1997 grand caravan camshaft sensor
                    Can some one please give me any info on the location of the camshaft sensor on a 1997 dodge grand caravan 3.0 se. My van just died while driving got it towed to the house run my tester on it code came up that it was a malfunctioning camshaft posistion sensor. so i got one order but know i am having a hard time finding it
Here's what it says from the AutoZone website:
Under hood, passenger side, upper engine area, between cylinder heads, mounted behind the power steering pump reservoir.
On my van, it only happens under acceleration right now, and I plan to nip it before it gets worse.
I strongly suspect this is in the suspension/steering of the van, but you could confirm that by checking your front tires for signs of uneven wear. If it is motor mounts or non-wheel related, it is not going to affect your tires. But, if you feel it in the steering wheel (i.e., it pulls the wheel left/right), as I do, it is definitely in the steering or suspension.
It took quite some time for me and a suspension specialist to pin point it to this problem, but a set of replacement rims got rid of the problem.
It sounds like you have checked and eliminated all other possible sources except this one as far as the noise goes.
On 97 Grand Caravan, we have changed the Gas pump 3 times, (the computer also, but changed back to the old one because it was not it.) the spark plugs and cables recently, all of the problems of misfiring, explosion like sounds, trembling or shimmy like problems as you push the gas and at about 55mph, Under 55mph in town it seems to work okay, similar to what Ireed70 and xwex commented on, the smell of gas once you shut off the vehicle and the misfiring was how it started. Once we changed the pump and the spark plugs it helped for 3 days and back to the same exact thing. Today is all of the above and now it's acting just like when you have a spark plug stripped out of threads, as you accelerate it gradually gets worst. No puff of smoke, or overheating so I don't believe is the seals on the engine block...Engine light is now on, but it scan inconclusive, no code comes up. Hope to hear of anyone who may have found a solution to these issues. I'm going to take it to an Auto Electrician Specialist as a last option.
