Why doesn't my radio/cd player not work?
lpd2495lpd2495 Member Posts: 1
edited April 2014 in Ford
I have a 2003 f150. The cd part of my radio/cd player stopped working. I took it out and have plugged in two used units but neither works. They don't even light the display as if it is not getting power.
Answers
  • Does the radio part work? Sounds like there may be a problem at the power connector and I'd guess that the radio doesn't function. I don't think the radio and CD have separate power connections.
    Almost has to be a problem with the connector or a cracked wire.
  • forddriver4forddriver4 Member Posts: 8
    I have found on some truck i worked on that there may be some wiring problems. And on others the radio part just stopped working. I know this is irrelevant but i have a radio in my house that is a five disc changer panasonic. It is about 5 years old. And the radio and tape player work but the cd part did not work. And i think it might also be wiring in the radio
