Our rear wiper did the floppy thing - the dealer needed to reset some kind of clutch. No problem other than the pain of taking the car in. We're about to hit 20,000 miles and all I can say is that everyone in the whole fam damily loves the car, teenager especially. Unfortunately the teenagers have also smacked into a Taurus wagon in a Mickey D's parking lot -$1700 to the Taurus, nothing to the MDX and backed into an Explorer while both cars were backing up - looks like about $1,000 to the MDX. It is wider and harder to back up than normal cars. The good thing is that nobody else wants to drive my Saab 9-5 wagon!
I returned recently from a trip where I towed my boat to a lake a couple of hours from home. Boat weights 2400 lbs dry and the trailer weights another 1000 lbs. Figured with gas and camping gear we had another 500 lbs. The drive also including an increase in altitude of about 2000 ft (up to an altitude of (3000 ft).
The MDX did fine. I knew there was a boat behind me but the MDX felt strong. Going uphill the transmission never really got past 4th gear. Braking was fine and even.
It will be interesting to see the what spin Mercedes M class evangelists are going to put on this results. After loosing grounds on all the other categories, the "superiority" of the M class was frequently demonstrated by its "peerless" safety record. Until now there was no hard evidence to compare, thus verify these assertions. Now that MDX got the best record on all categories and M class is only acceptable in Head/neck injuries that safety myth is shattered.
I'm no evangelist - I just finished up my research and opted for an ML320 over an MDX. I still have my MDX deposit (haven't had time to head to the dealer yet) - but I won't be needing it.
I still think, absent of whatever IIHS thinks, that the ML320 is the safer vehicle, because of accident AVOIDANCE.
The best way to survive an accident is not to have one. When the NHTSA is considering making VSC (ESP) standard on all SUVs, Acura is making it a nice marketing piece for all those in 2003 or 2004 MY. No thanks.
Besides - I'd like to see a side-impact on the MDX. My thinking continues to be that those very light doors will not do much to protect, and the absence of side curtain airbags means a side impact would be tragic on an MDX.
I hope none of you ever have to test any of the features I mention above.
However, there's more to accident avoidance than VSA. There are many, many variables to accident avoidance. E.g. stronger acceleration is itself a measure of avoidance because it gives the driver better power to execute highway passing safely.
Even something as mundane as steering-wheel-mounted audio controls help prevent accidents by reducing driver distraction. Indeed, driver distraction probably causes far more accidents than the lack of stability control.
Even high visibility is a strong accident avoidance measure.
Also, VSA will not prevent many offset frontal crashes, where the MDX's excellent crash test scores should substantially reduce the risk of injury. Again, the MDX should have VSA, but it isn't a magic bullet.
As far as side impacts go, the MDX will probably do quite well with the NHTSA side impact test. Acura has predicted it will earn top scores, which indicates they designed the vehicle to withstand side impacts well. Acura also predicted the MDX would earn top scores in the IIHS crash test, and was correct, so I have no reason to doubt them.
Bottom line, sometimes you cannot avoid an accident, no matter how good a driver you are, or what measures you have. It's nice to know that with the MDX, the IIHS has shown that there is a lower risk of injury than many other vehicles.
That's a stretch - but the good test results definitely help the MDX's case.
Of course - you'll remember I was looking into one before I plopped down the money for the ML320, and there were no crash tests of which to speak on the MDX, proof positive that although they do mean something to me, it's the company's commitment to safety that matters. MB has always been about safety, more so than Honda/Acura - although not to say that either vehicle manufacturer doesn't care about safety.
It is a stretch, but you drew the peculiar 10% acceleration vs. VSA angle, I didn't. Like I said, there are MANY variables in accident avoidance, and sometimes you just can't avoid one.
No doubt the next-generation ML320 will have improvements in its crash test scores. I suspect that IIHS will have to begin raising the curve for its grades so everyone doesn't end up near the top.
Unfortunately, the sad part about this is that they simply can't raise the curve, because some new SUV's from manufacturers like GM are still bringing up the rear in crash test results. Note how the IIHS press release says that Ford is making enhancements to the Explorer to help it perform better in an offset frontal collision. Better than what? Wonder how that makes current owners feel?
Spent the summer towing a 21 ft. ski boat - about 4,000 lbs. total with trailer and gas to and from local lakes around Wisconsin. MDX handled great - I also knew I had a boat behind me, but felt extremely stable and had adequate acceleration. Also, pulling boat out of water has been no problem.
