Acura MDX (pre-2007)
It has been recalled for transmission and engine. It took over two years for Honda to come up with a fix for the rear brakes. It still rattles in several places.
Honda seems to be having continuing transmission problems (since the 1999 model year and continuing into the current 2004 model year) with vehicles with V6 engines. The redesigned MDX transmission doesn't yet have the cumulative miles to say if it is better with respect to reliability, long term, than the previous design.
Honda may have been slow to step up to the plate in taking care of transmission problems, but they have been taking care of the problem, usually at no cost to the car owner.
Based on my limited Honda experience, my Chevrolets were more reliable with respect to major components. My last Chevy, a Corvette, was assembled better than my MDX too.
Overall, I like my MDX and find its reliability no worse than most other manufacturers' vehicles. But, it isn't much better either, though I expected it to be. Honda's four cylinder vehicles apparently still have outstanding reliability.
Jeannine Fallon
PR Director
Edmunds.com
I have an '01 Touring MDX with the Navi that I bought in Oct. of 2000 (it was the second MDX my local dealer received after the vehicle was first introduced).
Because I have been exceptionally satisfied with the XM satellite radio I have in another vehicle, I decided to have a second unit installed in the MDX about 7 weeks ago in preparation for a road trip I was about to take from the San Francisco Bay Area to Denver.
A week after the XM radio was installed in the MDX, the updated DVD for the Navi I had ordered earlier arrived. After installing the update, I drove a few miles to ensure the Navi was working properly. It seemed to be fine. With the XM radio working perfectly, I was ready to head off through the Nevada and Utah deserts to Denver.
Just as I was about to get on the road, I entered the Denver address that would be my destination. But about 45 minutes later and 50 miles from home, the red cursor on the Navi display screen wandered off the interstate I was driving on, which resulted in a prompt on the screen that read: "Not on digitized road." My immediate thought was that there was probably a software glitch with the new, updated DVD. I didn't have the original DVD with me, so it wasn't possible to eject the new DVD and try to reload the original. (I found out later that it wouldn't have worked even if I had the original disc with me and had loaded it into the DVD player under the passenger’s seat.)
During the ensuing 2600 round-trip miles to and from Denver the red cursor on the Navi screen would sometimes find the highway I was on. But when it did, it would always wander off again within a few minutes or up to a half-hour.
When I returned home a week later I took the MDX to my dealer to see if they had a fix and was able to speak directly to a technician. When I told him I suspected it was a software glitch caused by the updated DVD, we tried to reinstall the original disc, but the system wouldn't accept it. The technician finally ran a small jumper cable to two terminals at the back of the DVD player in order to reset it so it would again accept the original DVD. When he did, it seemed to work; the screen showed us at the location of the Acura dealer.
The game plan at this point was for me to use the Navi on a trip I had already planned to take to Southern California to see if the system would work with the original disc. If it did, I would request a new, updated DVD to replace the one I had been sent earlier. If it didn't, I would bring the MDX back to the dealer and a new DVD player would be installed.
I experienced the same identical problem to and from Southern California that I had with the Navi during the Denver trip.
I took the MDX back to the dealer upon my return and the dealer ordered and installed a new DVD player. A new one arrived within a day or two and was installed, but it wouldn't work either. Thinking that the replacement player was defective, a second player was ordered and installed. Same problem.
Finally, the tech pulled off the plastic panel that surrounds the Navi screen to check the GPS antenna. When he did, he saw the XM radio and immediately suspected that it was the culprit.
The XM radio installer had inadvertently positioned the satellite radio into a small cavity directly below the GPS antenna, which is located above and in front of the right air conditioning vent at the top of the Navi screen. It seems likely that the close proximity of the XM radio to the GPS antenna is creating a weak GPS signal, which would account for the red cursor showing the vehicle's location to wander off course.
I'm taking the MDX back to the XM radio installer next week to have him relocate the radio to a position behind or under the glove box. If by doing so the Navi works correctly, life will be good once again. If the same problem persists, I'll have the installer yank the XM radio out completely and buy an '04 Touring Navi with a factory-installed XM radio, which are now available. I've been so happy with my '01 MDX that I've been thinking about moving up to an '04 anyway for the added features and a new four-year/50,000 mile warranty.
