Visitor Agreement.
Here in Michigan, I paid $150 for aftermarket Cat and installation at the muffler shop (non chain store) about two years ago.
Hope this helps.
A guy at the dealership did say that it's important to get a "good" cat if not OEM because of the O2 sensors...a different or "cheap" cat may "run" or "burn" differently and the O2 sensors may pick up on it and give me an CEL (something about the running too "rich" of "lean").
Thanks again...
Oh and besides ebay i seen one for 2495 rebuilt.
if anyone knows where i can get a cheaper one or a new one for the same price or maybe a little more please let me know thanks guys.
Sounds like the dealer is recommending that a lot of stuff be done that Isuzu doesn't require. Some may be worthwhile, but ... hang on to your wallet. :shades:
You could try getting a quote just to do the stuff listed in the maintenance schedule.
And check Dealer Ratings and Reviews for recommendations for mechanics near you.
Bill
I am a current owner of a 1996 Trooper with 234k miles on it.
I have had a few problems over the last 100k or so but nothing major.
This truck has been so good that I have decided to buy another.
For the sake of familiarity I am considering another 96 or 97. But I found a good deal on a 98. This engine is different than the one I have and it also has the TOD system.
Can anybody tell me what their experience has been with the 3.5? More specifically, are there any telltale sounds or areas that I should check when I look at candidates.
Running a few Google searches hasn't turned up any chronic problems which is good, but I am a very cautious buyer and like to be as informed as possible.
Is there a good way to test the TOD system during a test drive?
I appreciate any tips you can give me.
I don't have TOD either, but you should be able to search that as well, lots of stuff about it. HTH One guys opinion.
Need to know if this vehicle be towed behind my motorhome without any special parts.
Any Help Thanks
Here in Puerto Rico cost me about $260.00
I have a PL24458 oil filter that I bought for a car I no longer have. If you would like it email me.
Loren Bradford
I noticed that my clutch is slipping a little bit. I have no problem replacing it. I just don't have the time right now to do it. My question is this...Does anyone know where I can tighten the clutch. its it on the tranny itself, or on the clutch petal. If there is any one who can help, it would be greatly appreciated...
Maddy :confuse:
For a while now, I've had a noise from under my 1999 Trooper and the best description I can think of is like "stones being shaken around in a glass jar". It didn't happen ALL of the time and was most prevalent when in gear and accelerating. A few shops said it was the catalytic converter - but it was running fine and I have blown it off for a bit.
Recently took it to a muffler shop who said it was NOT the CAT and suggested it was something (STARTER) brushing up against the FLYWHEEL - as he could see some wear on the flywheel gears.
Sound familiar to anyone?
My dad has a 1999 Trooper, and is going to Colorado this Christmas, and he recently called me and said his rear right ABS sensor is bad (took it to the dealer). They of course want a fortune, so i was seeing if anyone knew where to get one(cheaper) or who may have one.
Thanks for any help
Michael
One guys opinion.
It's definately NOT a pinging, it sounds metallic and substantial...although not constant. From what a couple of guys said, it does sound like the starter on the flywheel. Do you think I can live with it for a couple more weeks?
I've got an appointment to take it to the local dealer but they may charge me 2 hours just to tell me that!
Thanks a bunch for the feedback....
Just from how and when the nosie starts, it make sense to think its the starter rubbing on the flywheel.
1) It only does it when IN GEAR and accelerating (can't rev it in N and make it rattle)
2) Doesn't do it all of the time
3) If I'm driving and the noise starts, I can sometimes turn the car off, and when I restart it, the rattle goes away (usually comes back fairly quickly though)
Anyway, thanks a bunch for he feedback. Guess I'm gonna bite the bullet, and have the dealer (or someone) diagnose - hopefully a new starter - or just the spring that disengages it from the flywheel - will fix 'er up!
I hope someone can help. I have a throttle body 2 barrel fuel injection carb. For some reason or another, one of the injector won't spray fuel into the carb. Other than the basics fixes, what else could there be.
Any help would be greatly appreciated...
Maddy
Maddy
It does however seem to "loosen up" after a bit and shift easlily - like normal.
The Cable thing sounds pretty simpe and cheap (ha).
Anyone run into this sorta thing?
Does anyone know how to remove this rock guard shield? If I can get it off, I plan to paint the area dark grey with bumper paint.
Thanks for any help.
Just recently I started to get a pop that comes from my throttle body carb. I'm not sure why it would be back firing like that. I did check all the vacuum hoses. Everything seems to be intact. Just recently I did some work on my exhaust system, but the pop isn't from the exhaust. When my truck is at a stand still, it doesn't pop when I hit the gas, but it is certainly evident when I drive it. When the carb back fires, my truck loses power. Also, would anyone know the firing order for a 1990 Isuzu Trooper with a 2.8 liter v6? Just want to make sure the plugs match up correctly to the distributor.
If anyone can help, it would be greatly appreciated... :confuse:
Tracy
Assuming you don't have a camshaft problem or valve sticking, start with basics....plugs, wires, and coil check. Bad plugs will evidence themselves under load.
HTH
I’m having a persistent problem with my 1999 Trooper that has been running perfectly for years until now. It idles a little rough, but revs nicely with no engine load. It barely gets down the road, however. A real dog. Like running on three or four cylinders. Codes are p1171, P0030, P0301, and various O2 sensor codes at times, like low voltage. I replaced the fuel filter. Fuel pressure is being regulated at about 37 pounds. Remove vacuum from regulator, pressure goes past 40. Replaced oxygen sensors (that one on the passenger side was a bear; had to remove front drive shaft to get to it). Replaced all six fuel injectors. Did the usual EGR cleaning, also removed the TB to clean the weird EGR passage molded into the intake manifold which was plugged with carbon. I have an OBDII reader that interfaces the ECM to a laptop. Long term fuel trim on bank one runs into the negative, while bank two runs far positive, into the twenties at times. I tried the trick of spraying carb cleaner around the manifold to check for leaks, but nothing happened. Never did hear a leak anyway.
About two and a half months ago the check engine light came on, flashing. Ended up being the no. 3 cylinder misfiring. Coil pack was bad. I replaced the pack and bought a spare. I tried the spare on various cylinders, but no joy. No surprise since the truck was running better before on 5 cylinders than it is now. Difficult to get up to 50 mph, have to go very easy on the accelerator or I get a lot of knocking and pinging like the engine is under great load.
Can anybody give me any ideas? Thanks
Why must some people make useless, un-helpful posts? I'll post the concluding info and my fix here; maybe others can benefit from my experiences.
My trooper indeed had a bad catalytic converter. I came to the conclusion after examining the scanned results; the passenger side was out of kilter. Of course that by itself isn't enough, but what really got me to suspect the cat was the trouble (besides the little incident of driving back home on a trip from a neighboring state, with over an hour drive time left, when #3 coil pack died) was the lack of response on the right side. If I removed a coil plug or injector connector on the left side, it made major difference in the running of the engine. However, it made little difference on the right (passenger) side. And there was the clattering of the valves on that side, too. I got under the vehicle and drilled a few 1/4" holes in the engine side of the cat, and Man! did the gas shoot outta them holes. And the engine started to run properly. Case closed. Just got back from a muffler shop downtown that replaced the cat for 180 bucks.
My symptoms were that the car ran okay when the tank was full but got progressively worse as the tank drained. Eventually, it would misfire badly while accelerating.
Tom
