Volkswagen Cabrio Electrical Problems
in Volkswagen
Please let me know if any of you can help me diagnose my problem with my 98 Cabrio GLS. Occasionally at night when my headlights are on, the ABS and Brake lights will come on. Because this is only slightly annoying, I ignored it for a while until something extraordinary happened. When the ABS/Brake lights come on, the headlights TURN OFF for a few seconds, then come back on.
This is VERY SCARY on the road! It only happens when the lights are on, though. Anyone else had this happen? What do you think could be done to fix it?
THANKS!
THANKS!
If I turn the car off and restart it, or turn the key one more click to the right, all symptoms disappear. My vehicle has no codes at the dealership and they don't know what would cause this.
When I start the car, the brake light stays on, as does the ABS warning light. Headlights, AC and wipers won't work but if I flash my brights, everything turns on. Also, if I turn on the wipers and headlights and then start the car in succession three times, the will turn on and then fail after about 3 minutes.
Sound familiar? Have you found any solutions? I honestly have no money to spend on this and I'm hoping it's just a new set of fuses.
Any ideas you could share? I'd be very appreciative.
Please email me at noah.bardach@philips.com
Please advise. Thanks! Noah
The third time though, though it was raining, Jade was park. she just wouldnt start. I popped the hood and bingo, my engine is wet. I am not sure how this happened, but i know, my engine get wet, Jade sputters the water out for a good 30mins-1 hour & 30mins then she back running as if all was dandy. SO if you find out whats the problem. please let me know...its scary
Does anyone know how to get the top up manually when the power roof stops working?
Just looking ahead to the next rain storm when, no dought, this will happen.
Marti
Have you had any input on your problem? We took the car by the VW dealership right after we bought it, and they checked it over and replaced a tail light bulb and charged us $110! I am a little reluctant to take it back to the dealership unless I absolutely have to!
any help or sugestions? thanks
Lanny
cusco1959@yahoo.com
I have had the battery load tested, it passed. I put a volt meter inline with the battery and saw 12 volts, which means there's Something, Somewhere, completing the circuit...Pulled the fuses one at a time, and disconnected the alternator, no change....Which now leads me to believe the problem may be something that is live all the time like the computer or anti theft system.......Anyone know if the alarm is integral to the computer system? :confuse:
Finally took it in. Mechanic said my starter and ignition coil were bad. Had both parts changed for $850, see below plus $100 worth of tune up type services.
ENGINE WON'T CRANK AT TIMES $0.00
Labor - 151 CHECK FOR DRAW ON BATTERY $0.00
Labor - 500 TEST BATT, ALT, STARTER $45.00
Labor - 619 COMPUTERIZED ENGINE DIAGNOSTIC TEST $95.00
Labor - 625 REPLACE IGNITION COIL $72.30
Parts 1 OEM PART DIS STARTER 17415 $266.93
Labor - 516 RPLS STARTER $153.63
Labor - 630 REPAIR VACUUM LEAK & HOSES TO SECONDARY AIR VALVE $45.19
Labor - CC COURTESY CREDIT $-45.00
Parts 1 OEM PART 6N0905104 IGN COIL $211.73
Car starts and runs great now. I am so happy as it took me a few months before I brought it in for repair as I frankly do not trust mechanics. I realized during this time how much I love this car during the period it was not starting well as in the back of my mind I considered an alternate car and could not come up with one. Hope this solution to my intermittent car not starting helps someone else.
ble that they are grounding out.
Any thoughts?
'97 Cabrio
Intermittent issue - solved temporarily by turning the car off and on. The one turn signal is also blinking rapidly.
Might it be a problem with the sensor that detects when the brake is released? But then the blower shutting off - seems unrelated.
