Lexus RX 300
1175176178180181183
  • la4meadla4mead Member Posts: 347
    P.S. I think '02 might have been the best year & most refined for the first gen RX 300. If the one you're thinking of buying is a "Silversport Edition", I think you might even like it more. The "Coach" has nice appointments, but no real mechanical differences.
    I don't believe there was an '03 MY. The 2nd gen '04 RX330 was introduced in '03, with more/different bugs than the '00-'02's had. I think they got better again in '05, and then later the RX350, which had a lot of improvements. But any year/model you could get a really nice car, as long as you aren't looking for sharp handling.
    And it's pretty easy to add additional tranny cooling. And have fluid changes done with the right fluid (not corner lube and tune-up places!) as previously said.
    If the seller has records, that's great, but if it only has 22,000 real miles, it's doubtful the pan's ever been dropped for proper service, and there could be stuff to look for on a car that sat so much without daily use and/or only went a few city miles at a time! Oh, by the way on a car that sat, especially look for all power locks to work smoothly, good battery, and oil changes at proper intervals regardless of mileage.
    Keep in mind that a "smart" dealer might disconnect the battery long enough for the engine & transaxle parameters to reset to the factory defaults and then it will take as much as 500 miles of "test" driving for the ECU to relearn and/or adjust the parameters, parameters unique to "this" particular vehicle.
  • la4mead
    Not sure if your comment was meant for me or not. "not corner lube and tune-up places!) as previously said." If not, I apologize for assuming. By no means do I recommend chain lube places or non researched private mechanics. Mine has been great for twenty years, builds and races race cars, and uses only the proper parts and fluids. You don't need to pay dealer prices to have the correct fluids put in your car or receive good maintenance. He has taken great care of all 3 of my vehicles. Didn't mean to get off topic and your other points are excellent observations.
    Ken
    I was just referring to previous discussions in the RX thread on the same tranny service topic, and information for the whole group. Most lube places don't use type IV fluid for the transmission. Most use Dextron/Mercron and an additive to approximate the Toyota fluid, if they look it up. Most mechanics as well as auto parts stores, and even transmission shops don't stock Type IV, either. But they can get it if they order it ahead of time along with a Toyota filter and gasket, usually from the Toyota dealer, but Type IV can be gotten elsewhere with a little planning.
    If your corner mechanic uses the right stuff and is competent and reliable, that's what you want. I meant the remark in only helpful, general terms; no offense was meant, or taken. Yeah, although still worthwhile, a Lexus dealer charges a lot for transmission service, when you can get it elsewhere. I usually use the same reliable Toyota dealer (Hamer in Mission Hills, CA) or transmission shop where I've gone for years. Also as a heads-up for some, mine unexpectedly needed more than the three or four quarts it's supposed to need after a change. I think mine took 5 after the fluid (not torque converter) change for service. They ran short. Maybe because it's a newer model transmission.
    Cost being an issue, I'm a DIY, but I don't think you'll save a lot DIY, after the retail cost of fluid, filter, and gasket, having to dispose of your own, etc. I think they earn the labor charge, if reasonable. But in this car, I'll only go a year or two (and I have extra cooling) before changing the tranny fluid. But if anyone is interested, this guy (I don't know him) has excellent advice and shows step - by - step the transmission fluid change, as well as lots of great info on RX300's:
    link title
  • irishcaseyirishcasey Member Posts: 36
    la4mead:
    You mentioned "Silversport Edition" and "Coach" edition. How would I tell whether the one I am considering is one of these additions?
    Also, do you know the dealer cost to add the transmission cooler?
    thank you.
    wwest
    Can you expand on your comment about a smart dealer disconnecting the battery. I didn't really follow that. Would this reset the engine memory so that it adapted to a new purchaser? Would the dealer charge for this?
    Please explain and thanks.
  • Both editions are great. But made in limited quantity. Not sure about the Silversport but the Coach will have coach emblems on the outside toward the front of the front doors, perforated leather, and one solid color. Not two tone. Birdseye maple wood trim. I think the Silversport is also one solid color.
  • Thanks la4mead,
    I thought that was the case. My mechanic is great, I'm lucky.