If I had to choose the whether to have an accident in a Mercedes vs a Honda engineered vehicle, the Mercedes wins hands down. My brother in law owns a body shop and sees wreaked vehicles everyday. Only Mercedes and Volvos have the construction where occupants will survive most accidents. Hondas, if struck from the rear, don't hold up very well, the seats break, and the occupants go through the rear of the vehicle. Compare this to the heavy constructed Mercedes seats. They don't break!
When vehicles roll over, many times the roof will cave in, not so with Mercedes and Volvo. Mercedes also publishes videos of testing to prove this.
The MDX appears to do well in a frontal crash, but given's Honda's history, will probably not offer much protection in other types of crashes. This along with the lack of a stability program, onboard sos system, relatively small tires, no air curtains, etc. don't make a system that is safe as the Mercedes.
Let's also note that most Hondas and Acuras have historically been smaller vehicles in the subcompact to mid-sized class (the Passport, previous Odyssey, and SLX were not Honda/Acura designs). Such vehicles tend to do worse in crashes because they're simply smaller and lighter. The Odyssey and, especially, the MDX are, hopefully, of a larger and stronger construction (as the IIHS tests show), but only time will tell.
Historically, Honda vehicles haven't done as well in the IIHS test, but the three most recent Honda/Acura vehicles have all done well -- the Odyssey, the Civic, and the MDX. The Civic is in fact currently the best performing vehicle in its IIHS test class, and the MDX is the second-best, so some good engineering is at play here.
So hopefully Honda/Acura has been making a stronger commitment to overall safety, and not just for the crash tests. But these models are of course relatively new so a full history hasn't been built on them yet. As far as other types of crashes, though, there have already been some pictures of some rear-end collisions where the MDX held up extremely well, though that is not a scientific basis.
As it is, the IIHS test covers one of the most (the most?) common collision scenarios. It's certainly a lot more scientific and methodical than endless theorizing. It's comforting to know that the MDX protects its passengers very well, essentially tied at the top of its class with the BMW X5.
According to the IIHS, front offset crashes aren't the most common. What is probably important to note is that people involved in offset and side impact crashes are one of the more likely to be injured.
I had been wondering if rear-end collisions are the most common, though they're probably statistically less likely to cause injury than some other collisions as those numbers point out.
Those stats demonstrate that the offset frontal crash tests are indeed important, and more so than the full-width frontal crash tests done by NHTSA.
Just out of curiousity, did EuroNCAP begin offset frontal crash testing first, or did IIHS?
(Off-topic, I read the posts preceding the referred message to understand the context. With all the tragedy this week, I had forgotten that the Aztek didn't do well at all - marginal overall. That's really too bad, though not surprising.)
Seriously - have a look at them - some of those ML's rolled over 4 or 5 times.
I've had 2 different family friends roll over their trucks - one a Honda Passport - not good.
The IIHS does a good job of testing frontal impact, which, as has been mentioned previously, isn't the most common type of accident.
For my money, I think a track record is more important than a few crash tests - and the record on the ML320 is stellar. In a few years, I would possibly consider an MDX (if they beefed up the interior and added VSA).
There's something else to be said about being an innovator versus a follower - in an MB, I get the product of a company that innovates around safety, not just replicates and improves on what everyone else is doing. Not that there's a huge difference - but who knows what little MB gadget will save my life.
I was thoroughly impressed with Brake-Assist, the capability of the car to recognize fast braking, and power assist the process to bring the car to a halt faster. All too often in NYC stop-and-go traffic, you find yourself with too little room between yourself and the next car, and only a split second to apply the brakes. As a test, I slammed on the brakes during my ML320 test drive, and was IMPRESSED at the short stopping distance.
Dunno what CR tested with regards to the MDX, but moving at 30 MPH with an emergency braking procedure, I saw a signficant difference between the ML320 (which stopped on a dime, practically) and the MDX (which lagged, despite the strong feel of the brake pedal).
Another question would be the strength of the roof - although I don't wish it on anyone, it'll be interesting to see the first MDX rollover accident pictures.
You people put way too much faith in VSA. I highly doubt that the ML offers significantly better protection in a crash. Both cars are safe. If you are that concerned with safety don't leave the house or wear a helmet when you drive.
