Ford Escape Mazda Tribute Maintenance and Repair
1666769717280
  • genome1genome1 Member Posts: 6
    Read my post 3530. The problem still has not been resolved thanks to Mazda Canada's intransigence. Despite a warning on Transport Canada's website re ABS problems - ABS can be too sensitive; if so, take the vehicle to your dealer - Mazda refuses to do anything until the dealer confirms that this INTERMITTENT problem exists; ie. they won't honour the cost of a rental car provision in my very expensive Mazda extended warranty, nor will the factory rep. meet with or talk to me!
    I will never purchase a Mazda vehicle again.
  • tb6471tb6471 Member Posts: 1
    I have the same problem with a 05 Tribute. Mazda has looked at it 4 times and can still not fix it.
  • rwnzorirwnzori Member Posts: 1
    I have almost the exact same problem with my 2005 Escape 4cyl stick shift. Didn't start until about 20K miles as well.
    The accelerator refuses to move almost everytime I shift and from stand still so either have to tap it multiple times or STOMP on it. And like you, after about 10 miles will work ok. Much worse now that its very cold weather.
    The dealer said 'they could not replicate problem' (the odometer also had the same mileage as whe I dropped it off so I doubt they tried very hard!!!) I"m still under warranty so I wonder if they are just being cheap.
    green escapist
  • yarekyarek Member Posts: 1
    Did you flush the trans or simply replace the fluid? Did this solve the problem?
  • brad54brad54 Member Posts: 5
    My key fob quit working. Would this be caused by a dead battery and if so how does one go about getting the key fob apart? Thanks
  • gussguss Member Posts: 1,167
    Try some light pressure with a screw driver inserted by the ring.
    If you need a new one try e-bay. They will have your model for under $15.
  • gangkougangkou Member Posts: 1
    I purchased a 2006 MAZDA TRIBUTE I on Dec 2006. It is a 4 DR., 2.3L L4 PFI DOHC 16V / 4 WHEEL DRIVE.
    I live at Nebraska and the temp in Jan and Feb 2007 is about -10F to 10F. The standard MPG is 21/24 for city/highway, however, my city/highway MPG is only about 14.x/16.x using #87 gas and current odometer reader is 2000 miles. Is it normal, especially for highway MPG, giving the speed for highway is constantly 75~80 mile/hour and continually driving for 3 hours? If it is not normal, is there anyone can give me some suggestions on how to fix it?
  • mario10mario10 Member Posts: 4
    I had the same problem. Follow the throttle cable under the hood to the throttle body intake (where the rubber air intake hose meets metal), unscrew the hose clamp, and separate the rubber intake hose from the throttle body. You will see the throttle plate that opens and closes when you pull on the cable or press on the accelerator. Mine was gummed up and I used carburetor cleaner on it. Nice and smooth again.
  • tminchew01tminchew01 Member Posts: 3
    I have a 2005 Mazda Tribute S with the 3.0 liter Duratec V6. I was checking my oil and fluids this afternoon and it seems I am low on Power Steering fluid. The manual says to only use MERCON ATF fluid. I am having trouble finding this. Can anyone tell me where to find it, or if there is a safe alternative to use without voiding the warranty? The engine has 18,990 miles on it. Any help would be great...thanks!
  • tveilleuxtveilleux Member Posts: 15
    Mercon is one of the common ATfs around. A quick check on the Internet shows Valvoline, Chevron, Exxon, Castrol, Havoline, Shell, Motorcraft and Penzoil all aupply it. It is often advertised in conjunction with the name Dexron III. Go to a Ford or Mazda dealership for the stuff, or any repair shop that does transmission work will have it. Your local parts store should carry it.
  • normkolnormkol Member Posts: 135
    Change the ignition cylinder. If you ask locksmiths who do alot of automotive, they will tell you the Focus and Escape/Tribute have a poorly designed ign. cylinder.
    There is a Strattec aftermartket cylinder that avoids the problems, and should work fine.
  • semagsemag Member Posts: 1
    Sorry if this is so old !
    But did you ever find the cause to your issue of the running lights blinking ?
    Paul
  • balejandre_00balejandre_00 Member Posts: 1
    I just wanted to know if the bumper for a Ford Escape will fit to a 2006 Mazda Tribute. I'm looking for the front and rear bumpers and for the trunk door. I just wanted to know if the parts will fit because I need to replace them and I found some cheap Ford Escape parts.
