Rear Climate System Works Well - 2014 Acura MDX AWD Long-Term Road Test
edited August 2014 in Acura
imageRear Climate System Works Well - 2014 Acura MDX AWD Long-Term Road Test
The latest sales numbers are in and the Acura MDX is now the best-selling, three-row SUV of all-time. After driving it for nearly a year we're not surprised.
    edited August 2014
    The MDX HVAC system is all new. Most SUVs use two evaporators and heater cores, front and rear. The MDX has a single front evaporator and heater core partitioned 65% front and 35% rear and a dedicated blower. Honda says this reduces the number of refrigerant lines, cost less weighs less and reduces leakage potential. Honda said the difficult part was figuring out how to angle the 40% larger evaporator to fit and still drain properly. The solution along with the ducting, seals and design are patented by Honda. Honda designed the system and teamed up with Delphi (GM's primary HVAC supplier) to manufacture it. Delphi also provides the variable displacement compressor. The smart climate control module also incorporates automatic control of the heated and cooled seats and rear HVAC. On extremely hot or cold days the climate control module will automatically turn on the front cooled or heated seats and rear HVAC system as needed for comfort. It also receives information from the Nav system to determine the position of the sun relative to the vehicle. The computer determines by time of day and direction of travel if the sun is primarily on one side of the vehicle and compensates automatically using the dual zone adjustments. The system is so much more efficient and environmentally safer that Honda received CAFE credits from the government.
    That's slick.
  • evodadevodad Member Posts: 135
    what is that 'hole' below the vents and between the seat heater buttons. Almost looks like some sort of display?
    That hole is the display for the rear climate control settings.
  • schen72schen72 Member Posts: 433
    @stever said:
    That's slick.
    This feature is Honda/Acura's GPS solar sensing climate function, and it's been on their GPS equipped cars since at least 2005.
    Too bad I use Garmins. B)
  • sebring95sebring95 Member Posts: 3,241
    I'm rather surprised this is considered an upgrade and that some SUV's don't even have this? I have the prior gen MDX and it has a similar system. It does help with 2nd row occupants but the 3rd row or cargo area is left to bake in the sun. When hauling our dogs I have to use my Suburban or significantly older Pathfinder that both have vents in the ceiling all the way to the back. I was very disappointed with the HVAC in the MDX as I just thought ceiling vents were the norm for such big vehicles.
  • rjedrjed Member Posts: 2
    I don't think climate control for rear seats work well in 2014 MDX. The rear vents easily gets obstructed. The lack of overhead vents is a design issue, especially if you have small kids on rear facing car seats! Blower on full force still won't cool the insides of rear facing car seat properly due to the vent positioning. I wish honda thought about this issue at the time of re-design. I am just waiting it out till my kid reaches safe age for facing front.
  • taganrogtaganrog Member Posts: 5
    I have exact same reservations regarding 3rd raw seats. Glad I am not the only one concerned about heating/cooling for the passengers in the 3rd raw. The other 3 raw SUVs we are considering all have vents for the 3rd raw, highlander, qx60 etc.