Yep, no doubt the ML320 has a proven record in rollovers. We don't know how the MDX would do. If someone requires a proven record, the ML320 is certainly a strong option.
Though I am curious to your statement, that you held off on the MDX because of Drew's rollover pictures ("Reason I held off on MDX - Drew's rollover pictures") (and actually, I sent you the link to Drew's rollover pictures, which are impressive). You had previously stated that you didn't get the MDX because it didn't have stability control and/or you didn't like the treatment at Acura dealers you visited in the NY area. Have you changed your story again? ;-)
The IIHS crash test is a significant safety test, and it does indeed reflect many of the injuries (serious ones, too) that are inflicted in accidents. Indeed, I remember you saying that the X5 "tested incredibly well" in the IIHS test, and "that was one HELL of an IIHS performance it gave." Using your own statements, it's safe to say that the MDX did very well in the IIHS test, and it is quite significant when it comes to vehicle safety.
Next time you have a lot of snow, could you try this in a parking lot or some other safe area that doesn't have a lot of stuff to crash into? We should have a good amount of snow this year. Accelerate, then pretend you just saw a line of traffic up ahead that slowed down a lot. You can't stop in time in your lane even at full braking, but if you swerve left, you'll have more space to slow down but there is still traffic there. Swerve while braking hard. I'm curious what would happen. Seriously. I'll tell you what I think should happen theoretically after you post the results...
I did this in my 92 Explorer in snow at about 30 mph. ABS was activated and I swerved left fairly hard. It didn't tip over, so I doubt the MDX will. I'm sure its a nice feature, but that doesn't mean the MDX is unsafe or even less safe. Let's see what the stats tell us in a few years.
No, it won't tip over; tip over normally happens after a car "trips" while going sideways. That's not all VSA is good for. What also would be interesting is if you did a "moose test" while hard braking...i.e., swerve hard left, then hard right. In theory, this would cause oversteer on cars w/o VSA. There was a short image on a TV news segment in Canada last year that showed an MDX doing this and sliding sideways. I'd be curious if this is reproducible. To kick the MDX out of this, you should, in theory, need to hit the accelerator to cause 4WD to kick in...
I haven't heard of any MDX rollovers yet, so maybe the wider is better design is really better. It should be interesting this winter because there are finally enough MDX's on the road for one driver to do a whoops....
The MDX lost out on safety to the 2002 ML320. I felt there were too many extra safety features in the ML320 the MDX couldn't match (or couldn't perform as well).
Why did customer service factor into the decision?
Because I was thoroughly impressed by the 2002 ML320's. I wasn't as impressed with the 2001 MY.
If, *IF*, the Acura dealer I visited back in July hadn't been such a jackass, I most likely would have bought the model he had on the lot (which, was about $500 over MSRP, but I would have had a summer's service out of it, and I really wanted a new car for last summer).
Thankfully, as to script, the Acura dealer was a complete jerk, I walked off the lot in anger, and I'm in line for my ML320. But if he hadn't been such a poor salesman (and excuse for a human being) I would be driving an Acura today.
Thanks for the explanation. Curious, though -- you cite safety as the reason the MDX lost. E.g. "lack of VSA on the Acura killed it for me" in a previous statement, and the rollover crush resistance you cited several messages above.
However, the MY2001 ML320 had these features, yet you chose the MDX over it (and would have taken one had the dealership been better)? Did you not consider the MY2001 ML320's ESP, rollover crush resistance, Brake Assistance, and MB's commitment to safety enough reason to buy the MY2001 ML320?
The MY2002 ML320 adds side curtains, which are definitely nice to have but not essential in a high-riding SUV (else a lot of pre-2002 owners would be trading up; Drew had some excellent posts on why side curtains in an SUV weren't as critical as other safety measures). EBP is a good 2002 feature but the braking was good before.
Thus, MY2002 isn't a large leap forward in M-class safety. So the MY2001 ML320 should have been enough for you if safety is the reason you got the ML320 over the MDX.
my decision making process, and how I evaluated reviews, was flawed.
First off - there are Honda people, and there are non-Honda people. When I first found forums and reviews of the MDX, most of the ones claiming it's excellence were of Honda fans. I don't count myself amongst that crowd - I have a Honda Accord, purchased by my wife before I met her, which I consider to be the bane of my existence. After only 80k miles, it has cost well over $1500 in repairs, and it's rotted out exhaust will see at least another $400 go down the toilet. My best friend's Accord wasn't as lucky - it's transmission kicked the bucket at around 55k miles, but luckily, under an extended warranty. I find the leather to be cheap as well as the controls, with a gaudy push-button like quality to them.