    Thanks for your help.
  • rg8729rg8729 Member Posts: 3
    I also had the same problem, I thought it was the key or the lock... in my case it was the steering wheel preventing me from removing my key. I just gave the wheel a slight turn and the key comes free.
  • rhiannon1rhiannon1 Member Posts: 6
    Hi! I just started experiencing the exact same problem a month ago on my 2003. It was intermittent but now it is happening at least once every day. Since it is intermittent my dealer won't do anything either! Apparently if the light doesn't come on and tell these yahoos exactly what is wrong with the vehicle they are incapable diagnosing anything. This is also not my first problem that they have refused to fix -- I had a stalling & failure to start problem but learned here at Edmunds what was causing that. Have you been able to find out what is wrong and get it repaired? I am afraid one day the brakes won't hold. This is not my first Mazda but since Ford bought the company and can't put together a safe vehicle, this is definitely the last!
    No luck. After 2 weeks with the dealer, during which one of the staff drove it home and back to work a few times, they could not duplicate the problem. A Transport Canada rep. also drove it and the problem didn't occur. I had no choice but to take the vehicle. The problem has recurred sporadically. I believe the ABS is too sensitive and it looks like I'm stuck with the problem. The other side of the coin: the ABS does behave properly on icy/rough roads; however, I hate it. I'd rather skid than plow into the back of another vehicle or slide into an intersection. This is my first and last Mazda!
    I took mine in to the dealer & they said the most likely cause was uneven tire wear so I bought new tires and had a front end alignment done and it has had no effect. The ABS still deploys for no apparent reason on dry pavement and low speeds. Last week I almost rear-ended someone because I couldn't stop. So I spent hundreds and still am no closer to getting this resolved. If anyone has any ideas I really can use some help. The warranty expires in 2 months and my dealer is in no hurry to solve any of the problems I have with this car.
  • bdymentbdyment Member Posts: 573
    Cleaned up the wheels on my 07 Limited 5400km. Noticed corrosion around the hubs/centre cap area. Dealer ordered three new rims. The driver's front seems okay, but I will keep watching it. Dealer will replace if it goes bad. This must be a bad batch of rims. Just one winter and not driven on a daily basis. Washed weekly.
  • explorerx4explorerx4 Member Posts: 21,304
    do you mean chipping around the center cap?
    Chipping and corrosion on the wheel rim around the cap.
  • ochinskiochinski Member Posts: 1
    Hi, what brand of struts & shocks did you uses on your truck?
    I have a 2001 tribute, it's ready for new struts & shocks.
    Thanks, Ochinski
    Finally the dealer listened!! My ABS has started to stay on while I am driving and not even going near the brake! I took it back to the dealer and they fianlly took a look at it & said the rings are cracked on both sides so it is not safe to drive. They are keeping the car --will be another week as they still need parts -- but are replacing the rings, drive axels and the bushings under the warranty. Don't let them drag their feet - everyone told me it was safe and now they are saying it is dangerous & not drivable!
  • jcgreenbergjcgreenberg Member Posts: 3
    Well, our '03 Escape just turned 27,000 miles and while the wife was driving it, it stopped. Bottom line, catastrophic transmission failure and $3,500! I have been surfing the internet and found that this is not the only Escape to have this problem! Now, Ford warranty on the Escape transmission is 5yr/60,000! But, as of right now, Ford will NOT STAND BEHIND THIS TRANSMISSION! I have not even reached the first transmission maintenance service at 30,000! The dealership even stated that our Escape shows no signs of abuse! Never been off road! So, has anyone else experienced transmission failures like this? Is it time for a class action suit??? Depending on what Ford will do for us, this may be our very last Ford Product! We were looking at the Escape Hybrid but as this repair will cost 1/3 of what we were offered trading our '03 Escape in for a '08 Escape Hybrid, I really don't know!
    If it's under warranty, why isn't Ford going to fix it or put a remanufactured transmission in? I don't understand why the repair is going to cost you $3,500.
  • scatanscatan Member Posts: 4
    I too am curioius why Ford is not standing behind the transmission. What reason did they give? Have you consulted with another dealership?
  • mschmalmschmal Member Posts: 1,757
    He is out of warranty on time.
    If you are looking at an Escape you absolutely WANT the trailor tow package. You get an upgraded transmission cooler which gives you benefits even if you never tow.
    Many of the preowned off lease Escapes will have this feature as it was part of the lease program focus vehicle.
