trans wont go in od
hrdallhrdall Member Posts: 1
edited May 2014 in Dodge
    Usually means you need a trans service (or if you just had one, it may not have been don e properly). If you have no other warning lights, a transmission will generally lock out OD if it can't get proper fluid pressure of if it's running too hot.
