Caravan/Voyager Suspension
2»
  • safecyclesafecycle Member Posts: 9
    Thanks for your suggetsion to check the bearings at the top of the strut. My mechanic actually checked the top of struts first. He claims they are good. He says the noise is coming from a much lower point, perhaps from under the floor board. Any other idea? Thanks.
  • vchengvcheng Member Posts: 1,284
    The sway bar links are another possibbility that is a well-known problem point in these vans. They are relatively cheap and easy to replace too.
    If that doesn't fix it, I would suggest better troubleshooting rather than throwing parts at the problem. It may be well worth the cost to go to a dealer with a diagnostic machine called "computer ears" amongst other names. Basically they put wireless microphones on various components to pinpoint eactly the source of a noise or vibration.
    As an alternative, your mechanic will need to check ALL front components including tie bar and lower ball joints etc. Good Luck!
  • chuckgchuckg Member Posts: 69
    A good mechanic will put your vehicle up on a lift and start pulling and pushing on the suspension and other parts looking for that noise. A good mechanic will find it.
    Also, some of these replacement sway bar links have grease fittings in them. Do yours? It could be as simple as getting that van lubed.
  • mfahey1mfahey1 Member Posts: 419
    We had the links replaced late last year on our 2001 and the replacements are clunking again. I had it done at an independent mechanic so I don't know if he used OEM or aftermarket but 12,000 miles is pretty poor life in my opinion.
  • ntbillntbill Member Posts: 20
    I had a knocking sound even over small bumps. I had my sway bar bushings replaced at dealership and the noise was gone, this was at 18K miles. The right one had 1/4 left, and the left one had 1/2 left. They were in bad shape. Price = 0$ under warranty. The problem began on september, but the noise was just beginning, so I waited for my next oil change which was at 30K Km (around 18K miles). I can tell you that the noise was more frequent, and that I can ear it over small bumps too. A repair was welcome.
  • masterpaul1masterpaul1 Member Posts: 421
    Can somebody tell me how easy it is to replace the front links and bushings? I would like step by step instructions and if any special tools are needed. The dealer want's around $400 to fix. I believe this is something that I can repair on my own. Our van has 81K now. This is the second time replacing these parts. Thanks :)
  • new_to_dodgenew_to_dodge Member Posts: 2
    I was wondering if anyone has experienced a vibration coming from I believe to be the front end. I seem to only fell it when making right turns. So far, it is intermittent, but I can't pin point exactly what would cause this.
    I just had the sway bar links and bushings done due to knocking in the front end which made the van quiet, but still get this vibration.
    The van is a 2005 Grand Caravan SE with 72000 kilometers or about 45000 miles.
    Thanks for any advice.
  • windycity5windycity5 Member Posts: 1
    I have 2002 dodge Caravan, and am getting the shaking, has anyone helped you by answering the question.
    thx
    windy city5
    Windy City5,
    I was messing around with the van the other day and found a couple loose lug nuts on the front wheels. Not loose enough to fall off or anything, but I guess enough to give me that vibration. I tighened them up (especially the locking wheel nuts - they were the worst) and so far so good.
    I haven't felt it since, and I have been trying to duplicate it by taking sharp corners and accelerating harder through the corners.
    Hope that helps.
  • iyariyar Member Posts: 1
    I am here in the northwest of canada and am extremely frustrated.
    My dodge caravan is a 1994 with a 3.3 engine with overdrive and over 175,000 miles.
    I noticed a couple of months back that the right passenger wheel seemed to start to shimmy at about 30 - 35 mph and then would disappear as I speeded up.
    I drive the highway daily in mountainous terrain and am becoming more concerned with this issue as the condition is worsening.
    I have been to several garages and get so many opinions.
    I have installed 4 brand new tires and no change. I have had the uv shaft replaced and still no change.
    The garage then referred me to a transmission shop as the mechanic noticed a drip from the transmission.
    I went to that shop and he said that it would be 600 - 700 dollars to take apart the transmission to see if there is a cracked torque converter, pump problem etc. that is causing the drip; however no guarantee that it will fix this "shimmy".
    I went home and phoned BCAA who I have been a member of since 1962 and they referred me to another garage as they said that they only do visual checks and that this matter needed a drive by a mechanic with me to advise of the problem.
