More tips in the How to Remove a Stuck CD guide.
I did go ahead and check my oil in the transfer case. I did notice it was low, so I filled it up to the appropriate level. Looking at the old oil, I noticed there were no shavings of metal or such. When I replaced the oil, the rattling noise still occurd. at hire speeds. One other thing I did notice is that when I turn my wheels to the right or left, my Troopers seems to want to stop a little. Almost like I'm pushing on the brake a little. This only happens when I am going about 5 to 10 miles per hour.
If there is anyone who can help, it would be greatly appreciated.
Tracy
Tom
Can some one recommend to me a diagnostic program for a 2003 Isuzu Trooper, 3.0d. I am having a few problems with the engine spluttering and cutting out when cold. Also when I am descending a steep hill or braking hard it splutters and sometimes cuts out also. I think if I could capture the live sensor data it will be possible to sort out the problem. I have access to a laptop so I can either obtain a unit or use an interface cable and software on the laptop. All suggestions are welcome. Thanks all.
I did go ahead and check my oil in the transfer case. I did notice it was low, so I filled it up to the appropriate level. Looking at the old oil, I noticed there were no shavings of metal or such. When I replaced the oil, the rattling noise still occurd. at hire speeds. Is there any kind of adjustments that can be done to correct this problem? Before I dropped the tranny to replace the clutch, my 4 hi worked just fine with no rattling. Could something have happened when I put the tranny back in?
Any help would be greatly appreciated... :confuse:
Tracy
Any ideas on how to improve the efficiency in the winter?
But now we have ethanol in our gas yearround causing that drop. Might want to make sure your tire pressure is around 35 psi or so.
BTW, I have a 2000 Trooper LS...my maximum mileage has been about 18.5 average is probably more like 17-17.5. Mixed light city and hwy. It would be difficult to get much better mileage than that IMHO unless you were on a flat road with no stops driving about 55 MPH.
I purchased a 2008 Saturn Outlook in August. Still driving the Trooper quite a bit to keep the miles down on the new one. It has a DIC with average mileage calculated. When I reset that reading, I can see how much drop there is in MPG just pulling up to a stop sign/light and then getting back up to speed. Also, a couple of minute warm-up idle will drop it pretty quick. (Remote start is great :-) but not very effecient :-( )
I have a 2000 Trooper and also thinking of putting manual locking hubs.
One guys opinion. HTH
Anyone replaced their O2 sensors and seen any mpg improvement as a result ??
The engineers designed the electrical system to provide power only to necessary functions (like keeping the engine running) when the alternator quits, so the HVAC blower is off if no output from alternator. Good place to start...........check if battery is being charged with a VOM meter at least at 13.6 volts with engine running. If not, new alt is probably needed. Engine will quit when voltage drops to 9 or so volts.
HTH One guys opinion.
P.S. Any good (and easy) roof rack options for a 2002 Trooper out there? Are Thule or Yakima solutions ok?
I have 45K miles on it, new battery, new tires, new HD radio unit (the best thing ever!) and no issues other than a cruise control that is unreliable. Has anyone else experienced it? Like not being able to set it in the first place or dropping out of it completely when adjusting speed increments?
Chris
It is tough to get to, and the connector is very brittle by now and will crack, chip or disintegrate depending on how you treat it. Have you checked for codes? I sure would before diving in to this one. Remember that even if the CEL is not on, some codes may be stored. HTH One guys opinion.
I'm trying to help my Dad out. He has a "91" Trooper and it sounds like to me that he needs a new exhaust gasket. Does anyone have a diagram to the exhaust, its a 6 cylinder?
Thanks in advance!
Thank you for the reply! I guess I just have to get in there and do an alimination process. But yea, this will me neat to show my Dad. May come in handy one day.
Thanks a million!
ms_jetset
I was wondering how well the 'universal' clips you got a hold of held up and if its worth me finding a auto glass place that carries them.
Thanks for the help!
Has anyone experience anything like this?
I currently have a 2000 Ford F-150 Supercab Longbed 4x2 that has major issues with it's ABS module under the hood- it keeps running with off. And until I can get it fixed, it's not a viable form of transportation. Besides, my wife hates it as I never took her to look at vehicles when I bought it- and as she's in a wheelchair, she cannot get into it easily. As well as it being a gashog.
So, being unemployed (except for a 24 hours/week part-time gig) sucks. I was able to acquire this vehicle for $1800 cash.
V6, 5 speed, A/C, AM/FM/Cassette, manual windows, fairly new Michelin SUV tires- 175xxx miles and straight body! Only a few minor paint dings on the nose of the hood and a crack in the windshield that's not very noticable. Interior upholstery is a bit dusty and needs cleaning, but no rips, tears or damage! Both airbags intact and never used.
It rides nice, shifts smartly (in spite of my not driving a stick in 25 years!) and only had a few cobwebs- seems it was donated to the Salavtion Army, and the dealer got it there. And based on the numerous positive reviews on the Trooper on Edmundns.com and other sites, I felt it would be a good choice- as the passenger seat is basically the same height as my father-in-law's 93 Ford POS Explorer that my wife CAN get into- but with better leg room in the Trooper. And easy to load her wheelchair or her powerchair in the back!
The only mechanical issue is a leak in the power steering pressue switch- one inspector failed it, another didn't as he considered it a non-issue. (Put some Lucas StopLeak PS fluid in it...)
I know it does not get the greatest gas mileage, but so far on the first tank, it's about 15 - far better than the 12 the F150 gets.
I have posted pics in Redshank's album.
Tom
