Visitor Agreement.
I think it is one of two things (just dont know which one)
I gave it a tune-up.. my problem were the spark plugs - i ordered some fancy ones, and realized that I had to get the special ones for the trooper since of the ION-sensoring item. no clue, but that helped it. Make sure you have the right spark plugs, and not the ones that should be ok... NGK something were the ones I got.
Also, Check the intake manifold for leaks. I had one, and it caused some issues too..
One of those two above cases is a problem that seems like you could be having.. i just really dont know which one it is.. checking for leaks is easy..
Thanks in advance
http://www.sfmslaw.com/pages/cases.php?id=681
mox
I have a 1999 Isuzu Trooper at around 113,000 miles. The car is starting to sway (rock back and forth) more when I go over bumps. It's not 'catching' as much/rocks side-to-side. It's not really dramatic, but just enough to make you a little car sick.
Recent car goings-on:
-- Replaced shocks (original equipment) yesterday to see if this would help it. Didn't seem to help much. Put on the Mountain Ryder Gas http://www.lesschwab.com/shocks/mountainryder_gas.asp shocks at Les Schwab.
-- Have newer tires (about 2 years old), all-weather -- wear pattern seems ok.
-- Recently had starter replaced twice, 1st one didn't work out. About a month after this I noticed the sway more. Don't know if something got banged-up in the front end when the dealer was working on it.
-- Left rear axil seal leak last fall (hub bearing and seal)
Any suggestions on what to look at/replace?
Also, if you know of any suggestions for a car this age to get the road/air-flow noise down some. Should I replace the rubber lining on the doors?
Thanks ahead for any suggestions.
To replace that starter requires a undercarriage cross-member to be removed and the exhaust pipe to be dropped. Did the repairman put everything back together properly? Is the cross-member loose?
One other thought, how about the sway bars? If the end of one is loose or broken (had that happen on a Quest van years ago) that could cause the problem.
I've heard from a few people that there is a Chevy engine that will line up with my tranny. Something in the area of a Chevy 3.1 liter v6. I don't know the specific engine or the year, but if there is something out there that would have more power. it would be great! My 90 Trooper is in excellent condition! I just need a more powerful engine.
Any help would be greatly appreciated...
Maddy :confuse:
Maddy :confuse:
Had a mech say, "if its not going past middle of gauge not to worry about it...if anything, its god that the engine warms up alot quicker than other cars."
I was planning to keep it as a third vehicle before the rebate program.
I can not belive it is going to "die" with so much life left, and I can not believe I was so attached to it. I have imagined the government keeping the best "clunkers" for government use so it can live on.
I have owned many cars. None more relaible than the trooper that I owned for about 6 years.
I'm keeping my 2002 - I can't believe it's worth ~$4500 on paper though... Even 2000 Rodeos have a higher trade-in value for some reason.
I never believe in trade in values anyways on older cars not in demand. You will get more from an individual but I hate the hassle of selling, that is why I was prepared to just drive out the car before the clunker program. You may even get offered shockingly less than you think that if you actually trade in at a dealer.
I now have a crossover SUV and a car. Thought I was ready for the change, but I miss the "truck". I am sure I will adjust or get something more truck like next, whenever that is.
I've had 4 Troopers now, starting with a 1988 went to a 1997, a 1999 and a 2001. None of them let me down. Worthless??? No way........if they are paid for, they are worth about $10000 b/c that's what it would cost to replace them with a used reliable SUV of any size. A new comparable sized SUV will cost around $25000 maybe more, and the mileage isn't that much better than what I'm getting. I figure I can spend about $300 a month on gas and more than break even when I don't have a car payment each month.
I bet you'll regret letting your 99' Troop go before its over. It would have run another 150K miles if taken care of. I'd like to know where it's located and go get it!!
Why I miss it:
It was dependable and I got it cheap. I think it actually cost me less than a thousand dollars a year to run with car payment and repairs not includidng gas when all calculated. never had another vehicle that came anywhere close to that. It was a poor man's land rover, and almost as plushwhen loaded but with lower maintenance costs.
It was like having a large SUV in midsize skin.
It was loaded
I liked sitting high with the airy cabin.
I liked knowing I could go anywhere or tow even though it mainly saw pavement. It was not so new or expensive like a land rover that I was afraid to get a dent or scratch, but it still looked nice. Paint was just starting to flake off around tires a little.
I got a used convertible pontiac G6 at a great deal. Thought I could have both my rugged and girly man vehicle, but it did not work out like I planned.
Thanks a lot!
