Volvo C70 Homelink
"it took a little playing around to get the Homelink set up right with our garage door opener. The actual process was not quite like the manual. We trained the Homelink button to mimic an existing opener, but then had to also train the actual garage main motor unit to "recognize" the Homelink button. (Two step process, not quite like what the C70 owner's manual said.) "
I have a problem getting my HomeLink to work. What did you do to the main motor unit? I'm sure I don't have that manual sitting around now. It's been awhile.
Here's what I did.
1. followed procedure in manual for erasing all prior codes from the Homelink. If you can't find your manual, you might want to look in the Owners section of www.volvocars.com (for your country), for the on-line manual. In any case, the erase all step is:
Programming the transceiver for the first time (U.S. residents)
1. For first time training, press and hold the two outer HomeLink buttons, releasing only when the HomeLink indicator light begins to flash after 20 seconds. (Do not perform this step when training the additional HomeLink buttons.)
2. Then, you train Homelink to match an existing transmitter by:
Position the hand-held transmitter 1-3 inches away from the HomeLink surface. Using both hands, simultaneously press and hold both the desired HomeLink button and hand held transmitter button. DO NOT release until the HomeLink indicator light flashes slowly and then rapidly. (This took a long time - maybe longer than 30 seconds.) When the indicator light flashes rapidly, both buttons may be released. (The rapid flashing indicates successful training.)
But this still didn't do it in my case. I then needed to follow my garage opener's instructions for training the opener to a new remote. With my brand of opener, this consisted of pressing a button on the back of the opener (one press), and then, within 30 seconds, pressing the Homelink button.
In short, first get the Homelink trained to mimic your existing transmitter, then go through your opener's training process to get the opener/motor unit to recognize the Homelink button.
If this doesn't work, then try to "rolling code" "cycling" procedure that is also described in the Volvo manual.
Sorry - I misread your earlier e-mail. My Sears garage door opener sounds different than yours. Mine has a single green button (square shape) on the back of the unit. The instructions for the opener are actually printed on a small label next to the green button.
