Nitrogen in the tires
I asked the dealer if I could put air in the nitrogen filled tires that came OEM. He said no problem, has anyone else put air in nitrogen filled tires. I guess mixing air and nitrogen is ok?
SUVs and Smart Shopper
Nitrogen: A Noble Gas?
As I expected, I'm not really seeing any improvement in mileage since I tend to take care and monitor to the pressure in my tires on a regular basis. But I have observed that my tire pressure have been more consistent and the tires have maintained pressure longer with the nitrogen.
So for someone who sort of neglects their tire pressures, I'd imagine that they'd see less of a dropoff in mileage and handling as their tires wouldn't get as low as fast.
Yes, planes do use nitrogen. They also take a heck of a beating and big aircraft travel thousands of feet in the air where it's minus outside, then land in Florida.
Race cars too.. at 220mph, you need it.
Jul 15, 2009 - Nitrogen Long Term Test (AlternateRoute)
(the compressor is behind the 99+ sign).
Had Goodrich tires installed on a Tundra in Dec also at Costco. The same story. These same two vehicles with OEM tires had to have air added at least a couple of times a year and sometimes a single tire more than that. The Tundra with the nitrogen still has same pressure as when originally filled. Now this may have something to do with the installation and the tires themselves, but I've ran hundreds of tires in my 42 years of driving and never had this kind of luck.
I haven't read any stories of the nitrogen filled tires not giving good results. Lots of people will say scientifically it doesn't make much difference but the proof to me is my experience. Most of them just read stuff and then tell everybody else they are crazy.
Thanks for your report. In my experience, ordinary air (79% N2) has always been completely reliable and I have seen no need for nitrogen. Any time I have had air pressure problems it was always due to damaged rims or faulty tires. N2 would have made no difference. And the science still holds.
I wonder if the nitrogen, because of it's molecule density, is less inclined to contract in cold temperatures. Usually when it's very cold tires need a little more air but mine stayed full all winter. This could all be a coincidence of new tires and a great seal/installation job but it sure is a pleasant experience.
Under "normal" conditions, nitrogen and oxygen molecules both behave pretty much as ideal gases so their density variation with temperature will be substantially the same.
The relevant factors are molecular size and molecular speed. Nitrogen molecules are larger than oxygen molecules (by about 6%) so they will be less likely to escape through a "hole" in a single encounter. On the other hand, nitrogen molecules travel a little faster than oxygen molecules for a given temperature (also about 6!) which gives them more frequent opportunities to escape. In the end, it should be pretty much a wash between the two molecules.
On the other hand, the air that you pump into your tires has some water content which is not present when you use pure nitrogen to fill your tires. Water vapor accounts for some of the pressure in your air-filled tires and it can leak out more quickly than either nitrogen or oxygen.
In any case, I'm glad you're happy with your new tires and your N2!
I live in AZ and my tire light is on and my tires are low...Can you add air to the nitrogen tires without damage. Any ideas, I am getting very ticked off...
I have had very good luck in Chicago area with two vehicles with nitrogen(nothing added for almost a year in both vehicles). Maybe the high temperature of AZ affect the nitrogen more. I wouldn't know about that but it is certainly ok to add regular air.
With plain old air, tires are subject to the same problems people are. Cold air will compress, and hot air will expand, but when you use nitrogen, the tires will remain at a much more even pressure as it's not nearly as temperature sensative.
If you have a green cap on your tire stems, use Nitro, as adding air also adds moisture and can affect tire life and performance.!
Just thought i'd toss in that info..
RocD
Nitrogen and oxygen (the primary components of air) are both small nonpolar molecules and should therefore each behave very much like ideal gases. I don't see that compressibility would be affected in any significant way by replacing 80% nitrogen with 100% nitrogen.
Any difference would possibly be more related to the water content of air versus that of nitrogen which effectively removes the moisture. In any case, the differences should be largely negligible for ordinary vehicles as opposed to race cars.
After taking possesion of vehicle, tires were 4psi underinflated.
There was a 50$ charge on vehicle price for that nitrogen.
As winter settled in, had to go back three time for top up.
This tells me you have to check tire press nitrogen or not.
In which case, air is more convenient because if you have a compressor there is no hassle:air is easier to get than nitrogen. I see that ntrogen fill by the dealer as a cash grab.
They also bank on the fact people for the most part never check their tires thinking its good enough to do it when vehicle is serviced.
The Sandman
I have been maintaining vehicles myself for years and either have become too fussy or aware of different aspects of auto maintenance that dealers and shops find me a thorn in the side. its bad enough trying to maintain relationship with dealers to maintain their so called warranty requirements.
These tires can use up to 350 psi - and the simplest and easiest way to fill a tire to those sorts of pressures is to have a cart with nitrogen bottles already hooked up. These bottles have over 2000 psi in them and when you connect them and put them in a cart with wheels, the cart can be wheeled whereever it is needed.
And when it is time to refill the bottles, the cart goes to the shop. No muss, no fuss!
