Visitor Agreement.
I guess in the meantime if we want to truly hear the high fidelity of our expensive ML audio systems we'll just have to continue to invest in tires with noise canceling tread designs.
The anti-noise idea is great, but what about when the system fails? Will people go off the road b/c of the instant assault on their ears? <tic>
I do appreciate the comments y'all have given re: the RX.
Darn, just can't get that song out of my head...where was that again?
There it is - Post #7353.
You know, the one who kept trying to use white-out on her word processor screen.
Third - guess all you Blond/Blondes out there are Happy Now, right?
What next, Willard - Polish jokes?
When referring to women of a certain hair color that adjective should never be spelled "correctly".
It just confuses them.
Has anyone else had this problem? What was the cure?
Also have never had to add oil between oil changes. Has anyone had to add oil? Makes me wonder why I bother to check my oil between changes.
Is the 330 worth the change? I have only 45k on my 300.
Can anyone help me out on this one?
Know nothing about 03 RX300, but could it be a programmable thing in CBEST? If yes then only dealer can do it.
Does anyone run into this problem before? How to get the warranty from Lexus ? Insurance will pay, but I will spend more $ to get a new car + tax. Any advice is appreciate.
And made no mention of the fire that took place 3 days before - resulting in a total loss?
Just curious.
I already now the answer the rx300 using the timing belt, but not sure about the new RX330.
It's time to buy a car, therefore I posted the question for new RX330.
Please go back & read my message and READ SLOWLY.
Actually, my question was, why didn't you make mention on 4/28 that your RX had totally burned three days before...instead of waiting until today?
I mean, regulars on the RX boards never hear of such fire-for-unknown-reason cases and I know, speaking for myself here, I would be greatly interested in the cause, whether it's a dropped ciggie or some electrical problem in the wiring.
Hey - could it be that defective design in the windshield defroster? That's my bet.
No matter - sure hope that insurance money will cover most of the RX330. Good shopping.
Proving it's a warranty defect will probably be a painful and expensive route, if indeed it is. It will be interesting to see what the regional rep comes up with.
BTW, you weren't running those crappy French tires, were you <G>?
Pete
If everyone quits buying Michelins, what's going to happen to the union guys making tires in Tuscaloosa?
Not to mention, Opelika, Woodburn, Kitchener (for our Canadian friends), etc.
How about we stick to the Lexus and leave the politics to other forums? Merci, and Happy Cinco de Mayo (hehe - get it?). :-)
Have 73,000 mph on engine, did NOT get the 60/65K belt etc maint on the car--Dealer wants to charge $1,400 for this service i know my belts need replacing too. Do other mechanics generally know there way aroung Lexus' or should i bite the bullet and let the Dealer do the service ? Also, since its past the 65k and approaching 75k what else should i service now ? Thanks.
Hummer Guzzles Gas
Pete
Also, which part needs to be replaced for the squeaking steering wheel? I've had the boot lubed twice already and the squeak has come back again.
"Be careful when accelerating, up-shifting, downshifting, or braking on a slippery surface. Sudden acceleration or engine braking, could cause the vehicle to skid or spin."
NOTE: "ENGINE BRAKING"
(DO NOT LIFT YOUR FOOT FROM THE THROTTLE QUICKLY!)
Or else quickly shift into neutral.
The Sequoia is predominantly a RWD biased vehicle, what did you suppose will happen with a FWD or AWD with front torque biasing?
Same manual, Page 143, center column yellow high-lighted CAUTION note.
"Under certain slippery road conditions, full traction of the vehicle and power against 4 wheels (4WD mode) or rear wheels (2WD mode) cannot be maintained, even though the active traction control system is in operation"
I read this statement as verification of a firmware time-out to prevent the ABS pump/motor from being over-taxed and over-heating due to continuous pump activity requirement.
This statement would likely also apply to ANY Toyota or Lexus vehicle with ACTIVE Trac and/or AWD using braking to apportion torque, HL, 4runner, GX470, RX300, RX330, Sienna, and obviously the Sequoia.
You likely have only about 45 seconds of continuous Trac or AWD "duty", then you're left with a vehicle that has 3 open diff'ls.
And obviously the ABS and VSC would now also be non-functional until the time-out expires (unless you need to do a restart cycle??) and the pump can again be activated.
Now, how does that "gravity" thing work again?
Not lifting the throttle is a no-brainer if you live in a snowbound state. Newton's Laws become all to real when you have 0.10g of grip, or less.
lol, Jeff.
I am going to bring this vehicle in to a dealership nearby Monday. Does any of you have the experience? I got this car used about 3 months ago, and this is the first time I notice this problem.
Thanks for the advise. I heard about this sludge problem also a while ago. what will one feel when a engine has Sludge problem? I am sure the car was oil changed regularly.
I was driving Sunday and noticed the noise become louder if I turn left, and gone if I turn right. It is quiet sensitive, so even I turn 2 degree on the steering wheel, I can notice the difference.
The stock tires are Bridge Stone. which I can not imagine can wear out in the inside of the tire and create such problem. I had Bridge stone tires before and they are great, but they are for my accords. Maybe I should get M/L C/T tire for my RX. they are like $150 each, kind of expensive.
Dealer also suggest maybe the car need alignment. To which Lexus charge $129 for the service. I can get it done outside for maybe $40. but I really don't want to do it if I don't have to. Is there a way to find out if my car needs alignment? I let the steering wheel go while driving stright line, I don't feel any pulling to the side, does that means I don't need alignment?
Thx
