Air/heat control doesn't work. Buick Rendezvous.
I drove to work this morning and everything worked fine on the air conditioning. I got in my car after work and the area where the air conditioning and heat system is located it will not light up, nor will it work. Any suggestions?
First I would make sure the fan control is on (or set to be on anyway). Try hitting it (not hard) to see if there is bad connection Could be the HVAC cluster is bad, or maybe check fuses both inside cabin and engine compartment that deal with climate control