    Thanks for the RX How To sight link. I found that a few years back and learned how to change the in cabin air filter. But, lost the site. I re-bookmarked it. Great info.
    Ken
    The Coach Edition was a limited edition with different interior trim, single (not two-tone) paint, "Coach Edition" badging and some luggage.
    The Silversport had sportier interior trim and grille, perforated leather seats, sportier steering wheel, body colored rack cross bars, and a "sport" suspension (whatever that means from Lexus on RX300) with different stabilizers & struts. It also had exterior badging, but alas you have to supply your own luggage. I think it was only available in single-toned Millenium Silver or black, with carbon interior. Personally, I like the silver...
    I'm not sure what the dealer would charge to add an additional tranny cooler. "Trailer Towing" prep option packages were included on almost all models, which included an auxilery cooler that's proven to be too small for most driving/maintainence styles, even without towing. :sick:
    A transmission shop could add one; I wouldn't think it would be more than $100 installed, but I haven't checked. The shop I had my last service done recommended I add one, because he didn't see what I had done. When I showed him what I added, he said that was better than what he was thinking about, but good that I used that style, and very helpful for extended durability on RX300. They would have installed in front of the radiator/condenser. But Lexus specifically advised me against that, saying Toyota designs against the heat going back to the radiator.
    I purchased a compact, stacked-plate (54 plate) cooler called a "Defender" from a camper store a long while back for about $50. I installed it myself in front of the factory auxilery cooler in the RF fender, and easily cut the exit vent holes larger with an exacto. Easy enough; the hardest part was bending some brackets to use the stock mounts so I didn't have to drill. I also used the zip-tie style mounts, again very easy.
    Then, for an extra measure of redundant security, I added a small fan from an old motorcycle radiator in the inner fender blowing through the coolers, and an add-on Hayden adjustable thermostat from Pep Boys. It didn't take much tinkering, and the installation doesn't have to look good because it's inside the fender where you can't see it.
    Since doing that, my fluid has not been getting "burned" from temperature surges. I only notice the tranny fan after stopping the engine after stop & go or idling. I hope it helps, and I've found it couldn't hurt, and was not too much bother for me. :shades:
    When the car first rolls off the production line the engine/transaxle ECU is downloaded with a set of "best guess" factory default parameters. As the car is driven the ECU continuously adjusts these parameters to the actual tolerances of/for the various sensors, servomotors, etc.
    Disconnecting the battery will reset many of the "learned" parameters back to the factory defaults and then it might take several days, ~500 miles, of driving before the parameters are "relearned" yet again.
    And "this", the above, has absolutely NOTHING to do with purchaser/driver "learned" parameters, driving style/type.
    I'm not really sure, not convinced, that adding any extra AT F cooling capacity would be of any help. There is a thermistor within the transaxle that senses the ATF temperature and if it goes overtemp a light on the instrument panel will indicate so. It took 40,000 miles since new for the ATF in my '01 AWD RX300 to begin looking and burned to a level wherein I took notice and now I'm approaching 70,000 miles and I cannot say the ATF is yet looking or smelling burned.
    My conclusion is, has been, that the issue of the ATF overheating is localized, overheated within a very small section of the transaxle, and then when subsequently "remixed" with the bulk of ATF in the sump then on the average the ATF temperature is well within acceptable range.
    Also, while I haven't actually looked I suspect there is some sort of thermostat in line with the extrenal ATF cooler taht restricts flow unless the ATF temperature is up to, or even slightly above, operational range.
    So, since it appears that on the average the ATF temperature never rises to a detrimental level I just don't see how additional external cooling would help.
    I suppose one could re-rig the ATF thermostat to allow a lower temperature external cooling flow level but then might the ATF be continuously operating below proper operational temperature..??
    My guess is that the '01-03 RX300 models (and possibly mid-year '00) have an oversized ATF gear pump to compensate for the "abolition" of the ATF pressure holding accummulator and that's what, where, the ATF is being overheated.
    If you own an '01-'03 RX300 I would suggest as a minimum keeping a close watch on the ATF condition and do a drain/flush/refill when it begins to look and/or small burned.