    I drove with the mechanic and he noted that the "steering wheel" had no vibration but both he and I felt the shimmy in the seat.
    I asked what that could be and he said something in the back although the shimmy is in the front passenger wheel area.
    No one will offer to put the van on the rack and inspect any area and suggest what the cost of an hours examination would be.
    I am totally frustrated and want to get the issue repaired as i don't like highway driving in the mountains with such a problem exacerbating. especially as the highway is known for bad accidents. it is the sea to sky highway in vancouver bc where the Olympics will be in 2010.
    Has anyone experienced such a problem as I really want to go into a shop and have another test drive and see what the mechanic says and be able to have an intelligent discussion and get the mechanic to do an hours work to research the problem and then go from there.
    BCAA said that the transmission drip is highly unlikely to be the culprit of such a problem.
    I really would appreciate any and all suggestions. i don't want to take it into a garage and say here find the problem and get a 7 hr bill with an inspection and no resolution to the shimmy.
    Thankyou. BTW, I would appreciate ball park areas of cost to fix this problem if anyone has ideas, thankyou again.
  • wcskjbwcskjb Member Posts: 10
    My 96 GC with 130K rides OK in around-town driving, but at highway speeds the front right starts to shake like I'm driving over rumble strips. Lasts for about 5 seconds and stops.
    Suggestions?
  • gmac5gmac5 Member Posts: 1
    You can get rebuilt steering rack for under $200.00
  • chdabrenchdabren Member Posts: 16
    I don't know if this information will help you, seeing as how u had this concern back in January, but .....did anyone bother to check to see if you had any excessive brake rotor runout? did they check your tie rods (outer and inner)? Did anyone check your rims to see if they were bent? How about too much runout in your front hubs? You mentioned you got new tires so I really doubt the problem is in your tires. You can however, have a bad rim. You say the vibration goes away the faster you go. This is because of centrifugal force. Newton's law. I'd have the entire suspension looked at...CLOSELY....and have the brake rotors measured for runout as well as the front hubs. Also, have the rear suspension looked at for a possible bent traction (panhard) bar. Good luck if you haven't had it fixed yet.
  • mattdurmmattdurm Member Posts: 2
    I caught your reply researching the same problem in my '03 GC SE. I have had vibration since putting new tires on this summer and just had rebalance for 2nd time and still have vibration. The vibration is noticable at about 40mph and then gets worse at 60mph. It is obviously not the tires and I do have a damaged rim. Mechanic said rim was not the problem and when I described it to him he thought it was something in front end. No. It is definetly in the rear and shakes pretty good. I have drums in the rear that need serviced. Could the drum brakes cause some kind of vibration? My kids will be disappointed if I can get it fixed because they won't be able to play the "uhhhhhhhhhhhh--h-h-h-h-h-h-h-h-h-h" game anymore. I can live without it. Thanks for any advice.
  • phxmotorphxmotor Member Posts: 9
    This is true for all front wheel drive cars:
    At this milage it is very likely the wheel bearing. A shop loves this because it turns out very costly UNLESS you do this: Replace the entire "spindle"* with one from a decent wrecking yard. It is a lot smarter than having a new bearing pressed into the old spindle.
    * The "spindle" is the big heavy steel piece the driveshaft passes thru... it also has the shock-strut bolted to the top of it... it also has the suspension bolted to the bottom of it... it also has the steering "tie-rod" bolted to the side of it... believe it or not: replacing it is no big deal... 1-2 hrs max.
    How to tell if yours is worn out? Raise the offending wheel like you are going to change the tire... grab the top of the tire and pull and push... is there any "play" at all?
    There shouldn't be. (maybe a tiny tiny bit) But a bad wheel bearing also makes noise when it is off the ground and is being spun anround w/ the transmission in neutral. A good one makes almost no sound.
    I do this all the time w/ vehicles w/ this amount of miles... and I always get another 10 years of use.
    Don't start replacing a lot of things just because the shop says: "we're in there anyway". When you need a new bearing, a used spindle is the way to go.
    They all wear out at about this many miles... it's normal.
  • harpitectharpitect Member Posts: 4
    It's over a year since you posted this question, but the problem is common, so information will help others.