    Mark.
    Consumer Reports may recomend that you NOT buy the Extended Service plan but try sending them your repair bill and see if they will pay it for you.
    That advice is like saying that if you are a healthy person and have good eating habits and no unhealthy habits then you should drop your health coverage as the chances are you will never get benefits equal to the premiums.
    Well, the post said the warranty was 5yr/60,000 so I took that at face value. Time indeed has run out. Maybe Ford and the dealer will meet him halfway or something.
    Please keep in mind that if you are making lots of short trips or spend time ideling in traffic, then you should be following the severe duty maintenance schedule in the maintenance guide.
    Most wear for an engine occurs at startup when the oil is in the oil pan, not up in the block. Also short trips mean that the engine does not fully heat up enough to burn off acids that collect in the oil. This ages the oil much faster.
    Thats why its 5,000 miles or 6 months for Ford on oil changes UNDER NORMAL CONDITIONS!
    That being said, the trans failed at 27,000 miles on a 4 year old car. That person should have done the 30,000 mile service almost a year ago based on elapsed time no matter what the miles said.
    Mark.
  • larrygjaxlarrygjax Member Posts: 1
    I know your message is really old....and I didn't see anyone offer any help but my 2002 Escape just did the exact same thing....I'm stuck in park and the shifter will move but never actually change into D, R, N but the box around the P goes away when I try to move into any other gear....what caused this problem and how bad was it (cost and time) to fix it? Thanks for any help.
  • dilyhidilyhi Member Posts: 2
    The transmission just went out on my '06 Escape at 12,500 miles. Fortunately it is still under warranty, but now am wondering if this is a common problem. We were thinking of trading it for an '08, not so sure if that is a good idea anymore.
    No. This is not a common problem at all. Sounds like a fluke. I wouldn't hesitate to purchase a 2008.
    Thanks that is good know. We are picking it up today and are going to look at the'08 on Saturday.
  • flaereflaere Member Posts: 3
    Just wondering whether you've been able to fix your problem? We have a 2003 Mazda Tribute 4 cylinder, 5 speed manual transmission and have had issues with the vehicle not starting (especially in hot weather). After driving it for an hour or so, if we stop to get gas or pick up groceries, when we go to start the car, it does nothing. It takes nearly an hour for it to start up again. We've taken into Mazda a half a dozen times and they haven't been able to duplicate the problem. We've had the fuel pump and relay(s) replaced ... had the keys reprogrammed ... but to date ... nothing has resolved the issue. Any one else experiencing this problem?
    Did you ever find the solution to the problem? We have a similar problem with our 2003 Mazda Tribute?
  • jrosasmcjrosasmc Member Posts: 1,711
    My mom owns an '02 Escape XLT AWD that has 52,300 miles on it. Since she purchased the vehicle last year at 31k, there has been a persistent shuddering or grinding noise in the transmission whenever it is downshifting from 4th to 3rd on any type of incline. I've driven the Escape many times and what happens is this: If I go up a small or steep hill and the tranny has to downshift (which it does almost constantly), I hear a grinding/shaking noise coming from the tranny at speeds between 35-45 and 55-65 mph. They've had the fluid flushed and changed twice, at 35k and 50k, but the noise persists. What do you think it is- the torque converter or the solenoid?
    Just one more question as well: Does the Escape use the same troublesome 4-speed unit that the Windstar minivan used? I know that tranny gave many Windstar (and Taurus) owners a lot of headaches.
    If you are looking for an Escape, insist on the towing package. The tow package includes a greatly upgraded transmission oil cooler. The one flaw of the Escape trans is that it was always prone to overheating in early model years of its use (1994 Mazda 626). Although this problem was supposedly fixed, its worth it to get the best cooling possible with the towing package.
  • rossco3rossco3 Member Posts: 2
    HAVE YOU FIXED THE PROBLEM? I have the same vehicle (2001).
    It starts fine, but if it's hot out it will die after driving for awhile. Then to keep it running I have to hold the gas pedal down all the time in order to keep driving, or it will die again. Not easy to do with a clutch. I would like to fix myself rather than have the dealer try, and not be able to duplicate the problem.
    Can anyone help me?
    2001 4cyl. 5 spd. It starts fine, but if it's hot out it will die after driving for awhile. Then to keep it running I have to hold the gas pedal down all the time in order to keep driving, or it will die again. Not easy to do with a clutch. I would like to fix myself rather than have the dealer try, and not be able to duplicate the problem.