The bottom line of what seems to have turned into a short novel (sorry 'bout that) is this: If you have an MDX with the Navigation System and are thinking about having a satellite radio installed, post a reply to this message and I'll provide an update as to whether repositioning the satellite radio away from the GPS antenna fixes the problem with the Navigation System.
The 2002 MDX was 5/5 stars (driver/front passenger) in the full-frontal crash test. The 2003 was 4/4. The 2004 was 5/4.
Acura may be trying to get the vehicle back to 5/5 with the 2005.
The side-impact rating (5/5) will be carried over. The 2005 MDX will also receive the new rollover test.
http://www.nhtsa.dot.gov/nhtsa/announce/press/pressdisplay.cfm?ye- - ar=2004&filename=pr37-04.html
For those wanting a "long term report card" on the MDX, I've had my MDX for nearly four years now (took delivery on the first day of availability in October 2000). My car's serial number is in the low hundred's so it was one of the first one's built. The car now has 60,000 miles.
Facts
- Per the transmission recall, the car's transmission was inspected at 50,000 miles and had the preventive repair completed. No known transmission problem's thus far!!
- On my second set of tires. First set lasted about 45,000 miles.
- Still on my original set of brake pads.
- Still running with the original battery.
- Overall gas mileage has slipped a bit thru the years. It now gets around 19mpg where it originally would get around 20.5mpg
- Leather interior has held up very well.
Overall Assessment
- Great Car. I've literally had nothing go wrong with this car. I would buy another MDX in a heartbeat.
P.S. Too bad I can't say the same wonderful things about my 2004 TL!
Changes for the 05 MDX according to the lastest Acura news:
MDX
Standard XM Satellite Radio
Acura HandsFreeLink Bluetooth wireless phone interface on all touring models
OnStar on all models equipped with navigation system
Larger fuel tank
6 Disc In-Dash CD player on models equipped with Rear Entertainment System
Enhanced Vehicle Stability Assist (VSA) system
Enhanced navigation system
Quicker response time
Additional voice recognition commands
More points of interest
Zagat Guide
LEV-2 ULEV emissions system
3 new exterior colors including Desert Rock Metallic, Billet Silver Metallic and Steel Blue Metallic
All very minor changes in my option. The three new colors sounds interesting. The larger gas tank will coming in handy, I hope this gas tank don't slosh.
My wife prefers the MDX, but I'm going to have a tough time justifying the price difference, if this really is the situation for the 2005's. May jump up to the 2005 GX470 (with it's new more powerful, higher efficiency V8), just to avoid the feeling that I paid $7,000 more than the Pilot for a bit more leather and wood and a slightly quieter ride.
That's why the better deal right now is the 2004 MDX base model (vs. a leather Pilot). 2004 MDX has new styling vs. 2003 MDX, side curtain air bags, 17" wheels, lower roof height, sunroof, quieter ride, better interior, newer transmission design, higher Consumer Reports reliability rating (tops), slightly better Insurance Institute floor intrusion crash statitics, vehicle stability control, longer warranty, better buying experience - I'm sure I forgot something.... Plus the reaction people have when you say you bought an Acura vs. a Honda = higher resale value. That all adds up to easily justify the $6K spread....the side air bags do that themselves!
Believe me, I just went through the process and bought the MDX (sage) on Labor Day. Paid $33,336. (invoice) with free wide color-coded side molding installed ($299.) - and cargo tray, net and cover for cost.
This will be my wife's ride. I get the LLBean Outback - which is fine and handles better. Just wish Subaru would get their mid-sized SUV to market!!!!!!!
If you can't justify the price difference between a pilot and the MDX, then how can you jusify the extra $10,000 for a GX470? Unless you are planning to do some serious off roading or heavy towing, that extra little bit of luxury just do not add up to $10,000. Dollar for dollar, the MDX is a much better buy than the GX470.
