A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Acura MDX (pre-2007)
Other than that, driving on the roads covered with some snow and some slash has been very secure without no slips or slides.
That said, it's tough to find cables to fit the MDX's relatively non-standard tire size. Tried Sears and Les Schwab (the latter being a major regional tire supplier that carries lots of chains, with very friendly refund policies on them if you don't use them), no luck. Tried a few Internet sites. Called up the Acura dealership and they wanted $80. Pricey, but since I want them in the back just in case when we go over to grandma's for Xmas, may not have any choice!
Thanks for the tip
The A/C actually cools the air, condensing the moisture and trapping the water before it gets out of the vent. The vent blows dry air and no fogging.
Hope that helps.
Is there a way to change this default behavior to have the fan start at a lower speed in the full auto mode?
This thing drives GREAT! Computer says I averaged a little over 20 mpg (mostly freeway driving). Base stereo seemed just OK. Seats were very comfortable. I was having problems slamming the rear hatch hard enough for it to close properly. I noticed that my interior lights were not going off when I shut all the doors and it was because the rear hatch was not closed completely. Not too crazy about the parking brake but I'm sure I'll get use to it.
I was thinking about the extended warranty but needed more time to mull this over so I didn't purchase it at the time (I'm leaning towards getting it though) The dealer wanted $1650 (no deductible) for the factory warranty which extends the warranty to 7yrs/100,000 miles What do folks think about the extended warranty? What were other folks quoted?
Tomorrow I'm going to buy some accessories for this thing. Has anyone ordered the Fender Flares and installed these themselves? Do they just snap on/require glue? I'm also going to get the tailgate defector. Someone had mentioned a while back that it requires some drilling but that it only took them about 15 minutes to do it. Finally, has anyone bought the 6-disc CD changer that mounts underneath the driver's seat? Hopefully its already pre-wired to accommodate this.
Thanks and Merry Christmas everyone.
Thanks everyone for your responses and suggestions regarding using the AC in conjunction with the defroster. Seems goofy to me to be running the AC w/the heat on during the winter time as a default setting for the defrost. I've never owned a car *that made that decision for you* ... and don't like it. I've used the AC intermittently with other cars in the past and it will pretty much clear up the "fogged" areas immediately but generally I can leave it off and just run the heat up the windshield and that works fine -- that's in my other cars of course -- NOT the MDX. Perhaps it's because the windshield is SO big.
My original posting was more of an observation that the heat level and vent direction IS inadequate for melting ice off the windshield and side windows while the vehicle is in motion. Having the AC on could not possibly assist in clearing this exterior ice; although it probably would have some impact on "defogging" all areas of the interior of the windshield -- separate problem. The other point was the fact the wipers seem to be mounted too low to benefit from the heat produced by the defrost system. Generally the wipers will lay in a position high enough on the windshield that they will be directly above the air flow of the defroster vents -- resulting in heating the wiper blade and melting any ice that has formed on them. SUCH is not the case w/the MDX -- the blades are too low. If you have frozen crap on your blades --- enjoy it cause your defroster isn't going to melt it -- and when you need to use your wipers to wash away all the road muck that has splashed up on your windshield -- foget it cause they will be covered w/ice and will streak the windshield bigtime. So the question is ... has any one else experienced this OR am I just a big moron who has been driving for 27 years and can't figure out how to use my wipers and defroster correctly?
It shouldn't have problems starting under the conditions you described (e.g. it should start on the first try). Another poster here mentioned starting in much colder conditions in Minnesota, with no problems. Perhaps you might want to get it checked at your dealership?
scubaflex:
Don't know what to say, so far we haven't seen similar complaints from others driving in even harsher conditions. But maybe someone will peep up, along with their solution.
I've never been checked for the presence of chains at one of the checkpoints (Toyota Previa AWD, Range Rover, Subaru), and I've never been in any situation on the principal roads where I ever felt like chains were needed.
