I too had the same concerns you expressed about the TOD being way too complicated. I figured it would not work properly and/or frequently breakdown. So far no problems here and many people like Paisan leave it on all the time.
I knew of the brake-driveshaft-throttle position sensors, but I wasn't sure of any 'weight' or, in essence, position sensors. I thought I read something related to it, but I couldn't remember where. It is so sad that the Ascender is such a step down from the Trooper! Maybe I'll save my pennies and eventually get a used Gelandewagen (even though I really don't like MB's overall, but wow, three locking differentials; who wouldn't like that).
Regarding Breakors comments, I agree the TOD may have a slight disadvantage in some situations, but the Jeep system would have disadvantages in other situations as well. There has to be some advangages to the variability in torque split.
As an former owner of a Selec-Trac Jeep, I can't tell you the amount of times I had to drive in reverse for 100 yards to get the 4wd to disconnect (shift-on-the-fly my tushie) or how long I had to wait for it to go into 4wd after pulling the (direct acting, not electronic) lever. Talk about being sensitive to even just tire pressure differences! Following standard maintenance, the trans-type fluid in the selec-trac case often came out black and smelling burnt. It is far more tempermental and not much less complicated than the TOD. I will say the Jeep worked 'well' for 120,000 miles and never cost me a lot in repairs, just some poor design and/or build issues. NOTHING like the new GM Triplets. The particular year Jeep I had used an ABS system that, if the ABS pump failed, you literally lost ALL braking. You would have to overcome 1,500lbs of -reverse force on the pedal, it literally became a coaster brake. Chrysler lost class-action court case where they have to cover any repairs to the ABS system on those Jeeps for life at no charge to the customer.
I'll take the Trooper any day. Looking at the new Liberty, it does have impressive angle of approach/departure though, the tires are right behind the bumpers. So, ya got that going for ya!
I actually have toned down my TOD driving, in that I leave it in 2wd now unless I'm in moving traffic or around town. The Pirelli Scorpion ATs have helped me keep it in 2wd more than before.
-mike
-mike
http://cgi.ebay.com/ebaymotors/ws/ebayISAPI.dll?ViewItem&item=1826400310&r=0&t=0
Anyone have an idea as to the tire size? How about comments on this tire for the Trooper? It's getting close for me to consider tires for my 1999 Trooper and I think they will look better than the Bridgestones.
I have BFG's on my car, at the standard 245/70R16. They were installed at delivery instead of the standard Goodyear Wrangler AP tyres we get in Oz. (If you guys are complaining about Bridgestones, have a go at how bad the Gyears are offroad).
They BFG's handled fine, but provide a harsh ride and are a little noisy. This ride in the Oz Jackaroo is already firm as a result of the gas shocks that are used, but it is a re-assuring sort of ride. The BFG's made it a bit firmer due to the straighter 3 ply sidewalls. Handling is starting to deteriorate now with around 40,000km and tread depth down to about 30% of the original 15mm.The aggressive tread looks great though, especially when new with the side lugs all nice and sharp.
I will be looking for a slightly softer tyre by the time it gets to 50,000km. As the guys here seem to be raving about the Pirelli Scorpion A/T's, that is my likely new tyre. But the Michelin Synchrone will get a look in too.
PS ... The tyre size is shown on that ebay link, you have to scroll down a fair bit though. They are LT285/75R16.
You would get around 1.6" extra ground clearance with these, as the diameter is 32.9" as opposed to the standard 29.6".
BFG A/T's go upto a LT315/75R16 which has a diameter of 34.7". This would give you a 2" lift in ground clearance.
http://isuzu-suvs.com/events/pb-5-05-02/index.html
-mike
I think SBcooke would have been parking his truck and riding along on this one.
-mike
On another note...I am getting close to my big purchase. I am bringing the steering thing in next week. After that, new tires and springs. I keep going back and forth, maybe I will just try to fit new tires, save the springs? I don't tow, so if I could fit 275/70's without springs, maybe that it the best route? Anyway, in about 2 weeks I will be warming up the MC!
-mike
-mike
-mike
On the K&N filter So far i've found the K&N panel to really help prevent water from getting through the intake. I'm sure that if enough water rushed in, then it would swamp it out, but i've been lucky so far that i've been able to get lots of water into the box but none through the filter.
-mike
That 97 4X4 on e-bay for $5300 is a buy - if I had the money I'd get it. 109K miles is nothing. For a 97 that suggests mostly highway miles anyway. I like the looks of those tires too.
-mike
Still waiting on a response from Rancho, but after talking to a couple of folks around here, I think I'm okay. Agree there should be little difference between smooth bolt and sleeve througth the center... Only diff. is that pressing in sleeve compresses rubber gromet more, thus it might give a firmer ride. With just the bolt, rubber is not as compressed and may compress more when the shock moves. I might want to go a month or so and the drop one and see how they are holding up.
