Jaguar XJ6 - Memory Seats not returning
I have a 1995 XJ and it is perfect except for one item. The memory seats will not return when 1 and 2 buttons are pushed. The mirrors and steering will come to memory but the seat will not. but on exit and Auto mode the seats will go back and release. But the seats will not come back. Does anyone have a simple answer for fixing? Thank you
work. If you can find replacements, they will probably cost you about $80-100 each.
The seat has to be removed to get at them.
Ronmay
Th
I have the same problem on my 97 jaguar xj6, can't lower the driver's window
and the electric seats don't work.
Were you able to get yours fixed? And could you tell me what was found to
cause the problem.
I did this ad everything works fine in my xj8 '98. Good luck.
replaced fuses,no help