  • arochaarocha Member Posts: 2
    The VSC and chk eng light came on at the same time in my 2001 RX300. I got the codes for the chk eng: PO440, PO441, PO446. It has to do with the evap emission control system. What should I do?
    Nothing likely wrong VSC, the VSC indication is simply a default as a result of the CEL.
    If you happen to remove the gas cap without refueling, only slightly refueling, or do not fully tighten the gas cap after refueling you will get evaporative emissions fault codes.
    Once you correct the problem, say tighten the gas cap, the faults will go out after a few "drive cycles".
  • jzaragozajzaragoza Member Posts: 1
    Thanks for your previous response to "rugmankc" on Aug, 21, 2005. I benefited from your wisdom as well. My "VSC" and "check engine" warning lights turned on. I don't recall if I had work done to it at the time I noticed it on, but I probably did. My little hose that's connected to the back of the air filter box was disconnected on my 2002 Lexus RX300. I reconnected it and immediately checked the warning lights again. The "VSC" light was now off, but the check engine light was still on. I disconnected the ground of the battery for 15 minutes and then reconnected it. Voila' !!! All warning lights were now off !!! Now I can get my car re-smog checked and pass the test this time! You're a life saver!
  • sam421sam421 Member Posts: 14
    Disconnecting the battery will reset the CEL back to the factory defaults. It might take several days, ~500 miles, until you can actually get the test done because the emissions machine knows.
  • dsalcedsalce Member Posts: 4
    The window on the passenger side of my 2000 RX300 does not ALWAYS open. This occurs when I try to open the windows from either the inside of the car or when using the remote key function. All the other windows always open. Please advise.
  • melanjianmelanjian Member Posts: 31
    i just got my rx 300 with 91,000 miles timing belt replaced, also replaced was the fan belt and the accessory belt. my question is, is the car supposed to run and sound exactly the same after the changes as before? cause it seems to me the engine sounds louder now than before or is this in my head?? all parts are oem.
    my wife says it has sluggish performance but i do not think so...
    any comments?? especially from w west, thank you!!!
    First, I NEVER fix something that isn't broken, most especially if I have to out source the work, non-DIY.
    The level of (in)competence at the service shops, Lexus especially, is such that you are likely to come away with more/additional problems that you went in with.
    Lexus dealer's service shops only have one MARQUE to rely on for service needs and as luck would have it that one marque turns out to be extremely reliable.
    So, why should the dealer's pay a premium wage to retain competent help when most of the work involves simple routine, REPETITIVE, work and many McD graduates are (presumably) qualified...??
    Obviously I'm voting for mis-timing of the new belt.
  • avery1avery1 Member Posts: 373
    I've noticed something similar. It was explained to me that the new belt creates different pressure on bearings so there is a different sound. I have no idea if this is true but I'm at 152,000 miles and no problems came from the sound and it either got better or I got used to it.
    Although it's possible, it's highly unlikely the timing belt was installed incorrectly enough (mistimed) that it caused mildly sluggish performance, unless the vehicle performs extremely poorly now.
    My guess is you are more likely hearing the difference in pressure from a new, tight belt on the older more worn moving parts (idler bearings, a/c clutch, etc.) from the drive belts being replaced. A slight difference in pitch might be normal.
    There could be other reasons for slightly more sluggish performance from the replacement of the timing belt other than mistiming it; other maintenance items that are now showing their weakness or need for adjustment. Or simply that it sounds different giving the impression of a change in performance.
    As Mr. West points out, there's always a possibility the mechanic failed to re affix a vacume or breather hose (which you would hear and likely affect performance slightly), an electronic connector, or something else fairly simple.
    I don't find Lexus mechanics on the average any less competent than any other ASE mechanics (actually maybe a little better than others), but being a DIY I always make a good visual inspection and have found things forgotten before. There definately are Lexus shops I stay away from, so like anything else, your experience may vary from one time to another.
    Once long ago at a Toyota dealer I trusted (not this car) I drove off the lot after routine maintainence, and pulled over to do my check. I opened the hood and found a rag where it could have been caught by the fan belt, a screwdriver resting on the front radiator brace which would have fallen in, and a mirror the mechanic used to see up from underneath.