But my last car (a Nissan truck) went 260k+, and I sold it for $2500 cash when I got my Trooper. And the aspect that they'd assassinate it really bothered me. I can try to wait 2-3 more years.
My map light's switch is busted and the cruise control works when it wants to. Other than that it looks and rides like new. The brakes on the Trooper are massive but should I start looking into replacing them soon? I don't trust any of the places out there; can I replace the pads myself, what about the rotors, and how would you check how much life you have left?
You could probably check the rotors for thickness and runout against the specs in a repair manual, but if the surfaces looks okay and they have not warped, I would just change the pads and go on. I'm up to 148,000 on original rotors. (The Grand Cherokee rotors were warped at less than 10K and were problems until I replaced with budget rotors from Autozone.
One other suggestion would be to try and find the OEM pads at an Isuzu dealer or order from St Charles Isuzu if they are still around. These pads do not dust like other brands. Even after I changed to ceramic on the Jeep there was dust.
My Trooper is in semi-retirement...will probably be doing 5K or less a year since a Saturn Outlook is my need daily driver.
I ran into a problem with my Trooper just recently. 5 thousand miles back, I replaced my clutch. I.e.: bearings, pressure plate, clutch pad, etc.. Now I notice that my clutch is slipping once again. I have always been easy on the clutch, and have taken great care of my vehicles.
So, the question is obvious..."Why is this happening"? Am I missing something? The clutch worked like a charm after replacing. I'm not sure or not if this particular clutch can be tightened. And if so, how is this possible?
If there is anyone out there who can help, It would be greatly appreciated... :confuse:
Oh, just one more thing......"TROOPERS ROCK!
Maddy
The socket should have a rubber insert in it so it will hold the plug as you pull the wrench and attachments out of the well. Reverse the wrench assembly as you remove the plug.
Likewise, but more recently, our ABS light came on and the ABS doesn't work at all now. The service center said we need a new EHCU, which is around $1500-2000. Ouch!! Doesn't seem right.
Anyone have suggestions to keep the cost down on these repairs? I'm not very good mechanically, but could probably clean out a couple sensors or something if that's worth a try. I don't mind spending $$ to get these things fixed, but certainly not $1,500+. Part of me would just like to find a good mechanic who could better diagnose whether it's just dirty sensors or whatever because replacing with rare and expensive parts, but I'm not sure what to look for there. Do I just find a mechanic and buy him a Helm's/Chilton's book for the Trooper? Please help me not make an expensive mistake, as I try to get my Trooper to 200k.
P.S., I tried searching this forum on these topics, but frankly, but I find this discussion board really hard to search / read / navigate, so I apologize if a lot of this has been discussed before. It seems like there's just one big discussion of everything related to Troopers, and as people reply to each question/post, the replies just become new messages under "Trooper" -- there is no simple way to view a threaded set of replies to someone's specific question about their Trooper.
SUVs and Smart Shopper
I'm not going to tell you not to get it fixed but I'm not about to spend 2k on a car with 156k on it when the brakes appear to work fine.
Good luck
It's probably cheaper to get a winter tire setup that should get you through the snow and ice relatively well.
Any ideas why this would happen?
I live on the south side of Denver Colorado in Jeffco and am looking for an independent shop or a good dealer who has a guy who knows '86 - '91 Troopers?
I've got a '91 with a 4EZ1 and 310,000 and a '91 with 150,000 and a 2.8.
Some days I'm just too tired. Would like to find someone to pay to do the work.
John
OK.........what is it ???
You're starving your engine..........your fuel filter is plugged up, almost completely and fuel wasn't getting to the engine. I've replaced the fuel filter and put Chevron with Techron in the gas tank to clean out the piping and injectors. It seems to be running smoother, but it could take some time to see final results. May require a injector replacement if it doesn't smooth completely and run like its supposed to.
Are you kidding me.........so I'm driving it now to see what happens. I'll have the final story here when I know it. But, for now it looks promising. Should know in a week or so.
FWIW, I had to replace the fuel pump and strainer in my '99 Trooper. It got to the point I had to keep a full tank of gas to get it to run. Pretty soon I had to be gentle with the throttle when giving it gas. Strainer that was attached to the fuel pump was plugged.
Tom
The drivers side switch does nothing when i press heat or keep, and doesnt warm the seat either. The passenger side switch illuminates when either is pressed, but the seat doesnt heat up.
Any suggestions? I looked at all the fuses, but really havent found anything. Is there something in the seats or under them? I have not looked yet
Thanks for any help
