Hyundai Azera Climate Control
What, exactly, is being controled when you select "auto"? The usability guy in me thinks that the appropriate lights ought to come on when auto takes over, e.g., if the a/c is running then the a/c light ought to be on. Yet when I turn on auto none of the other lights come on. Indeed, if I touch any button except the air filter (the "A" button) then auto shuts off.
Another question - how do I determine the temperature inside the car?
Another question - how do I set the fan speed higher when I have the vents open (or recirculating air) but the a/c off?
As to the inside temp in the car, on the Azera, there is a small slot in the center dash that "reads" the temperature. It doesn't display the temp on the panel, but that is how the Auto setting starts to increase/decrease cooling or heating to match the settings.
Boy, lot of words to try explaining a simple thing. Hope that helps
My dealer tried to explained how to get uncooled air but got confused by the controls and ended up suggesting to set the temperature control high enough to be sure the air conditioner is not working. He would not admit that the control was defective.
Can you (or someone else) can tel me if we can get uncooled air when turning on the fan? Thanks
After hitting the AC switch twice, you can also manually adjust the fan and the head-foot-both switches and recirc./fresh air, all w/o AC. To get all back to normal, hit the "AUTO" switch...
I guess Hyundai needs to make this unit control more intuitive.
I think a lot of the technology is all coming from the same copanies regardless of make and whoever writes the manuals and explains it to dealers never gets all the information.
That is what is so great about these websites.
That's why it's called automatic climate control :=)
Still getting used to our new 07 Azera. The climate control section in the manual is not very clear. Can someone explain the difference between the 2 buttons which are identified: Air Quality Control System and Air Intake Control Switch? The description in the manual sound like each do the same thing. Is there a default setting for these? I notice that if either button is lit when the vehicle is on it does not stay lit when I restart the vehicle.
Do the setting of these affect in any way the cabin filter which must be periodically replaced? Any other hints regarding the climate control system would be appreciated. Thanks!
Steve
Forgot to add another question in recent post. This regards the climate control with the bi-level setting. The manual states that this can be set so cooler air could be sent through the dashboard vents and warmer air through the floor vents at the SAME time. I can't figure out how to do this. Is it possible or is there a mistake in the manual?
Thanks again!
Steve
And if AQ or you decide to run the cabin on recirculate most of the time, it would tend to extend the life of the filter as less outside air (bugs, dust, whatever) would be passed through the filter. All air which enters the cabin passes through the filter, but if you don't smoke in the car and keep the theoretically dirtier air outside by using Recirc., there would be less crud to be filtered (but the cabin might get a bit stuffy).
The bi-level vents (warmer low, cooler upper) are likely processor controlled according to the requested temp. setting you choose and according to the humidity inside the car, where, in Winter, you might want warmer feet, but the cabin humidity might occasionally call for some air conditioned air to take the fog off the windows. Don't know of any operator controls that would let you vary the top/bottom temps, in a like manner to the driver/passenger temp. controls...
Thanks for the prompt and thorough response. Makes more sense now.
Steve