    Independent shops tend to be much worse, or sometimes more careful. I think it just depends on their work load and QC.
  • pschiffepschiffe Member Posts: 373
    I've had good results having mechanical work and routine service done on my RX300 and RX350 at various Toyota dealers. Same parts and level of competence often at half the price. No free loaner or gourmet breakfast but I can live with that.
    Pete :)
    thank you very much for you timely replies and w west whom i respect utmostly
    since i have read all of these posts thru the years!!! Took it out today and it seems to perform fine.. yet at idle the engine sounds louder when i open the hood and listen to it.. maybe it is the tighter new belt(s) vs the 91,000 mile original belts?
    Toyota dealers have a MUCH larger "fleet" to work from, and maybe a less reliable one to boot..??
    Additionally many Toyota dealers have multiple marques for sales/service whereas Lexus never allows that insofar as I know.
    I haven't yet looked but I would be extremely surprised if the timing belt doesn't have a spring loaded idler to maintain relatively "constant" tension over the life of the timing belt. Obviously a brand new belt would have a different sound but it seems to me the sound(s) of the timing belt, regardless, would be swallowed up, over-shadowed by overall engine "noise".
    On the other hand when my '78 911 was retrofitted with the hydraulic chain tensioners I didn't get off the lot before turning around to go back and ask if the NEW noise was proper.
    On yet another (third..??) hand a mis-timed timing belt would undoubtedly result in a different "noise" signature.
    Revision...
    Learn something new every day.
    "My guess..." "oversized ATF gear pump.."
    Was probably, most likely WRONG.
    All Lexus needed to do was raise the PWM duty cycle, power level, to the solenoid controlling the ATF line pressure so line pressure was held at a higher pressure level CONSTANTLY. That would allow them to prevent the premature clutch failures being experienced with the '99 and '00 models but would also result in a higher overall heating level of the ATF for the '01-03 MY. Obviously Lexus knew in advance about, and attempted to compensate, for the higher heating level by including the towing package on all '01-03 RX300's.
    where is the air fuel ratio sensor located on a 2001 rx300?
    There are two, in the exhaust pipe just downstream of each exhaust manifold. Oxygen sensors with self-heating capability are now being used as A/F sensors.
  • chikoochikoo Member Posts: 3,008
    How much should it cost to resurface the front rotors of a 2001 RX300?
    Brake pads are good. Not needing to replace those.
    If you're not replacing the brake pads insofar as I know there is no good reason to resurface, turn, the rotors. If the rotors are warped therefore the resurfacing I would go to the expense (~$80) of new pads anyway.
    As a rule I replace worn out pads 2 or 3 times before I get the rotors turned.
  • goherd27goherd27 Member Posts: 3
    We have been considering a used 2002 Lexus RX 300 (35,000 miles/owned in Pennsylvania) . I have read on these forums about potential transmission problems. Are there others that we should be aware of?
    What are your opinions on buying something of that age?
    Make certain/sure it has the towing package which includes an extra ATF cooling heat exchanger, but has NEVER towed, and inspect the ATF condition at EVERY oil and filter change. Some may tell you that the tranny problems are only with AWD but I don't buy into that theory.
    To avoid the premature transaxle failures of the '99 (&'00..??) models the '01-03 series uses a higher sustained ATF line pressure and that results in localized heating of the ATF, heating above the original design parameters.
    As a result the factory maintainance schedule, ATF drain and refill, for my AWD '01 was revised from infinity to every 15,000 miles.
    As of '04, the RX330, DBW was adopted to alleviate the problem of engine torque rising for "re-acceleration" before there was enough line pressure to fully and firmly seat the downshifting clutches.
    The age isn't a problem. The extraordinary low mileage is definately not a plus. Check this thread (and the tranny thread) to read complaints from folks who have had problems. Not all RX's had issues, and many higher-mileage RX's that did have them had the problem parts replaced under warrantee with a minimum of hassle
    Have the vehicle inspected by a knowledgeable mechanic.
