As far as I can tell, there's no rear differential. Did you mean "G" would be third character in VIN of two wheel drive?
Thanks again for the help.
I was wondering if anyone has had to replace a master key. y car came with only one key (master) I'm thinking I should probably get another one in case of loss, breakage, etc..
I know the dealer charges big$$, also where are the key code #s? like I said, I only have the one key.
Thanks a lot for the help.
Pete
Thanks for the help.
I found this site that was very helpful:
http://rx300how2.home.comcast.net/side_markers.htm
hope this helps!
It seems he's been compiling his DIY notes and took the time to post them on his website for others to see and benefit from. I added the link to my CarSpace favorites.
I'm going to need front brakes soon. Does anyone know of a good online car parts store?
Thanks for the heads-up.
I've ordered brakes. Also CEL just came on, the car gets inspected tomorrow so I'll ask the guys to pull some code. I cleaned the MAF although it didn't seem too bad,but I figured I'd wait before I re-set the CEL.
Also regarding your CEL. Most common cause is the gas cap not on good. Second most common seems to be when someone opens the top on the air box to check the engine air filter they disconnect the hose located directly behind the air box and below the brake fluid resovoir. Other than those 2 and the MAF, you will need codes.
I'll let everyone know what turns up.
When I got my car, it came with only one master key. I've read about how flimsy these keys are (and expensive) I came across a great site: sparekeys.com you can have a shell key made for $60.00. When your cheap original breaks, just slide out the "brain" from the broken key and drop it into the new shell key, now you have a new master key that they promised me is much stronger than the original. Also, I did not have my key-code available so I called them, nice people, and really helpful. All I had to do was give them my VIN#, address, credit card# and the key goes out today.
Still waiting to hear about my CEL codes. I'll spill my guts when I find out.
cheers
The site is: sparecarkeys.com makes more sense now. Sorry for the goose chase boys and girls.
I picked up my car from the mechanic today. (2000 FWD rx-300 81,000 mls.) Code shows: p1130
p1150 two front Oxygen sensors: bank 1, sensor #1 bank 2, sensor #2
He re-set the CEL and said everything is fine on the car. He will install sensors if I want them...do I? Is it a real need? I had a BMW and the mechanic used to just re-set all the time and I was fine.
Also, I was wondering about the oil jelling complaints. If a lot of owners are taking their cars to the quick change places for oil changes, tranny, etc... I know the oil filter on this car is a B**** to get to. So, that said, I would bet a lot of these places are skipping the filter change and just replacing the oil...IMHO maybe I'm wrong but how many of us check to make sure? Hmmmmmmm :confuse:
Pete
Graham
Forgot to mention this to the service dept, but after the service, it is completely gone. I paid $458 for this service.
My RX300 has very low mileage, 43500 mile now. So far two failures. (1) the "D" bulb went out a few weeks ago and I replaced it; (2) the door lock/key fob control failure which costed my about $600 for the module replacement.
Also yes, I paid too much for the 45K service. That dealer just moved to a brand new place, much larger and nicer looking. They need to collect money from customers like me to pay it off, and the ES350 free loaner is not actually free...
My car will need oxygen sensors soon. I've found aftermarket sensors but how difficult are they to install yourself? Code shows: p1130
p1150 two front Oxygen sensors: bank 1, sensor #1 bank 2, sensor #2. Does this mean they are ahead of the cat converter ?
Graham :confuse:
I'm at my wits end and hoping with all the knowledge on this site I can get a straight answer. I bought my husband a Skifi2 for Christmas. He originally set it up using the cassette adaptor, but the cassette was constantly popping out on him. Called Lexus to see if it was a problem with the cassette player or the XM and they said they knew of no problems with the cassette player and to try cleaning it. So off we went to buy a cassette player cleaner. Cleaned, cassette still popped out. So we tried the FM route. Here in the Dallas/Ft. Worth area there are just too many stations. The interferance is horrible. Cuts out all the time. Went to Best Buy and got a FM Direct Adaptor. The installer says that it only works on the Lexus vehicles 50% of the time. He said they spoke with Lexus and that there's a problem with the FM stations interferance and that's why Lexus stopped putting XM radios in their vehicles. Huh? Don't know what to do now. Get the adaptor installed and see if it works? Forget about the whole darn thing and stick to CD's. Hubby does love the XM, just wish we could get the darn thing to work consistently. I've got an appointment to get the adapter installed on Friday. Help!
Thanks in advance. Sherry.
I'm putting Sirius satellite in my car. I had it in my Infiniti and it worked great, I've never heard of your problem before. I do think the "cassette" type installation is not the best way to go, even with a frequency available it's sketchy at best.
The adapter should be ok, and you should be able to find an open frequency with ease. Now, as far as XM tech, that may be a grey area, Sirius recievers do a better job I've found because I've owned XM as well. Maybe the coming merger will address the problem if it does exist. Sorry I couldn't be more help but you're moving in the right direction.
Chances are your CEL will come back on soon. How many miles does your car have on it? It will probably show codes you should have your mechanic or your local Autozone (they will read code for free) It may be your co2 sensors which won't really cause performance issues aside from loss of fuel economy by 2-4 mpg.
I got only 44K miles. I will certainly check it once I see the CEL again. Actually I should have checked it before I reset it. Now I have to wait...
By the way, I was just told that on some cars/makes when CEL is flashing, it indicates a more serious problem than just on.
By the way, ealrier I posted the back gate support getting weak. When I open the gate half way up, it should go all the way to fully open position. It does not. However, if I push it up and pull it down a couple of times, it seems to work better but still not like when it was new. It's kind of like the lubrication issue. I just leave it as is and hope it won't suddenly drop on my head...
You are a good predictor.
My CEL came on yesterday. I bought a cheapest scanner and it reports P0171, a pretty commom code I have read online.
Last time I "cleaned" the MAF sensor. After I read more closely how to clean it, I found that I didn't clean anything at all! I didn't even know what is inside the sensor! Therefore, there is still a chance that after I clean it, it will work.
I will report my result in a few days.
Good Luck... MNF
Question: if I don't reset it, the error message will always stay, after the problem is fix, correct? If yes, I think the circuit should be designed so the error message will be eraised automatically by the new cpu signal.
MNF
Some of my friend said that every time after the dealer service, there is always issues like this. Is dealer trying to make more money by doing this?
Pete
I saw there is another round connector with a lid, next to this OBD connector. I don't know what that is but my best guess is it is for technician to program the "CBEST".
Also good to know, a replacement is not so expensive anymore. Most of the aftermarket companies are making them now. Bosh, Wix, NPN, Denso to name a few. AutoZone has the Bosh for about $15. AutoBarn also has it online. Also here is a link to the NPN for less than $15:
http://catalog.drivewire.com/drivewire/baseline/wizard-newest.jsp?partner=drivew- ire&year=2001&make=LX&model=RX-300-002&category=All&part=ACC+Cabin+Filter
I'll wash it today.
Pete
The solid state controller for the turn signal flasher relay has a current flow sensor that will cause the controller to FAST flash if the current flow indicates a bulb failure. You have to change out this nichrome resistive link so the low current of the LEDS does not trigger a bulb failure flash rate.
Same thing with the stop/tail/high mount bulb failure sensor module in the driver's side rear quarter panel, except there are three sensor resistive links that must be changed out.
Or you can simply ignore the rear bulb failure indication on the instrument panel or tape it over with black electrical tape.
Sounds like the turn signal replacement is a bit too much work for me. I'll probablly start with the stop light. Also the interior reading and dome light, so that I can leave them on for long time without lots of heating.
I replaced the mid-dome light, just behind the front seats. with a Ford map/dome overhead (see Ebay auction #220103570956) that has left and right map lights w/individual switches and center dome light.
Wired it with a transistor and diodes so the map lights come on and off (slowly) with the dome bulb. Rewired the front dome/map switch so it turns on the passenger map light on the Ford unit.
Used 3 Luxeon 3 watt leds with limiting resistor to limit current to 1 amp. You will need good heat sinks for those 3 watt Luxeons though.
Lots of LED bulb/lamp/fixture stuff available will fail within 24 hours due to insufficient heat sinking. LEDs overheat and reduce in brightness without proper heat sinking.
Basically didn't care for the Lexus front map light that helped blind me when on at night. Much better with the passenger, DW, map light from behind.
The mid dome light has a fading feature. Does your new LED light still have that? It is not a big deal to me, but nice to still have it.
Darling base driven directly from the existing 12 volt dome power, collector to 12 volts and emitter to the anode of the two diodes, diode cathodes connected to each "map" light.
