New tires on 2007 Honda Fit ... are these installed right???
OK, so I am new to these forums, and this is going to be a stupid question, but I need to see if I have a problem or not. I just got 4 new tires Guardsman Plus P175/65R14 81S put on my 2007 Fit. They seem to seat differently on the rims than the previous tires.
I am used to having the hubcap sit almost flush against the rubber tire, but now I can completely see the outer edge of the rim on all four tires.
Shouldn't the new tires fit the same as the previous tires if they are the same size? Do I have an installation issue that could potentially be dangerous? Or am I worrying over nothing?
Best Answer
capriracer
Member Posts: 907
Some tires have what is called a "rim protector" - a ridge of rubber near the rim edge that sticks out beyond the edge of the rim to protect it from curb damage. Not all tires have that feature - and not all tires that have the feature have it to the same degree (some are big and heavy, and some are shallow and light).
So, no, the important parts of the tire may sit the same on the rims, but they may look completely different.
6