    Regardless, it's likely a good used car, depending on the deal. If the deal's good enough, you will be able to justify replacing a transmission, should it be a problem. Don't pay extra for extraordinarily low mileage.
    That is good. like they say, it was likely driven to the church only :shades:
    Make sure the engine sludge issue is not present.
  • Ditto on all above posts. Don't neglect ANY of them.
    I have a 2002 with 112k on it. 70% highway though. Change the tranny fluid every 25k, since I put about 18k a year on it. If I don't change it at 25k it gets pretty dirty. That said, the car runs like new, Literally.
    Good Luck on the purchase,
    Ken
  • gmkanegmkane Member Posts: 5
    i replaced my battery a few days ago and now the navigation system doesn't work. when i disconnect the battery cable and replace the nav system will come on, reset and seems to work ok. after a shut off the car and come back later, no nav system, blank screen and the no response to the buttons. radio works ok. is this a dealer situation or is there a fix??
    flashgordonsd
    I have a '99 RX and I'm getting no heat. Fans and air conditioning all seem to work ok. I can't get to the dealer for a couple of weeks. Anyone have any ideas on simple things I could check or any experience with this problem?
    Have you tried the MAX HEAT setting..??
    In that setting the various sensors are ignored and the servomotor drives the mixing vane/door into the FULL HEAT position.
    Low engine coolant or a recent drain/fill of same..??
    Air bubble, "vapor lock" in the hose to/from the heat exchanger is not unusual.
    's servomotor drives
    I have tried max heating with no luck but will try again and follow up on your other suggestions. Thanks.
  • mikey00mikey00 Member Posts: 462
    This is a common RX problem, It's one of the air mix servos not working. If you remove the glove box by opening the door and removing the 2 phillips screws and the 2 lower 10mm bolts, you can then view the operation of the air mix servos.
    You can then remove the white exit vent tube and see the trap door open and close as you adjsut temp control.
    There is a door which is almost up against the heater coil and as you will see, this door open and close to compensate for max or min heat levels.
    DIY'ers... I'm curious who your favorite parts sources for Lexus parts...
    My next two projects:
    1. Replace weak RR door lock solenoid.
    2. Replace struts.
    If you have a link, that would be great.
    Thanks folks...
    My biggest complaint with the '99 RX is the swaying, benign, and otherwise blah handling. Although this car was not marketed as anything close to fun-to-drive, the chassis is so much more capable than the tippiness Lexus built into it.
    I'm curious if anyone has found any suspension upgrades (other than tires) or found aftermarket struts (like KYB or TRD) made a significant difference. What fits? Please, please, please.
    I'm thinking it's finally time for new struts. But I'd love to find upgraded sway bar links to replace the unusually frail, long stock links.
    Irontoad.com and newlexusparts.com are Lexus dealers that discount over the internet using these site names. I have purchased from both. Rockauto.com has great prices for aftermarket parts.
    For the door lock solenoid, others have used a generic one from ebay for about $10. They piggyback it on to the existing one, leaving it in place. They then use a wire tap to connect to the one wire necessary necessary to operate the solenoid. The original one in your RX has many wires attached to it as it performs various functions. That's why it must be left in place or replaced with another of the same. The solenoid from Lexus is about $300. and others have complained about the replacement failing again in a few years.
    Thanks mikey00. You are a great contributor to these forums. I was dreading bringing the car in since I was told by one tech that it would cost hundreds of dollars because they would have to take the dash out.
    Thanks Mikey, these are great suggestions that I hope benefit others, too.
    I've purchased parts from various online Ford dealers and have been pleased with the service and deep discounts. I will have to try this with newlexusparts.com and irontoad.com and I'll search for others. With Ford parts you can look online and many times find a copy of fiche or drawings to match up parts. I don't remember if that's so with Lexus parts. Also, I've needed very few Lexus parts in advance compared to the Fords.
    Your suggestion to use a generic door lock solenoid is really top notch. I had narrowmindedly assumed I needed to remove the old one and replace with the factory part, but was disappointed to find it's sold only as a whole expensive latch assembly. It was not too hard, but it was an awkward process. A generic might be the best trick so rather than do it myself this time. I will try going to an alarm installer and ask them to disable the factory solenoid and install a generic one to provide the same function. That will preserve the factory security, as long as it latches and unlatches positively.