    I just had this work done on my '01 GC. Cost of the sway bar links and bushings, done at a tire store, was about $235. That's a lot less than the dealer quoted you. :)
    John
    Yikes, $235 for swaybar bushings? Geez, I just replaced the bushings on our 2003 DGC ES with the blue NAPA bushings, which only cost $11. I crawled underneath, four bolts on one side, two on the other and the job was done. I cannot believe that your mechanic charged you over $200 for labor for such an easy job. :confuse:
    Best Regards,
    Shipo
    I haven't fixed it yet. From what I remember, all the parts I need cost around $175 from the dealer. The clunking is not that bad right now, and has not gotten any worse since a year ago. Anybody know of better parts to replace them with, then what the dealer sales? ;)
    Hmmm, $175 for parts.
    The MSRP price for the OEM swaybar bushings is $4.95 per side, so $9.90. Okay, I guess that means that they did the swaybar end links as well (sometimes necessary, sometimes not), and they have an MSRP of $43.00 per side (for the OEM parts), so another $86.00. That brings our running total to $95.90, still a far cry from $175. I'm really trying to figure out what else they could have done to your van to bring the total up another $79.10.
    Any ideas?
    Best Regards,
    Shipo
  • dave42nydave42ny Member Posts: 9
    I also just had the sway bar bushings replaced on my 2001 Dodge GC SE last week. I paid $100 - which included parts and labor. (Not from the dealer)
    Have a Happy and Healthy Holiday Season.
    Dave
  • 727727 Member Posts: 9
    Hey :o)
    I'm new here. Just stumbled over this site. Looks good.
    I own a GV 3,3 -93 and have that annoying problem.Changed just about
    everything in my front suspension.. with no result. The one thing i didn't replace
    yet is the swaybar bushings. I'll try it, thanks. Maybe the cheapest spare ever
    can solve the problem.
    Best regards
    727 Denmark
    At the risk of being a complete fool.. is stabilizer bar and swaybar the same thing??
    I'm trying to order new bushings to get rid of this problem.
    Everyone here mentions swaybar, and my Haynes manual doesn't use that term at all in the front suspension.It uses the expression: stabilizer bar. I'm confused.
    Hope someone is able to help ;o)
    Best regards, 727 Denmark
  • xwesxxwesx Member Posts: 18,100
    Well, now I am at risk of being a complete fool, but since I am used to that, I will go out on a limb and say that yes, they are the same thing. At least, I have always interpreted them interchangeably.
    Although, I generally hear the term "stabilizer bar" used in conjunction with performance modifications wherein someone will install a strut tower stabilizer bar. Both those and the commonly used sway bars serve to reduce the body roll (and thus "stabilize") of the vehicle.
    Probably the same thing. Where does the Haynes manual say the "stabilizer bar" is located?
    Best Regards,
    Shipo
    Thank you very much :o)
    Hey, this place is cool.. ;o)
    Best regards. 727
    Front suspension.
    A curved.. bar.. stretching from one wheel to the other.
    Thank you ;o)
    Best regards, 727
    Yup, that's it. ;-)
    Best Regards,
    Shipo
    Thanks. you've been really helpful.
    Best regards
    727 ;)
  • muggelbergmuggelberg Member Posts: 19
    Does anyone have a general idea how long it takes to change the sway bar bushing on a 2001 caravan?? It was done at a local shop 3 years ago, prior to me taking ownership..I believe it cost my sister about 150.00 to do it. I'm going to try it myself as I have the garage and tools to do it.. I believe it's ten or so bolts to the frame pan and then the sway bar bolts....
    Bill
    I'm thinking that it took me less than an hour and a half to do both sides.
    Roll'er up on the ramps, crawl underneath, unbolt and move the servo unit under the left side swaybar bushing (three bolts IIRC), unbolt and remove both bushing covers, pull the old ones off, open up and slide the new ones on, replace the covers and the servo and you're done.
