Ford Crown Victoria/Mercury Grand Marquis: Audio
This car is our daily driver and we don't really want to spend a lot of money upgrading it. However we would like to change our cassette radio for a CD player/stacker. One local dealer offered us a 6-disc in dash changer but being from a later model it did not fit into the slot. Can anyone please advise us where to look for a player or a stacker for that year or possibly share your experiences of upgrading to one.
Many thanks! :confuse:
The best you will be able to do is get a single CD player, but you will loose the cassette player in doing so. Look for a radio that is DIN 1.5 sized.
Look for the link on their page that says: "What fits my car?" and follow the prompts.
I guess if you don't listen to AM radio, probably not a big deal.
The radio doesn't hold onto a station for more than 10- 20 minutes on FM-1, FM-2, or AM settings. I tried the scanning control, but it just keeps scanning thru all the channel numbers, never locks on to any station.
Don't want to take it to a dealer at $70 hr to find problem.
Is it the radio, electrical, or rear window antenna? If the radio, is it easy to replace? Any estimates on cost? What will fit?
Good Luck.
An antenna whether "power" or manual is just the receiving agent for the transmitter's signal.
If interested in receiving FM stations, the antenna should be extended only the length of the FM wavelength or about 30.5 inches. If interested in AM, squirt some liquid Viagra on it.
Im finding that Ill probably be better off buying a changer from a reputable shop. I talked to my local audio wizards and they said that the connectors mite not be compatible from model to model (yr.). You always get what you pay for when you guess at something like this. I'll take good councel this time.
I have a 2000 Grand Marquis, and I got an aftermarket CD player from Crutchfield. It came with a dash kit and wiring harness, which I connected.
The cd player works and everything, but now the Climate Control doesn't turn on. I'm pretty sure I just missed a wire (there were a few that didn't have mates when I was connecting the wiring harness). I hope I didn't damage my system somehow!
Any help concerning the wiring would be appreciated!
Is less bass normal with the Audiophile radio without a subwoofer installed? Or do I have a defective radio?
Also, what would be a good choice of rear speakers to install? Looking for something in the $50 range.
Thank you, Tom
If your in dash radio has a cross over network, the subwoofer will be fed the correct frequencies, otherwise the factory bass control on the four speakers should be set "Flat", not attenuated.
Do you now have a "Premium" set of speakers from the factory or just a Good set? If just a good set, plan on spending more than $50 and listen to some mj quart speakers.
I have the stock speakers and not the premium that comes with the audiophile system. I agree, I don't think the subwoofer will improve the bass in the other speakers either. What I need to know, is the normal with the audiophile radio to have less bass or do I have a defective radio. I wont be able to "qualify" the radio until I install the OEM subwoofer.
It appears that the single CD radio does have the subwoofer connector. I will try it with the sub and see what it sounds like. I will take a look at the speakers you mentioned
Depending on the antenna design, sometime, there is little reception degradation except directionality (more sensitive in one direction vs. others). Sometime, they screw up big time and as a result, the radio reception is very bad.
The whip antenna is still the best antenna for radio reception. However, it projects the low tech image and causes wind noise.
So test drive that vehicle and compare with you reference one. Sometime, if the glass antenna is good enough, the new radio with better technology could compensate for the overall system and you may like the new system better.
jt
on am/fm1 and fm2 i hear volume but no reception