    Yeah, it's common lock solenoids go bad. Too bad they aren't sold separately by Lexus. I had the driver's and one of the rear doors go bad, covered under warrantee. And out of warrantee I had to replace the driver's latch/lock/solenoid combo myself, a PITA. The rear door has been getting lazy as my car sits a lot between uses for road trips. I'm now driving it less than 3000 m/yr, but not short trips. A couple years ago, I took it out and vacumed and cleaned it, put in some spray lube, and it worked fine till a few months ago.
    I'll look at Lexus Owners club, etc. and see what others have to share about using a generic solenoid.
    Thanks again for the very useful info.
    Happy New Year everyone.
  • aquarius021571aquarius021571 Member Posts: 2
    Thank you for the information. I hope I can come across one that has had the transmission replaced. If not, I guess I start looking at the LS400. I truly appreciate your input.
    Happy New Year
  • RathaRatha Member Posts: 4
    Hi all, I've just got RX300, 2000 FWD. I see alot of complaints about its transmission failure I wonder if the problem happen to AWD only or both AWD & FWD?
    Is there any suggestion for the caring?
    Thank you in advance for the the reply,
    Ratha
    Ps: my email is rathahuot@yahoo.com
    A general indicator of wear is the color of fluid between changes. Preventive maintainence in addition to Lexus recommended service might help extend the life, especially if your use involves short trips, stop & go traffic, and/or extended idling or there isn't already too much damage. I have a friend who has over 200,000 miles on an AWD without problems, and the fluid in that car stays pink. My 2WD's original transmission had shift problems and would show wear in the fluid by turning it burned and brownish right away. The factory replacement transmission doesn't show that kind of wear in the fluid, and there are no shift problems.
    Service specific to the transmission includes transmission fluid and filter change by dropping the pan (rather than "flush") and inspection of the old filter and sediment in the pan. If not at a Toyota/Lexus dealer, let them know you want refill with the proper type IV fluid (not generic Dextron/Mercron like most shops stock, they may need to order it ahead with the filter kit).
    For more ideas, search the RX300 Transmission thread of this discussion. For example link title
    And report back to share your experience, good or bad. Most people don't post positive comments, instead most of what you see posted are complaints.
    Good luck with yours.
    Thank you la4mead, I appreciate your reply. All the best.
    It appears to me that somewhere mid-stream of the 2000 MY a major transaxle changeover, revision, was made.
    The '99 and early '00 RX300 models appear to have a transaxle design flaw that results in premature transaxle failures in as little as 70-80,000 miles. Insofar as I have been able to learn Lexus has NEVER addressed the problem of the design flaw for these MY's. Only offering, sometimes, to partially compensate owners for repair costs.
    If the 2000 RX300 you have purchased has the towing package that will be something/somewhat of a good indication that it is one of the late 2000 model year RX300's.
    Once Lexus discovered, came to realize, the nature of the design flaw the corrective action/FIX appears to have been to change the transaxle's firmware so the line control hydraulic pressure is always kept up to a higher pressure level than the original design specifications called for. That resulted, of course, in more heating of the ATF than was expected with the original design pressure and so most, if not all, future vehicles were shipped with the optional (NOT..!!) tow package which included the auxiliary external ATF cooling.
    It appears that this technique, "patchwork" fix, continued up until DBW, E-throttle was adopted for the RX330 series. DBW could be, was used, to delay the onset of engine torque when a transaxle gear change was required and ATF line pressure was not sufficient. DBW was used to "enforce" a delay in the onset of raising engine torque long enough for the line pressure to be pumped up to an acceptable level for fully and firmly seating the clutches for the upcoming gear change.
    Thanks WWEST, however, mine is not with the tow package.
    I don't know yet if it could be only good till 7-800, 00 miles. I've just changed the ATF and the mechanician said everything looks alright even the old ATF still look pink. After changed we test driving and it runs well.
    Hope it could be last longer otherwise I'll be :cry:
