, especially when raining. And the sound sounds a lot like what you described, only at a higher decibel most likely because the tires are smaller than big off road tires.
I certainly hope the tire(s) get(s) accustomed to the rotation and that the noise goes away. I've noticed that ever since I returned to NY from NC the noise has somewhat dissipated, but on certain smooth highways, I still hear it, albeit less than when I first noticed it in NC. So, maybe it is going away. In any case, it's an annoying noise and it makes the car seem cheap. My wife was complaining about it and she hated the noise and said it made the car seem like an $8K Kia, or something. I do hope it dissipates.
Thanks for your explanation, though! Is there anyway to fix it?
It sounds like your tires might have already started their "re-accustomed" trial since you mention that it has gotten better. There really is no fix for this, other then just letting the tires wear evenly with time. However, you can prevent this from happening in the future by getting your tires rotated at least every 5K miles (or every oil change if you do your oil changes every 5K miles) and getting an alignment once a year or 15K miles just to keep those wheels and tires nice and straight. Besides, keeping your tires properly inflated, rotated and aligned prolongs the life of your tires and keeps your MPGs at normal and sometimes better levels.
LOL! ....watch out when you mention the "KIA" nameplate in here in a negative way, there are many RONDO lurkers that get offended...LOL!
Many people have complained about the Toyos but i haven't had any problems with mine other than they seem to be wearing rather quickly (hard to know exactly the mileage on them since we switch to winter tires every fall). Mayhe with new tires i will notice the difference.
Regarding road noise. In general, I do not think this car holds out road noise as I could hear both my old and new tires. It is not a big deal to me but I have seen this post in a few forums. It WAS a big deal when my tires and bent rims were making noise...drove me nuts...hence the reason I went with new rims and tires.
Considering that the sidewall is 0.4 inches taller then stock tire, I would assume that it gives a little bit more protection against bending rims, and the fact that it is almost an inch wider as well, I am sure that curb rash is less likely then stock tires.
See for yourself here.
Thanks for the tire sizing link. Those tires seem a bit oversized though at 1.9 mph speed differential. Any issues with sharp turns and rubbing of tire on the undercarriage or body?
Like to see any pictures of those who have changed their Toyos out to different sizes..
BTW, your username nissmazlover....I take it you love Nissans and Mazdas???
I am in the same boat as you if that is true with you, I love my MZ5, but my greatest pride and joy was my 2004 Nissan Frontier Crew-Cab Short Bed Automatic 2WD with tons of stuff I put on it i.e lifted, 32" tires, rear diff locker, etc
Unfortunately it lost to the ridiculous super high gas prices. Since it was all off-road hooked up it constantly gave me 14-16MPG, my pockets were hurting big time.
Needles to say...I miss my "Little Fronty That Could" this is the name my off-roading buddies gave it because it was such a capable off-road truck even with just 2WD and a locker.
(sigh) ahhh memories.....
Anyway, yeah, I had a friend who had a Frontier and that truck was indestructible! He abused that thing, and it just kept on going. He had to get rid of it since he got married to a woman with kids and he lamented that loss. So, yeah, I know what you mean.
I always imagined my first new car would have been a Nissan, but when news and pictures started coming out in 2005 about Mazdas new mini-minivan, I just fell in love with it. It seems as though it was perfectly made for me and my family! So, before it came out, I searched the Mazda dealers here in NYC and found out which one would get the 5 first. When they received it, i went over right away, test drove it, LOVED it, and actually bought the one I test drove - which, incidentally, was the first Mazda 5 sold in NYC (July 2005). If Nissan would have had a car like that, I would have bought the Nissan, though. But, they didn't, so I went the Mazda route. Have always loved Mazdas, though. My mother had an 89 626 that the whole family loved. That car was TOTALLED at one point, fixed and it still felt like new and kept on ticking for years afterward!
1. Wider tire = better grip.
2. 0.5" taller = smoother ride.
3. Awesome deal (I work for a dealership, so I got a set (4) of Michelin Pilots HX 225 50R17 93V take-offs for $150.00)
Has your opinion of running size 225/50/17 on the MZ5 changed since your last post? I am wanting a larger size tire to guard against curbing and potholes and was going to just go with 215/50/17 until I saw your post. I'd like to go with the 225 if it doesn't rub at all. Have you gotten them to rub? I read you're running MZ6 wheels...do you happen to know if the offset is the same as the MZ5 wheels? Thanks for your help!
I have been running with the new tires (225-50R17) for about close to two months. I have been able to make them rub under two circumstances on two seperate occasions, but I still would not downsize because the better grip and "alot" smoother ride over compensates for the "very lightly" rubbing.
FRONT:
1. Turning wheels (either way left or right) all the way to lock turning into or up a driveway, where the suspension compresses and the wheels are locked all the way to one side.
REAR:
2. Loaded up with 6 adults (LT/FT 215lbs, RT/FT 195lbs, LT/CTR 130lbs, RT/CTR 230lbs, LT/RR 220lbs, RT/RR 110lbs) and going through a speed bump as one comes out of it and the suspension compresses or going fast through a large dip where the suspension is being pushed to its limits.
The MZ6 wheels were not my choice. The two of the original MZ5 wheels were bent and the dealership swapped them for me for the only Mazda wheels they had in the lot, which happened to be a 2008 Mazda6. I do not nessesarily like them, I would prefer to have the MZ5 wheels instead. However, at least now I have a smooth ride because the wheels are true and nicely balanced. I would love to get my hands on a set of nicely used MZ5 wheels but they are hard to come by and very expensive. Needless to say, I don't know what the offset is for the MZ6 wheels I have on, but they seems to work just fine.
I live in Vancouver British Columbia and plan on purchasing a Mazda 5 in the next couple of months. I have noticed a few Mazda 5's on the road around here with very plain, black rims on them. This is for all 4 wheels. I am assuming they have mounted winter tires on different rims and changed all the rims at the same time to avoid any salt, etc. damage to the stock rims. Can anyone tell me what rims these would be and where they might be purchased. If they are from the dealership, I will try and work out a deal when I purchase the vehicle. Thanks.
Just thought I share this fact.
Costco runs a $70 off four tires at different times. This time there was a promo on Bridgestones - good enough.
I was very surprised to see that the depth of the nobins was much deeper (or greater) then the original tires had when new. That may be the primary reason for the premature wear - they are pre-worn
The maximum inflation pressure on the original was 40PSI (or at least that's what I thought). These ones are 56PSI.
The alignment guy told me he would inflate to 38PSI. The minimum is 34 (per label on B pillar).
I think I have them at 37 now and the car does not feel as stiff as the old tires felt at 36.
I gave up on swapping shocks. I have no signs of wear, yet.
