Oldsmobile Intrigue Audio
 dirkwork
                    Member Posts: 210
dirkwork
                    Member Posts: 210
                    Has anyone upgraded the radio headunit or the speakers on a BOSE option sound system in their Intrigue?  Crutchfield didn't have a clue about the Bose systems but said that some cars with Bose have amps on each speaker and such the entire mess must be replaced to upgrade.  I was curious if someone had been down that road before.
Spoke to cardomain again and they now tell me I need GM05 harness which looks like it would fit bigger connector but still has only that single connector.
Thanks, Mark
I want to enrich the overall sound of my 380 SL, I have a CD player installed and originals speakers. Consider I drive with top down most of the time.
Can I just change the speakers, add other 2 on the doors and a Subwoofer maybe?
Not idea, budget about $350
Thank you for any advise.
Rick
What are the fragile things to watch for?
I would like to be be able to re-attatch cleanly when I'm done with the install. I'll also be putting in a new head unit, amp, f&r speakers.
What is the best way to run the power and ground to the amp?