But, I figured, form follows function - the credo of engineering. The reliability behind the ML320 of 98 and 99 were questionable, although improved in 00. I had no info on 01 as yet, so I had to assume that it would be the same as 00, and I'd have to pass on the 320. Also - ride and appearance, both fixed up quite a bit in 02, lagged behind the RX300.
Crash test results of the MDX didn't sway me. I felt the vehicle was not as sturdily constructed, having taken a look at both of the vehicles very closely. Lighter weight does add to the MDX's excellent mileage capabilities, but it does detract from safety. I hope to God the engineers didn't shave off a few pounds by going light on the roof support.
As I went on in my search, safety mattered more and more, and I decided if safety was what I wanted, I should buy a MB. It was only after 02's improvements, such as rear-seat AC, bi-level Xenon lighting (without necessary sport package), and some exterior upgrades, that I saw the MB as a clear winner over the MDX.
Personally - if I didn't care about cargo space, the search would have ended with the RX300. I think the Highlander has every right beating the MDX, as the interior of the MDX is *sorely* lacking for a luxury vehicle. For a fancy Accord, maybe. But to compete with Lexus and Mercedes, hardly.
I think ultimately, Acura relies on current Honda/Acura owners, who will put up with their shenanigans, and don't mind the interior looking the same as a $25k Accord.
Thanks for clarifying. I had suspected that your original research was flawed when you initially ruled out the 2001 ML320, and I also suspected that your priorities began to shift somewhat more toward "kitchen sink" safety as your buying process progressed. That's why I kept urging you to look at the 2002 ML320 ;-). I'm glad you have your research and priorities straightened out and you've arrived at the vehicle that fits your priorities. That's what auto purchasing is all about.
Yep, the MDX is lighter, and it's a unibody construction (some of the lower weight is offset by its larger size, of course). The lighter weight didn't adversely affect the IIHS crash test, in which the MDX excelled. That means that Acura engineers designed it properly in this regard (lighter weight but still strong). Hopefully that good engineering design for safety extends elsewhere, but only time will tell.
BTW, if you say that you would buy the RX300 over the ML320 if it wasn't for the cargo space, does that mean that rollover crush resistance and other incremental safety features of the ML320 aren't as important as what you find more attractive in the RX300 over the ML320? FYI, Drew also has some ugly pictures of RX300's with their roof pillars crushed after a rollover. He also has some disquieting X5 photos too.
The leather on the highlander is much cheaper than on the MDX. I almost bought a Highlander but was angered by the poor customer service of Toyota. As far as safety goes, we don't know which car is safer yet. In a year or two we can compare their safety records. I feel the MDX is just as safe as the ML, having driven both. I prefer the MDX. Also, the ML comes standard with cloth, how can you say the MDX isn't as nice? For the money, I feel the base MDX is a much better buy than a base ML.
I think every purchase decision is a question of the assignment of priorities, including pricing. I feel the MDX is a very safe vehicle, and over time more of that will be proven. That said, I do think the M-class has a "kitchen-sink" approach that adds some additional safety, some additional scenarios that are covered. It's up to the individual buyer to decide if their priority is an overall safe vehicle, or do they require a vehicle with even more safety.
While one might ask "how could you not get the extra safety" there are always other priorities at play. The MDX has certain advantages over the ML320 that may factor into one's priority list, just as the ML320 has some of its own advantages.
I purchased a 2001 MDX over a 2000 ML320 because I thought the MDX was a safe vehicle (though the ML320 still has an edge), and because one of our other priorities was a ride comfortable enough for us to live with on an everyday basis (please keep in mind that ride comfort is extremely subjective). The ML320's we drove had what we interpreted as a rather harsh ride with some rocking motions and some serious jolts. Please note that the 2002 ML320 may make this a bit better, though the truck construction (with its pros and cons) is a factor here.
Other factors in our MDX decision included its noticeably better acceleration (probably slightly more so now that the 2002's have gained a couple of hundred pounds). Also the lingering concerns over ML reliability (Consumer Reports have the 2001's now as below-average, though the scores have improved much from where they were before). Another factor was that the Acura service department in our area was a known, excellent quantity, while the MB dealership service departments in our area were/are questionable. Looks came into play too; I'm not crazy about how the ML320 looks (even with the 2002 facelift), and my wife dislikes it more (but probably not enough to disqualify it).