I can get a nicely equiped GX470 (Navigation, ML stereo, 3rd row) for about $46.5k. That's roughly $8k more than an MDX Touring with Navigation. Which itself is roughly $7-8k more than the Pilot w/ Navigation. Now, although I am a big Honda/Acura fan, IMO I would say that the increase in "luxury" going from a MDX to GX470 is at least equal to the jump from the Pilot to the MDX. I know that's subjective, but we have two sets of friends who have "traded down" to the GX470 from a $65k LX470 and $70k Range Rover 4.6 HSE respectively and neither of them feel they gave up anything in terms of luxury feel, ride or interior quality.
The added advantage of the GX470 - and Volvo XC90 - is that they qualify for the 6,000+ lb GVW write-off. If you qualify, the after tax cost of the $46.5k GX470 drops to about the price of the Pilot.
I would say that the Volvo XC90 with it's new Yamaha V8 engine and 6-speed automatic transmission option has gone to the top of my "luxury list" over either the MDX or GX470. It will come close to matching the Cayenne S in performance and carry 7 passengers. I would like Volvo to steal Acura's navigation system, but Acura needs to steal Volvo's seating design and steering/handling precision.
Note: Once assembly problems were fixed, my Volvo was reliable for about 70K miles. After that reliability was terrible. Parts were expensive, but more quickly available than the parts for my MDX.
1. No coin/loose change holder?? Once you've had one it's certainly a nuisance to go without!!
2. I find my kids and I are frequently "reclosing doors" they don't close tightly under their own weight so they need more than a little flip of wrist to close securely; are other folks experiencing that?
3. This is my first SUV and I'm shocked that when I take my foot off the gas pedal, instead of cruising, I immediately begin to slow down, as if I hit the brakes. It's very noticable and I wondered if it's "standard" w/an SUV engine or vehichle. I've had v6 sedans for the last decade.
I'd appreciate any comments please. Cig
Just go to Pep Boys and purchase a coin holder for a few bucks. It fits nicely in the top compartment of the center console.
2. No suggestions
3. It does have a "feature" that controls speed when traveling on downgrades. If you are going faster without giving it gas or while using the brake it senses you are going downhill and applies transmission braking, probably by just turning off O/D or downshifting.
Are you it "D5" or "D4" when this occurs? Maybe your O/D isn't working properly.
This isn't standard, all SUVs are different, just like cars. My MDX doesn't have this problem, but I have an '02.
1. Agree. I guess the cramped ashtray will have to do (is that a dime or a penny I feel??)
2. Agree. The back latch, too! (It must float longer than your average SUV!!)
3. Disagree. Our MDX seems to keep going OK. We realize after this weekend that you drive an SUV differently (it's our first one, too) if you want to get good mileage. No gunning it anymore :-(
You have to respect the weight and use it to your advantage. We are almost at 1/2 tank and are at 16.9 mpg on the computer. not bad for the first tank. Hope we can get close to 20mpg with mainly a highway commute.
It rides very smooth. We are glad we got it over the FX35. Just could not get over the rough ride on the FX. Great looks, though.
I had my MDX for 7 months now and loving it.
I only use my coin tray for quarters, so there is no fumbling for dimes and nickels.
Have to remember, the MDX has a big door. Like any truck, it is heavy and may take a bit of a push to close, unlike a sedan. Try sparying some teflon lubricates on the door hinges and latches.
The MDX is actually a nice cruiser for a truck, again it is not a sedan and will slow down when you let go of the gas. To make it a better cruiser, you may want to pump up the tire pressure to 34 or 35 psi. This will give you less tire friction and the car will not slow down as much when you let go of the gas. Of course you will be losing some traction.
Good Luck
I drove my MDX today & tested taking my foot off the gas pedal...I didnt notice any immediate slowing down, it just cruise smoothly and no slowing down until reaching a certain distance. I was just wondering if you had your foot brakes on.
I got the transmission recall applied, since then the truck seems to shift erratically when cold, not terrible, but much more rolling resistance. I wonder if they just didn't put enough fluid back in...maybe since there is a new loop in the trans that maybe they need to amend the fill amount by 1/2 pint?
I got the brake noise fix applied. I was never bothered by the noise in the first place, but thought since it was available I would get it done. Well now I have a pulsing in my brakes and the braking behavior has changed. When lightly braking the truck seems to exponentially decelerate...so much that my wife always says whoa take it easy. I brake lightly then the brakes seem to catch more and more, not that they don't work, but it is difficult to gradually apply the brakes since they go from little grip to hard stopping very quickly.