    Can anyone help me?
    No, not yet ... but will let you know if we're successful.
  • troy_mcluretroy_mclure Member Posts: 2
    I have a 2002 tribute that is also dying on hot days. Please let me know if you figure it out. The mechanics have no idea.
  • raulobandoraulobando Member Posts: 1
    I have a serious problem with the moonroof of my it tribute 2005 and it is that I had stopped a lot of time the vehicle and the moon roof I am not well closed, leaving a space for where entrance a lot of garbage that stride and damage the support and the guides of the glass of the moonroof and now ask to the dealer and them alone they sell the whole kit and that the parts that I need don't have P/N. Will it be that somebody can help me saying I eat up I can get those parts? Thank you Raúl Obando (raul_obando@hotmail.com)
  • scoutguyscoutguy Member Posts: 3
    Has anyone found a way to solve the tailgate problem of not opening?
  • desertrat2desertrat2 Member Posts: 3
    I have a 2003 Mazda Tribute and live in the Palm Springs area. Each of the last four summers and on an extremely hot day (in excess of 110F), the car has shown an electrical problem - indicator lights start flashing, radio becomes intermittent, etc. When the engine is turned off, it will not restart without a jump. When taken to the dealer, the first time, I was told it was the battery and it was replaced. The second time, I was told that there was nothing wrong, but after fighting with the dealer, the battery was replaced again. Last year, they finally determined that it was the alternator and replaced it while still under warranty. Now again, on year later, I'm having the same issue. Any suggestions as to what could be causing this to occur?
  • funokafunoka Member Posts: 13
    I have had no electrical problems, with my 2001 Tribute, but they replaced the computer chip twice under warranty in 2002. Did they check that, or do they think it is purely electrical?
    I've had no issues with my Trib since, until this weekend. It didn't want to start after an hour and a half drive and then sitting for two days. I was parked on an incline, and it was like it wasn't gettting enough gas -- the engine turned over. After getting it started after five attempts, all is fine now. Has anyone else had this problem?
  • erinnzoomserinnzooms Member Posts: 4
    I was wondering if anyone knew of a reputable/low cost source for rear bumpers for the Tribute. JCWhitney only has front bumpers. It's not a necessity, but I may want to replace it soon for aesthetics.
    Erinn
  • othelloothello Member Posts: 2
    "But I also notice quite of bit of engine vibration coming through the accelerator pedal, mostly under heavy engine load such as right before the upshift while passing on the highway, though I'm not sure if it's typical for this type of vehicle as I have been driving a silky smooth Contour V6 for the last 5 years. I am a little worried that there is a loose or broken engine mount or other drivetrain component that is causing the vibration and that it will be very hard to trace by the dealer." - Kam327, July 05, 2005
    I didn't see very much response to this. I own an new '08 Escape (less than 700 miles on it right now)in which I notice vibration coming through the gas pedal. I agree that this is not a good thing - a loose or broken motor mount could fail disasterously. There is also a growling noise that shows up at light throttle (almost coasting) at any speed.
    I took it to the dealer with these complaints. The response was that there were no "unusual" vibrations or noises.
    The noise is difficult to repeat, but the pedal vibration is obvious, altho' not violent. How much gas pedal vibration is acceptable in a brand new vehicle?
    Have any other Escape owners (any model year) noticed undue vibration in the gas pedal?
    Note: 08 XLT V6 AWD 4spd Auto no extra packages.
    For everyone with starting issues (cranking but no turnover) on older autos try replacing the IAC valve (Idle Air Control). Inexpensive and easy to do (top mounted).
    Is the vibration short-lived or continous?
    There is a fairly common problem with transmision shudder that lasts for less than a second upon accelaration/shifting that is solved with changing/flushing the fluid. I am used to older cars that had longer change intervals and thus had the problem for a while before I read this and other forums that suggested this solution. With a new vehicle it may be either low fluid level or something else.
    I had the same problem. The dealership mechanic wanted to keep the car for a week to duplicate the problem and then wanted to start replacing parts one at a time until they found the bad one. I checked on a mazda forum (http://www.mazdaforum.com/archive/threads/2003-mazda-tribute-26234-1.html)
    which recommended changing the IAC valve right on top. It was $65 on mazdapartsonline.com and easy to replace (two screws right on top of the engine). It's been 3 weeks and hot out, and the car starts up fine every time.