    Best Regards,
    Shipo
  • creepingdeathcreepingdeath Member Posts: 2
    :) Sorry for the long read....I just finished replacing both of my sway bar links and the sway bar bushings. I have a 1997 Plymouth Grand Voyager (3.0L) 181,000 miles. Driver-side link was broke. Popped out of ball joint. The link that was broken was difficult to replace because the fact it had become unattached from its ball joint. When I went to wrench off the bolts on the sway bar end, the torque flexed the sway bar. Had to jam a piece of wood in there to keep the sway bar from flexin. The passenger link was a little eaiser to remove, however, being it was the original link, I had to utilize a #40 torx head bit gripped with a vice grip, and a 18mm gear wrench. Not the best way to remove rusted bolts, but after a lot of cussing and elbow grease, both links were removed. The sway bar bushings were somewhat easy, however I first had to remove 9 - 11/32 bolts and one 18mm bolt....(whatever) that held on the cradle grate. Once removed, loosened the two bushing retainers and slipped off the old bushings, slipped on the new ones. (make sure to put them on the correct way) Then, making sure the sway bar is centered, I bolted on the new links, then tightned up the bushing retainers, reinstalled cradle grate. Done! Took me about 4 hours to finish. $130.00 in parts from the Dodge dealer, and about $300. in labor saved.
    Test drove and now the suspension and steering responce feel like new, not like navigating a boat.
    Note: PB Blaster is your friend, as well as leverage. ;)
  • srs_49srs_49 Member Posts: 1,394
    Ahhh yes, the joys of working on a car!
    Creepingdeath - you mentioned the tools and PB Blaster. How many beers were needed ;)
  • robbie19robbie19 Member Posts: 1
    So I come out of the house yesterday morning to a huge puddle under my van. My brother in law drives an hour to come look at it and it has a leak related to the power steering. He couldn't find it so we took it to a shop. Today they are telling me it might be a rack and pinion leak or something to do with the breather. Everything I have read states that it could be $700 - 900 just to fix it. I only paid 700 for it 1.5 yrs ago and already 200 in repairs. It has 249K on it. Is it even worth it to fix it? Should I fix it and then turn around and sell it? Any advice, feedback or ideas?
    I don't have a lot of money and will have to take a loan to fix it if its that much. However, without it I have no way to get around and I am a full time student at the university currently missing my second day of classes.
  • sattysatty Member Posts: 6
    I have a 2002 Dodge Grand Caravan that has a slight front end vibration that cannot be found but is tearing through tires. HELP! I have replaced the struts, sway bar bushings and end links, tie rods and most recently the entire rack. The van has 122k on it and has been great up till now and it is just one thing after another with the front end. I recently took the van in as the front left (drivers) tire was wearing out very quickly and I had noticed a slight vibration in the front end. I was told the rack was bad causing the vibration and the tire wear problem. After spending $1300.00 on repairs and two front tires the vibration is still there and I am now wearing out the new left tire. Dodge cannot find the problem and says everything looks and appears to be in good condition and again has no answer for the vibration and tire wear. The alignment has been re-done 4 different times to no avail/ with solving the problem. The last dodge mechanic said there is a very slight vibration on the front drives side axel possibly causing the problem but again not sure. Of course they want another small fortune to tear into the van with no guarantee it will solve the problem. Please help
  • mctrimmctrim Member Posts: 1
    What kind of life should one expect from the sway bar and control arm bushings? 25K, 50K, 100K, for standard suburban roads and driving? My 05 GC has less then 40K and I replaced the sway bar links and bushings 2 years ago and now the control arm bushings are worn. Seems to me that someone needs to redesign a suspension, since I had a 92 GC that ran flawlessly to 150K before I had to do maintenance beyond oil changes and replacing mufflers, tires, and shocks. This 05 GC is not the 92!
    mct :mad:
  • snowdawg2snowdawg2 Member Posts: 1
    I Have a 1998 Plymouth G.V. and it has developed a shake in the rear at about 60-70 MPH below that it is fine.We have replaced tires rims brake drums shocks and drums.We have even gone so far as removeing the rear brakes and drums and it is still the same.Disconnecting the rear shocks causes the symtoms to occur at a lower speed indicating to me the problem is definately in the rear.The last thing we did was replace rear wheel bearings, same thing. It will keep vibrating at 60mph with the trans in neutral and the engine idleing,I am at the end of my rope.Is it possible panhard bar bolts and bushings could be causeing this?