Not sure if either of these issues are related to the fixes or just coincidence? We only have 17K on it an most of the miles are highway, so it is possible that the brake rotors are warped and need to be turned due to mostly high heat braking?
I noticed minor high speed pulsing (warped front rotor like vibration) about 10K miles ago. Still does it at times (27K on my 02). Does not happen all the time during high speed slow downs and has never happened at in town speeds. There was no change in brake feel or performance after the brake clunk fix - just no more clunk.
My MDX has never been a great stopper, but I suspect that may be due more to the hard Michelin Cross Terrains than the brakes.
With a coupon for a free oil change, I am very happy not having any $$ out of pocket.
I've noticed that the trip computer is always pessimistic when it comes to avg mpg calculations. I think this is due to the fact that when you're at a standstill in traffic or at a stoplight, it continues to factor in the 0 mpg for the duration of the stop. So far, I'm pleased to be getting just over 20mpg with half my driving in town and half on the interstate.
I would agree with the guys who say that the '04 MDX base model is a better value than the '05 Pilot leather. Especially since dealers are willing to go close to invoice on '04 MDXs.
I do with that I could take the seats out of my Volvo and put them in the MDX however. It's hard to match the comfort of Volvo's seats.
If anyone is looking to get XM radio for their '04 MDX, I just had an "XM commander" put into mine. I had a local stereo installer fabricate a simple plastic cradle which fits very neatly into the storage shelf in front of the gearshift, with about 1/3rd of the room left over. Very slick, it almost looks as if it were built in... no wires showing, no fuss no mess.
-Cheers
Still driving it easy...haven't pushed the pedal or the body, yet. This is out first SUV so getting used to the mass. Actually, we just took it on a long trip and then we've garaged it until the Accord is sold. Finally selling it tonight!
What did the XM unit cost installed??
I also had my first experience which made me very, very, very glad that my dealer put a clear nose mask on all the MDX's! There's a lot of construction in progress on the section of the Interstate I frequently use to commute to work... nuff said!
As for the XM unit... the XM Commander cost $150, and it comes with everything you need to mount it to a vehicle...(receiver, tuner, RF modulator, antenna) and about another $39 for installation including the fabrication of the base which mounts it to the storage shelf. All told, just over $200 including tax. It's not too bad, considering that a XM Delphi SkyFi unit's car kit is $70 alone, add to that the installation cost and the fact that the Delphi SkyFi on the cradle is HUGE! The little extra cost I think is worth it for the gucci factor and being located in a very convenient place.
Word of warning however, make sure that you get it installed at a place that has experience with MDX's. The space around the center consol's face plate(which needs to be removed to install the tuner) is unusually tight... so you definitely don't want an inexperienced monkey wrenching at it and scratching the trim.
-Cheers
So, in the pouring rain I stopped at the new Acura dealer in Cleveland that had emailed me their Internet pricing, asked for a red one, talked my way out of Nav ($2K for a map?) and DVD, the saleswoman showed me a Touring, I pretended this was my first test drive (which was as good as the real first drive), and got home at 10:30 with it.
What a great vehicle to drive. Lightyears past my ML320. I love everything about it. If anyone else is considering Pilot, don't drive the MDX if you don't want to be tempted because you will spend the extra money. In the long run, the comfort, smoothness of the car is worth it. On paper they may seem close, but behind the wheel the MDX is something quite different.
The Touring package was well worth it, especially at only $400 more than the price for an MDX Base at the 'other' Acura dealer in town. Acura of Cleveland started at invoice price in their internet quote. The first trade-in offer was $900 under what both the other Acura dealer and the Honda dealer finally offered. We 'talked' and I got the net price dropped another $1,500 (don't know if the next $600 was off the MDX or onto the trade-in, don't care). This dealer says they are now the biggest in the tri-state area (OH, ? and ?) and based on their pricing I'd say so. Easy people to deal with.
No other toys added, might get a cargo cover or net; might get a sunroof deflector (does anyone think they really help in this car?) but that can wait until a) it warms up, and b) my wife lets me drive it.
