Lincoln ls check engine light on code p2195
Hi, I have a 2006 Lincoln ls V8 that have the check engine codes p2195.the car idle very rough and it lose power and the engine is shaking while trackleing
Answers
Here is a video that will help show you. It is likely a vacumm leak. You may be able to get a 90 degree connector for about 5 bucks. Either way it should be an easy fix.
