Truck wont start three out of four times trying to start it. GMC Sierra 1500.
I have this truck and it wont start. Ive contacted gm. Had my battery changed, starter changed. Still the same problem
What should i do
i also just changed my alternator, spark plugs.
have you had the fuel pump checked? On our truck, you can hear the fuel pump come on when you try to start it and it's working.
MODERATOR /ADMINISTRATOR
Review your vehicle
i can hear the fuel pump when i turn the truck to the on position.the pump does work. i had that changed too
How long has this been happening? We also had an issue with getting moisture in the gas tank that caused the vehicle not to start, and then for no good reason, it would just start.
Review your vehicle
it just started this winter about november. but once it starts it will start up again. if it sits for like 3 hours, last time it did it, it wont start again
but it sometimes will start on the first try
oh one more thing. the last time it did this it started on the second try, but when i put the key to the start position every thing died. then when i let the key go to on position it started. what caused this to happen. i know this is not supposed to happen
I wish I had more ideas for you. Unfortunately, I lack mechanical expertise and can only tell you what issues we have had, and I'm pretty much out of those. The only other issue we had was with an aftermarket stereo, and that did give us some electrical issues related to starting the vehicle.
Review your vehicle
I took it to someone to figure it out. I checked everything three times everything was okay. So someone will disect the truck and figure it out. Thanks for the help.
I did install an aftermarket stereo with dvd player. That could be the problem
i found out what was wrong. wiring and the starter. but its the third one
