Ford Crown Victoria/Mercury Grand Marquis: Real World MPG
For those of you who live in cold climates, how much of a drop in MPG do you experience in winter? I was shocked the other day when I calculated a 5 MPG drop on my '94 CV since the weather has turned cold (i.e. below freezing).
Almost all of my driving is short city trips, so the drop might be explained by the engine simly not having enough time to heat up to allow optimum performance. Tire pressure was also a bit low, so that likely contributed a bit as well.
Just curious as to what effect the cold weather has your MPG.
1. Engine not completely warmed up.
2. Cold air reduces air pressure in tires, causing more of a drag.
3. "Winter" gasoline containing up to 10% methenal or some other adverse chemical that prevents fuel lines from freezing.
4. Have you installed a roof top ski rack or luggage carrier?
I think that there are a few factors that explain poorer fuel economy in the winter. Longer warm-up times in the driveway, more power required from the engine to overcome cold tranny and differential fluids, and more wheel slippage all contribute to wasted gas. Add to this the extra drag of blowing snow (at least where I travel!), the extra weight on your car due to ice and slush, and you can see that winter is a recipe for poor economy. My car is noticeably lethargic when it is coated in ice after a big storm!
thank you
So, I fill them to 42 psi hot, let sit overnight, make sure out of sunlight in am, and let air out to 37-38 psi cold...firm ride, yes...better mpg???...no...
If tires leak out air down to 32-33 psi, I feel like I am riding on slush, with no control whatsoever...
Bob
Tires running greater than recommended psi are more subject to impact damage.
1 what’s the year of your vehicle and your current MPG average?
2. What Viscosity(5w-20 or 5w-30etc) and type(Mobil1, Valvoline etc) motor oil are you using?
3. What’s your cold tire pressure?
4. Have you ever hade a used oil analysis?
Me:
2000 GM 24-26 MPG
5-W20 Mobil1
34PSI cold
I never done used oil analysis/ I will with this oil change
The Handling Package enables better cornering and less pitching, but at a price of having more road feel and noise. So to install Comfort Treds would counter the advantages of the Handling Pac, but improve the ride.
I'll look into the Comfort Tred tire and thank you.
My used oil analysis consists of "yup, it's used." :P
FUEL ECONOMY
AVG - 22.45
HIGH - 28.71
LOW - 17.74
PRICE
AVG - $2.555
HIGH - $3.059
LOW - $1.999
So if we are paying $2.50 for gas currently, just think you've been paying that much all along on average.
We have two Ford products - each with same engine (4.6) and AOD transmission. '94 Towncar and '95 Thunderbird
Town Car @ 70 MPH gets 23.0 Thunderbird @ 70 MPH = 26.0
City driving gets 17 on each.
Mileage can be improved by using synthetic oil, 35 psi of air in the tires, clean air filter, and clean mass air sensor. There are a lot of variables to gas mileage.
The other 50% was on 40MPH suburban roads with a medium amount of traffic lights.
I do not have a lead foot and pretty much drive the speed limits.
We're leaving for Blackcomb Friday & will fill up just this side of the border.
I envy your having been in the Canadian Rockies & hope you were able to visit Jasper and the surrounding area.
I don't know the differences between our Marquie and theirs, but would not be suprised to learn the CA engine is not the 239hp, but perhaps the 210 and maybe even geared higher. How was the acceleration?
I just got back from a 800 mile round trip that was 90% highway driving between 65-75mph. I got 26mpg for the trip.
The car now has just over 3kmi on it.
Sites like Edmunds.com are good sources for getting mpg numbers from a variety of owners and driving situations. Just remember you're most likely to see only the highest/best or lowest/worst mpg posted or reported online. As they say, your mileage will vary. We appreciate your purchase.
That Ford continues to install Crown Victoria engines in Town Cars is not providing a Town Car level engine for the TC. The price of the Town Car screams for a more powerful and distinctive engine. At least provide a "Power Option" engine of 5.4 L enabling the TC to not be plagued with the same engine as the CV. The Power Option should be a $250 extra cost item. The 239 hp 4.6L is just too enemic when traversing the Rockies and Cascade ranges both here and in Canada. :sick:
Your Panthers have been since 1998. When will we be given the option of a NEW car with NEW styling that still seats Six?
Presently, your 2008 TC drives me towards the Jaguar XJ8L and we've owned three TC's since 1980.
Thanks for the feedback. I'll forward your comments to the correct departments. There are a lot of factors behind design, engineering and marketing decisions including customer input. As I can't monitor every site all the time, I'd like to recommend another way you can let Ford know what's on your mind. Please visit ford.com and give us your feedback. The comments posted there get forwarded to the proper department for evaluation. Again, I do appreciate the time you've taken to reply to my post.
I don't know how much less it is.
On average, my car gets 17 or 18 mpg.
Does anyone know what other factors contribute to lower fuel economy on this type of car? :confuse:
Over time, the Air filter gets dirty, check it and maybe replace it.
Unnecessary idling wastes fuel as does Jack rabbit starts. Drive smoothly with no quick moves.
Try the next level quality of fuel such as Mid grade, 88 or 89 octane.
1. For my new 2008 Mercury Grand Marquis LS, for the audiophile system I have, where are all 8 speakers located, along with the subwoofer? I can only find 4 areas with speaker grills (1 in each of the front doors and 2 behind the rear seat). Do each of these areas have 2 speakers next to each other?
2. Why doesn't the steering wheel lock? Every other car I've ever owned had a steering wheel that locked.
3. What were the manufacturing problems that prevented them from being able to give me the laminated side glass option I was supposed to get with my order, but did not?
4. Why did it take 4 months for me to get my car after it was ordered, instead of the 2-3 month wait the dealer said it would take?
Although I'm not happy with Ford customer service, I'm very pleased with my car. I've had it 2 weeks now and feel I've made the right choice.
I haven't had the opportunity yet, becuase most of the E85 dealers near me only charge 5-10% less for E85 than gas, and I understand that E85 gets at least 15% less mpg. There are some other stations further out where E85 is about 15-20% less than straight gas, but I dont want to make a special trip out that way, but will give it a shot next time I'm out that way, just wondering if anyone has any data on this????
If you air up the tires to 35 lbs and then feel every crack in the pavement as the car corners like a locomotive, you probably have the Handling Package.
Averaged around 23-25 mpg ove rlong distances.
Will be picking up my Dads' '05 CV shortly ( he can't drive anymore). Hope it does as well.
Great car to drive these days - the cops think you're one of them (or their grandparents.