Regarding getting the right size chains/cables for the MDX - you only actually need to put them on when conditions get to R3, and, as I understand it, the highways are usually closed by then. I suspect that you'll never actually put them on (unless you live up there and need to be out and about in the most severe conditions), and I also suspect that the CHP would never check to see if the sizes of the chains match the wheels/tires. So....
Now there is a remarkable simple solution discovered by an engineer named George Platter. He presented his method at the prestigious Society of Automotive Engineers. The National Safety Council tested his theory and discovered, to their amazement, that it works! The method has been tested and fully endorsed by the National Safety Council as described in their September/October issue of Traffic Safety. Here's how it works.
First, forget how we learned to adjust our outside mirrors by plopping behind the steering wheel and turning the mirrors so that we just saw the side of our car looking back at us in the mirrors. Instead, adjust the driver's side mirror by resting your head against the driver's side window and then turning the mirror so that you just see the side of your car. Once this is set, move to the center of the vehicle and turn the passenger side mirror so that you can just see the side of your car from the center of the vehicle. That's it. You won't see your own car in either mirror, yet what you will see is far better. Cars behind you show up as usual in the inside rear view mirror above the dash, but the instant the car leaves your field of vision from the rear view mirror the outside mirror picks it up. No. blind spot; no delays; no wondering where that car about to pass you has disappeared to--and no waiting a few seconds for the car that you just saw in your rearview mirror to show up in your outside mirrors. All three mirrors work in harmony with one another, and the blind spot has been eliminated!
I'll try this myself. Kenyee, if your method is different, let us know!
It works very well for the ML's blind spots which are worse than the MDX's IMHO. The BackSee lens fixes the blind spot that's covered by the hatch for the most part unless someone/thing is resting directly on your bumper.
p.s., you could avoid using the Spell Checker...people always wonder why I never have a spell checker installed on my system ;-)
R3 conditions means that you have to have cables/chains including 4-wheel drive and I do beleive its all four wheels. After driving for many years in the sierras I have yet to drive under R3 chain controls even in the worst of blizzards.
Here is the official CALTRANs winter page that talks about the r1,r2,r3 chain controls. For some tips check it out.
http://www.dot.ca.gov/hq/roadinfo/wntrdriv.htm
BTW, can somebody educate me what IMHO is?
What car did you own previous to the MDX? Do you find the width of the MDX a handful when parking? Does it feel car-like. I currently own a 2001 CL-S, and I've got the itch to perhaps trade-up to get the all-weather capability of the MDX but I'm concern that I would miss the smooth power of the CL-S.
I drove Accord94 EX and used to park it with my wife's BMW328i in the garage. Now after the DX, I am out. Fortunately we have a NV parking space next to the garage, so far DX is there over night.
Ye, the DX is wide. As it's still brand new, I have to park a mile away if the space is narrow. For bigger space like in Costco, I don't need to do it.
Comparing with those Subs (Sequoia, 4Runner, QX4, Explorer sports Track) I drove (or test-drove) before, DX is much car-like. But DX 300 is a little better than MDX, just IMHO. The 01 CL-S? can't be compared with MDX in car-like. MDX is power smoothy but bumpier than most sedans for sure. But I like the feeling.
4WD from 2WD vehicles. The Colorado
Chain Law permits 4WD vehicles without chains provided they have proper tires.
Press the reset and select button for the odometer at the same time for about 10 seconds.
The outside temp will then change to numbers from -3 to 3.(-3, -2, -1, 0, 1, 2, 3)
Depending if you want it to go up or down, release on the number you want.
If you want it to go down 3 degrees, release on -3, and so on.
If you want to do more than 3 degrees, do it repeatedly until you get what you want.
I hope this helps.
How many times do I have to log in to post one message??!!
Anyway....
I just got a call from my dealer. Apparently, the factory was backed up with orders to NYC for December. I put my order in on November 15 and I'm hoping that it will be here before the New Year (hey... don't make fun of me.....a guy can dream, can't he?)
