Visitor Agreement.
According to my detail guy, this is the only Lexus model in black that does not have a such a clearcoat.
I don't know why this is but the advantage, according to Mr. Detail, is that there is more layers of black paint vs. other colors that substitute the final clearcoat layer instead of another color coat.
I've had lots of black vehicles and in several of them the clearcoat becomes "crazed" with spider-type lines and it eventually separates from the underlaying paint color; as you can imagine, this becomes a major headache if it happens out-of-warranty.
Also, on clearcoat vehicles, you have to be very careful when using any wax or polish that is the least bit abrasive - if you damage the clearcoat, game over. So the black RX has an advantage of all those black paint layers to detail out surface problems.
Hey Willard - how's that for content, dude?!
By the way, that stuff on the printing press was written by other people and I thank Host Steve for reminding me to give credit where credit is due.
Personally, I read several books a week on the engineering theories behind AWD and HVAC systems in past and present day motorcars and trucks.
Steve
tidester
SUVs; Aftermarket & Accessories
Pete
You can also advertise your old tires in the local paper. Putting on Bridgestones (my first choice) or Michelins will make your next 50,000 miles a lot happier. I swapped out all 5 Goodyears for Bridgestone Dueller HL's, mounted and balanced for $300.
The faster you do this the better. Good luck and let us know how it goes.
Premature failures. Anyone handling a halogen bulb knows not to handle it directly as the small amount of oil from your fingers will result in premature failure due to light blockage.
But I must admit that the Goodyears seem to wear longer than the Bridgestones.
Just my two cents.
And may I extend kudos to Willard who, as far as I can tell, was first to mention this problem oh so many moons ago??!
Kudos accepted with grace and gratitude.
The Integrity and Dueler HL have the same treadwear rating so should last a long time. The Michelins always wear great and will probably outlast the other two.
Finally, it is my belief that the well advertised Michelin name benefits from a self congratulatory halo effect at places like TireRack. Probably no different than we do with our RX-300's.
To moretorque, the DRL are the same bulb as the high beams.
Since the RX factory fog lamps are useless I've been thinking about getting a set of those dual mode PIAA fog/driving lamps, replacing the "driving" bulb with the european DRL bulb and wiring those into the DRL circuit and then setting up the fog portion so I can have true fogs, amber tint and operation without headlamps.
Sorry, all, for posting misinformation.
Interestingly, no failures of high beam bulbs in wifey's 99, which is now over 4 years old with 47k on it.
Well, from a technical perspective it actually would, as the high beam lamp is then supplied with its full share of voltage for which it was designed. I guess, it would also make it somewhat difficult for oncoming traffic not to get blinded. If you want to appear to fellow drivers like you're driving a Saturn, buy a Saturn.
Tarik
In the GS there was an option to bypass the resister for Canadian use. I wonder if the early RXes didn't use the resister? Could it be that simply bypassing the resister would provide enough heat to initialize the halogen recycle process?
Anyone have the shop manuals for the 99 RX and can look in the elctrical section and see?
That may or may not be the case but I'd be very surprised if it were true. Lasers are highly monochromatic and the amount of light the headlamps emit within that extremely tiny band of wavelengths is minuscule.
tidester
Re DRLs, BMW pulses the high beams to illuminate them for use as DRL, would that eliminate soot?
Tarik
It apparently does not accumulate to any significant degree with time or I'd expect either hi temp failure or at least diminution of light output as result of thickening deposits.
And thank you, Tidester and Tarik, for discouraging further light pollution by continually operated high beams; even in daytime they are quite annoying. jiamin is correct in that it is illegal in many areas to operate high beams (usually within any city limit).
Didn't we, in the US, go through a phase of folks complaining about DRLs being too bright? Was the resister added to overcome these complaints.
Tarik
Oops, that was on the GS.
Can't remember now, buy I'm lazy enough that if a simpler solution were available I would have taken it. DRL fuse removal also disabled something else?
DRL Fuse
DRL No. 2 Relay
DRL No. 3 Relay
DRL No. 4 Relay
I don't see any mention of a resistor in the location diagram or troubleshooting section, however; there is no wiring diagram per se. That is contained in a separate publication "RX300 Electrical Wiring Diagram Manual" Pub. No. EWD337U.
Pete
probably no sooting with those voltages, though.....
Autonet
Pete
150K ? I'm just curious if the drive train on these babies can be expected to last that long.
(I'm the proud owner of a '99 AWD with 45K and a '01 FWD with 33K.)
Thanks in advance...
Any ideas on what the problem could have been? For what it's worth, my wife filled the tank earlier that Saturday before parking it in the garage.
And any advice on the dreaded glove box rattle is appreciated, too. I've tried to fix it with rubber pads and bending the latch, but bending the latch is scary and makes the door stick.
I heard the term "vapor lock". In summer the high temperature turns water (there is always some) in gas tank into vapor and when it's too much the gas will not be continually pumped into engine. My gone 86 Sentra suffered from this. Within almost 6 years my gone 96 Maxima didn't start twice but after giving a little gas it started immediately with no other problem at all.
Love my lil Lexus ...
to know and may do the same.