Would we repeat the decision again? Hard to say, as the MY2002 ML320 does have some improvements that addresses some of our older concerns (heck, so does the RX300), and the reliability has hopefully gotten better and maybe our local dealerships are better now (though I doubt it).
At the time we ordered the MDX, it hadn't been released yet so we knew when we'd be getting one (we got the first one our dealer delivered to a customer). I daresay that if we went shopping today and didn't want to wait, or if the dealership wanted to rip us for above MSRP, we'd definitely go with the ML320. Otherwise, the decision would be tougher, made a bit more complex by the fact that the MDX had a slightly better IIHS crash test score than the ML320.
But that's all academic as we don't have to make that decision today, and all vehicle purchase decisions are made at a point in time.
Best of luck in everyone's purchase decisions! So long as you do your homework, you can't go wrong!
I'm comparing equivalently equipped models, and giving extra points to the Highlander for being cheaper.
All said and done, I'd say my ML320 ran about $1500 more than the MDX - but factor in included maintenance over 4 years, and better depreciation, and it just about breaks even. What hurts the MDX in the value arena is the MSRP pricing. The M-class sells at closer to invoice.
As for one item that William mentioned - the quality of the local Acura dealer. I tried about six of the local Acura dealers in NYC - what a complete nightmare. I actually wrote letters to Acura regarding the p___-poor service I received; no response. I figured that if I ever had a serious problem with my expensive new SUV, I'd have nobody to stand behind it.
Look at it differently from the MB perspective - all customers have had nagging little problems - but nothing their dealers weren't eager to fix. There are some nightmarish posts on the Acura board, specifically by a poster going by the name of BellTeck, who has been fighting for months to have a very faulty lemon of an MDX replaced.
That's not to say that a company won't have it's share of lemons. It's how they make lemonade that's of concern to me.
With regards to my RX-300 comment - yes, William, preface that statement as well. Before I became a safety nut, the RX300 would have been great. When I saw Drew's rollover pictures, it was immediately ruled out.
The X5 - great car. Not an SUV in my book, as it holds less than a passenger car. But if you want to do some fancy driving in a tall sedan, you'll have a blast in the X5.
"... but factor in included maintenance over 4 years"
Of course, as you've found out, it's "included maintenance*" (note asterisk). Only pays for oil changes when the computer says to bring it in (and I understand you distrust it because you think the intervals are set to favor lower cost for MB dealerships, so you said you'll be doing some of your own oil changes at your own expense). Doesn't include brake pads, which some ML owners have complained wear out quickly. BMW's included maintenance is much closer to being real included maintenance.
Obviously none of the MDX maintenance is free, no doubt, and Acura maintenance isn't cheap either. But most U.S. MB dealers charge $200 for an FSS-A service, which is basically a diagnostic plus oil change. Nearly $400 for an FSS-B service. I know you don't plan to necessarily keep your ML320 for beyond the warranty period (where you get included maintenance), but I was worried about what the costs would be after the warranty.
The $1,500 price difference you cite is using adjustments you've personally made for features. Of course, others may value those adjustments differently and come up with a much more significant price difference. But you're right, Acura needs to eventually get the price under MSRP at its dealerships.
Funny you should mention Bellteck's problems. Since I have an interest in how the local MB dealerships are doing, I've read some very negative accounts about my local MB dealership being able to accommodate its customers, and it hasn't been pretty. And believe me, there have been some ML owners who have had trouble getting their lemons replaced too. I guess it's a regional thing, some brands have stronger dealerships in some areas, not in others. I'm sure you've read the complaints about some MB dealerships not being able to fix problems, too.
I do agree with rihoops and you though. The base MDX (which I know you had placed two separate orders for on two occasions) is a better dollar value in terms of content. A similarly equipped (to the base) ML320 doesn't come as close, even with adjustments.
A similarly equipped Highlander goes for about $32k depending on market, so it's about $3k cheaper than the MDX. The $3k gets the small third row seat, some better performance, and some more passenger/cargo room, and a few luxury items not available on the Highlander. The Highlander will probably have better reliability. If you need the third row seat, any comparison is moot because you can't get one with the Highlander.
Consumer Reports' rating apparently doesn't factor in the third row and somewhat better performance. Sure that level of Highlander has VSC, but curiously enough the Highlander did not score higher than the non-VSA equipped MDX at emergency handling.
I am speaking from relative ignorance here so please forgive me but if safety is the only concern at play, why not get an AWD wagon and avoid much of the rollover issue with SUVs in general? I certainly think that both the ML and MDX are very safe vehicles but if safety is the only or critical element maybe an SUV is not the best choice. I am of the viewpoint that SUVs prevent many accidents due to better sightline but with your qualifications, maybe an AWD wagon (such as the MB 4matic) might be the safest bet. I wouldn't think that cost would be an issue if you are placing such a great importance on safety.
it goes to something I always say, when I see people saying 'I want a car ride out of my SUV'...
Unless you absolutely NEED an SUV, why are you buying one?
In my case, I do need an SUV, preferably one with a low gear, as I need to both tow my boats, and run over some rough terrain occasionally. A good laugh - the incline to my driveway is almost 30 degrees (making snow entrance an exhilirating experience).
But you are 110% right - and I would gone with the Audi AWD wagon over the SUV if I could have.
for the RX300. Since they sell close to invoice, they're a good value. I don't consider the MDX good value, as I'm not impressed by it's luxury or it's part time AWD system. Of course - the RX300 met neither my safety nor space requirements, ruling it out immediately.
I do think the Honda version of the MDX will represent a good value though. Even though I'm no fan of Honda, I think the Honda version will be a good competitor for it's space. I think once the hype around the MDX dies down (it is a first MY run), it'll be a better value as well (as the disparity between invoice and MSRP is significant).
"if you're going for 'base' value ... I don't consider the MDX good value ..."
But for quite a few buyers, yourself included, the RX300 doesn't have the cargo/passenger room.
Thus, please name a better base value in a safe SUV with a third row than the base MDX at $35k. Buick Rendezvous? Mitsubishi Montero? Ford Explorer? Mercury Mountaineer?
if you're going solely by value, I think the Ford Explorer at roughly $30k loaded is a better one than the MDX. At roughly 15% cheaper, it's a bargain. The whole question now centers around reliability.
Also think the Highlander will be a good competitor at the 'base' level (of $35k).
I wouldn't touch it if someone gave it to me...well...maybe to sell it for something else :-) I doubt they've done anything w/ the roof collapsing on rollovers...
No, I won't laugh. Maybe I'll just gasp a bit. ;-)
Please remember I said base value in a *safe* vehicle with a third row seat -- that also rules out the Highlander just like it rules out the RX300.
Besides reliability, safety is even more of an issue with an Explorer. I'd imagine the IIHS should have released crash test results for it with the last roundup (where the MDX scored "Best Pick"), but instead the press release has this *very* curious statement:
"The Institute didn't test the new 2002 Ford Explorer along with this group of vehicles because structural modifications intended to improve its offset crash test performance are scheduled for later this year. The modified Explorer design will be tested when it becomes available."
Okay, so Ford is "improving" the vehicle to do better in the crash test. Uh, how bad is the current 2002's that people have bought or are buying? And how much "improvement" will there be?
Perhaps when it gets the promised stability control that'll improve its safety, but since stability control won't prevent some crashes, it had better do at least "Good" in the crash test. Jury's still out on that and Ford's making no promises.
And, if you're talking about what you can buy today, it's neither here nor there -- you can't get stability control on the Explorer yet, and I'd bet the current models do not do well in crashes, given the statement above.
Good points. No doubt that AWD wagons have many of the useful elements of SUV's, without some typical SUV issues.
I wonder how much of the safety advantage of wagons are offset by the SUV's placement of passengers higher, where they're less vulnerable to crashes (particularly side impacts). Obviously engineering both static stability (wide track, suspension that's not too soft) and dynamic stability (stability control, pneumatic suspension) can help substantially reduce the rollover risk. Of course, some of that damage is inflicted by other SUV's (I've no desire to see this forum become an SUV/anti-SUV debate, of course).
Obviously cargo room comes into play. You can only load so much into a station wagon, and once you go past the beltline, the cargo itself can become dangerous to the passengers inside. And the wagons don't offer the forward-facing third row that vehicles like the MDX, Rendezvous, ML320, etc. do. The ones that do have a third row have a rear-facing seat which is inconvenient and perhaps questionable in terms of safety.
