Mud Bogging - 2014 Acura MDX AWD Long-Term Road Test
edited June 2014 in Acura
imageMud Bogging - 2014 Acura MDX AWD Long-Term Road Test
Traction Control? Who needs it? Slipping and sliding in a 2014 Acura MDX.
    SH-AWD is a very good AWD system
  • darthbimmerdarthbimmer Member Posts: 606
    You're not going very fast through the mud in that picture. If you were, the sprays would be 10' high and dropping mud on your roof. That's how you know who's a serious mudder when you pull up at the local gas station/minimart/bait shop.... It's the truck with mud on it's ROOF.
  • quadricyclequadricycle Member Posts: 827
    edited June 2014
    Actually, you'd be surprised at how clean things stay when you have tires that fit INSIDE the wheel wells.
  • 6sptl6sptl Member Posts: 27
    SHAWD is superior on any slick surface to any other system, in fact our MDX drives adroitly in situations that leave my 4wd FX4 F150 skidding around. The only issue with the system is that it has never been applied to an offroad capable vehicle and that it doesn't have a low range (for going downhill). As long as you drive on roads that are within the MDX modest clearences it will never get stuck, period.