I have a car for sale now..... any takers?
I will be back with comments on how it handles here in NYC. West Coast and East Coast experiences seem to differ slightly. I want to see for myself.
Happy Holidays
>a new V8 will first appear in RL(2002?).
yes, that is what i hear they are planning on
>Then it'll show up in the MDX(2003?). I
Well, maybe. I'm not sure if they will put it in the 2004 NSX before the mdx or not.
>t'll be targeted on ML430/X5 4.4 instead of ML55/MX5.
Yes, i am aware of that. What i meant was that a v8 TYPE -S would compete with the ml55 and the x5m or whatever bmw is gonna call it. If you think what acura did when they "type-sed" the 3.2 v6 engine, by adding 35 more hp (i think), just think what a tupe-s v8 could do. I just can't wait untill 5 years from now in a motortrend article comparing high performance suvs: "SUV SHOOTOUT!! we compare the ml55, the x5m, ACURA MDX TYPE-S, porsche cyanne, and the ford svt expedition lightning."
well, i tried posting last week but it didn't show up on the screen. damn new software:-) i'm in michigan and we got six inches of fresh snow last week. i got up pretty early and was able to test it before many others were able to get on the streets. it performed marvelously. didn't hesitate at all as it plowed through the undriven road. it doesn't even have trouble going from a dead stop in really deep snow. however, like any other cars, it does slip a little when breaking and the abs really pulsates. but at no time did i feel unsafe. i also drove it later in the day where the roads were still covered, but others havd had driven through. again, no problems at all. didn't experience any fishtailing or sliding sideways.
like someone else mentioned earlier, i also have the abs light go on if the front passenger is leaning forward or something. is that a problem that should be brought to the attention of the service dept?
as for oil change, i signed a liftetime oil change with my dealer for $129. it not just the lifetime of the mdx, but for any acura i may also buy in the future. and i can change oil as often as i like.
If you mean the SRS light (airbags), and not the ABS (braking), and it happens when the front passenger leans forward, then it's not a problem. There's a sensor that tries to determine if the front passenger is too small or too close to the airbag.
There have been similar "complaints" from folks who have a bag sitting on the front passenger seat in a certain position.
This Link
Rail
of things I've tried:
The following was posted on the old forum after the cut over.
Got my VIN number on Dec 13th, hopefully my baby MDX
is delivered before the holiday.
Here is a check list based on the inputs from many
of the current MDX owners in this Edmunds
townhall:
1-look for orange peel paint
2-the mileage on the car, to ensure is not a demo car
3-the accessories purchased
4-free tank of gas, promotional gadgets, leather
cover for the user manual
5-w/o rust proof under-coating still under
warranty
6-the extended warranty can be purchased later or
elsewhere
7-pick up the do-it-yourself accessories at the
parts department
8-Break in period is the first 600 miles, no hard
breaking (first 200 miles), avoid full-throttle
starts and rapid acceleration, Premium gas
preferred, drive 55MPH or below .
9-first oil change ~3500 miles
10-first VTM-4 fluid change ~ 7500 miles
11-submit your dealer survey and provide dealer
rating at www.acuramdx.org
12-continue to provide feedback to this conference
after you became an 'official' MDX owner
13-park your car on 2 parking spaces to avoid door
dent
14-expect other drivers to check out your car
15-expect some noise either from the wind, glove
compartment or the 3rd row seat.
16-expect 5 stars from the crash test for the
MSRP(or more)price we paid.
I would like the MDX owners and buyers to the waiting wasn't easy (2+ months) but it is
finally coming to an end for me.
I agree with the new software critics - simplier the better. Edmunds town hall used to be THE place to go just for that reason. Guess what? The tribe may just pack up and move to another valley one day. I am spending more and more time in the other dot org place.