Finally, it's sort of like AWD minivans -- there are less good options. In the SUV market you get fierce competition between Acura, BMW, Lexus, MB, Toyota, Ford, GM, Chrysler, etc. But there are relatively few AWD minivan choices. There are more AWD wagon choices but to me they all have their own issues, though many of them are quite excellent.
I happen to really like the Passat 4Motion wagon, an excellent vehicle. The Subaru Outback VDC is also very good, but doesn't offer side curtains (which, while not essential in a high-riding SUV, are to me essential in a lower-riding sedan/wagon). The E-class wagon with 4matic is a wonderful vehicle, but it's also substantially more expensive than an M-class. The Audi's and Volvo's aren't cheap either, and the latter has had a lot of reliability woes recently.
Woops, Audi All-road is having problem? Heck nothing with German pedigree is reliable I guess. Looked at X5 closely but bailed out after the Aux fan burned up 3 houses, good dealer returned my deposit. The ML, well I heard they have too much problem on MY 99 through 2001 so no go there. MDX is a little too plain, IMHO.
The Audi allroad is a bit too new to have compiled reliability on. However, as Drew mentioned, CR did hit the A6 as "below average."
Saw an allroad today. "Interesting" vehicle, to say the least. I was surprised how much trim it had on the exterior, unless it was the owner's accessorizing at work.
hpia4v2: The worse of the ML reliability and build quality problems were the '98's and '99's. CR says the 00's were below average, but much improved. No compiled numbers yet on 01's.
The X5's woes have been disappointing. For reliability, the clear choice is the RX300 (also the QX4).
Actually, I think the base MDX (premium) is quite a good value and I believe that several writers have made statements to that effect. I actually was targeting the Highlander but at over $30K (still not getting leather and other options) I looked around and found the MDX. While I didn't want to spend $35K on a car, I thought the value difference between the HL and the MDX to be worth a few thousand more. I took delivery a few weeks ago and am very happy. As for the Explorer, I was entitled to the xplan discount and I still didn't want the Explorer. It has it's own advantages (towing) but for me it doesn't compare to the ride, styling and refinement of the MDX.
I agree with you. The Highlander is a very nice vehicle, no doubt, and is even more so if more Toyota dealerships enforce discounts (it seems to vary greatly).
But I still prefer the MDX over it. I'm glad you're enjoying your new MDX.
Certainly the outlook nowadays is gloomy, with the horrible tragedy, the plummeting stock market, and the spectre of a long military action. I think we're right in the middle of it now and it'll be a while before a lot of new car sales begin to recover (though I think with a recession theyll be down overall).
Only you can decide what's best for yourself. The MDX is a great, enjoyable vehicle and should serve you well. If there's a significantly cheaper vehicle that can serve you nearly as well, that's always a consideration too. Good luck!
Can anyone tell me about finding an mdx in penna. at base price. Dealers are adding 2500-3000 dollar options that I don't want. how long is the wait? It,s the economy .
We purchased an MDX with the touring package approximately 7 months ago and have so far thoroughly enjoyed the car. The only thing that we are having a bit of buyer's remorse about is that we did not purchase the gps. Does anyone know whether Acura can or will offer their gps as an after market accessory? If not, is there any non-Acura gps system that anyone can recommend?
Just a quick comment. I noticed some debate on the safety issue. I have a couple friends who are in the forensics analysis business - studying auto accidents. They drive Mercedes. Why? because of merc. commmitment year after year to safety. When i asked about Acura (my wife has a TL and i have a 98 ML, and will be making a change soon so something new) they believe they make a good safe car -- just not as highly committed. (remember, they put their badge on some pretty shoddy vehicles, passport, etc. true, they aren't honda designs but they were selling them.)
However, it's good to see the results of the recent iihs safety report.
Does anyone know where in TN or the southeast I can find an MDX for base price (34,850)? One dealer in TN said that would mean no rear mud guards, paint sealant, wheel locks, all season floor mats and cargo tray. Are these items not standard?
I see a lot of Progressive Insurance vehicles moving around town. 100% of them have been Ford Exploders.
http://www.highwaysafety.org/vehicle_ratings/ce/html/0113.htm
Press release:
http://www.iihs.org/news_releases/2001/pr091101.htm
Congratulations to the great MDX design team!
Transpower
IIHS study:
drew_ "Pontiac Aztek" Sep 15, 2001 2:41pm
Drew
Drew