Also, to answer some of the recent questins I am posting my collection of the MDX tips and tricks I've cut and saved over a couple of months, so get your author rights layers ready - here it goes:
#211 of 322: insurance (andyn2) Fri 27 Oct '00 (11:57 AM)
Got my base model MDX last week. I just got it
insured with Farmers Ins. for $325/6 months with
$1000 deductible. Also quoted for $388 with $500
deductible, $418 with $240 ded. and $464 with $120
ded. I live in Glendale Hts, IL 60139. I was paying
$242/6 months ($1k ded.) for 1993 Sable before. I
don't know how are the quotes compare to every body
else, but I think it's reasonable for me.
#221 of 322: Hondacuraworld (jhw01) Fri 27 Oct '00 (02:07 PM)
Just contacted Hondacuraworld, their prices are
about 5% cheaper than AHMotors and if you order
enough, they will ship them free for you. Not bad.
Has anybody had any experience with them before?
They are Ray Laks Acura based in Buffalo, NY.
Tim P.
E-Mail: hondacuraworld@aol.com
Phone #: 716.826.4109
Web Site:
hometown.aol.com/hondacuraworld/myhomepage/business.html
The sunroof
visor was also pretty easy...just a couple of
brackets. I also bought Prostripe 1/2 round 1 inch
wide molding (M941202) and put it on. I
positioned it using the lines where the front and
rear bumpers meet the upper body, so it looks like
it actually belongs on the car.
Prostripe is owned by Avery-Denison, the label
people. They have their own website,
www.prostripe.com. This site has a distributor
listing; I found a few of their dealers in my So.CA
neighborhood so I will be contacting them for an
install price.
JDFord has more guts and experience than I do so
I'll have the auto body guy put the molding on -
the last thing I want my wife to say is, "Gee, it
looks kinda crooked, doncha think?"
Leather fails? What does that mean? It is skin,
you know, and has to be cleaned and conditioned
regularly (ideally every 2-3 months). If not, the
leather will dry and the creases will be very
obvious. It may even crack further down the road.
It will not be covered under warranty since its due
to lack of care (considered wear and tear).
Use a good product such as Lexol cleaner/Lexol
conditioner, and you should be fine. The protection
package is a waste of money since it will wear outafter a couple of months.
Simply follow the detailed step-by-step
instructions (with pictures) at www.lexol.com and
you should be fine. It's basically like washing
your face with a soft cloth. No special tricks
needed to cleaning perforated leather. I recommend
that you clean/condition the leather around the 1st
or 2nd week of December. The protection should
last all the way till late February. Remember to do
the leather steering wheel as well.
#198 of 216: Invisible Bras (railr) Mon 27 Nov '00 (02:06 PM)
A search with Google.com led to:
http://www.xpel.com/
They don't appear to have an MDX bra yet.
To be prepared, I applied for PeopleFirst auto
loan. Got approved in 10 minutes!!! Incredible.
Their "Blank Check" is "in the mail"
;-). Good for 45 days. I hope there will be NO
SURPRISES with the dealer's estimated delivery
time!
Based on earlier posts from today, I also checked
e-loan, which actually had better rates (7.3 vs
7.9). I called PF and they gladly matched! What
an incredible customer service. I wish some Acura
dealers learn from them!
I've been in contact with Thule US. The've
confirmed in writing that THULE is the OEM Supplier
to acura fo
For the rear splash guard, someone mentioned that you only need to put 2 screws (the screws were already on the car). However, the splash guard has 3 holes (like a triangle) and the lower one is the one hard to get to. (directly behind the tire)
how do you index to a particular or a range of postings to look up references ?
How do you print a ranger of postings (more than 20) ? When it gets busy at work, the only way to participate with the interesting discussion is to print them and read them on the bus.
Additional features (such as the jump to a specific post feature) may be activated after we squish the intial bugs. The login/timeout bug, for example, is top priority.
Thanks for your understanding!
Drew
Edmunds.com Townhall co-host
Vans and Aftermarket & Accessories conferences
I'll launch my empty shopping carts to. Ooops, sorry about that.
How about instaed parking out in the distant and walking your lard a** in!