Love the ride...tested them out near the mall Saturday. There is a tight S curve with what seems to be 2"-3" washboard all the way through. Went through that without slowing down.... Handled it much better than I remember the stock shocks.
I read where there are folks who are getting 90,000 - 100,000 from some Michellins. If that is indeed true, then they should be worth the extra price that is if we keep our Troopers for the next 100k miles.
The service tech said that the Check Engine light will come on for numerous reasons. I now know the computer has sensors that sense the pressure in the gas tank - so what are the other reasons that will cause the Check Engine light to come on?
I got a CEL this past weekend for the gas cap as well. When you hit 1/2 a tank of gas it will automatically check itself and turn off the CEL if the cap has been re-tightened.
Luckily for my a friend had the palm pilot with the ODBII connector and software. It was pretty neat to see all the codes come up with "evaporative something or other problem" I went and tightened the gas cap and it immediately stopped
I'm thinking of buying one for myself
-mike
BTW, the format of this message board is pretty hard to read. Would be much nicer if it was threaded, had search capability, etc. Are there any other good Trooper message board out there?
-mike
People seem generally to prefer the "converational" style of the message board rather than the "threaded" format. I find it helps a lot to use the "subscription" feature that lets you focus right in on the topics that interest you.
The lack of reliable search function is a deficiency and Edmunds is working on fixing it - release date TBA!
tidester
SUVs
BTW, is there a shop manual on the web for the Trooper?
We drove through water that came over the hood and was basically up to the door-handles at some points, no leaks, but I wasn't standing in the water. The pic there is of conways with the water just up to the lip of the door, no problems as it didn't come in the vehicle
After one water x-ing where I had the water up over the hood, the engine did almost stall. Not sure if it was electronics or the lack of air-intake that caused it. But it didn't stall and kept pulling me through. Didn't get stuck all day.
These trucks are tough!
-mike
Also, I have been after a workshop manual for a couple of years now. The only ones available in Australia are the ones that Holden supplies to their dealer network. And they are something like $400 per volume. I suppose that is to discourage "Do-it-yourself-ers". And guess what? It's very discouraging.
If anyone is aware of a cheaper option, let me know!
BTW ... Where is the ODBII port on the Trooper?
14.5 ID top
19.5 ID bottom
I don't trust all of those generic roof racks that say they will fit all makes. Thanks.
1. Problems, problems, and more problems;
2. What "color" the thing is going to be available in.
People seem to go out of their way to avoid discussion on any technical aspects of the vehicles (4wd vs. AWD, for example). Few forums would talk about taking a rather new vehicle and 'adapting' an ARB for the front axle as an example.
Long live the Trooper!
http://www.overlander.com/pages_misc/contents_fr.tpl?cart=31035535534420761
(if link doesn't work, it should all be on one line). The 'foot' they provide fits into the stock Trooper holes under the factory strips.
Look at the Trooper Mount Set:
SBTR100 Trooper Mount Set $39.00
You could certainly use the mounting feet and just add a couple of cross bars and make any type of rack you want if you don't want to use the aluminum Expedition racks.
If Helm doesn't ship internationally, you might try having the manual shipped to one of us Americans and we could send it to Australia. I'd be willing to help with this transaction.
http://cgi6.ebay.com/ebaymotors/aw-cgi/eBayISAPI.dll?ViewListedItems&userid=dentstcr@aol.com
There are weld nuts under the vinyl trim on top of my 2000 Trooper to bolt to. Probably the same with a 95.
If you get Yakima or Thule cross bars you have access to an unlimited range of rack accessories for hauling everything imaginable. I haul ladders, kayaks, canoes, etc. This summer I may add a storage box.
I think that ARB also makes racks for the Trooper. I got a catalog today and they have a basket type rack. Could probably order the feet and put on any type of crossbars you like.
They send international. For Oz that $67. Apply the conversion rate and we are talking $300 AUS.
Now ... talk to the bosslady!
www.racetothesky.com
It is a major hill climb in NZ, based on Pikes Peak at Colorado Springs. Holden entered Bruce Garland's Jackaroo in it.
He came 7th in the Open 4WD class and 33rd overall out of a field of 82. But look at in context. Other than a monster Hilux (which won outright), the 'roo was the only traditional SUV that started and finished. And it was only beaten by some speed machines such as Mitsubishi Lancer EVO's, Subaru RS Legacy and WRX's. It also beat a large field of motorbikes, quads and other cars. All things considered, it's a good result for the 'roo!
If the track was a bit chopped up, it could have been a very different story.
And it didn't rollover!
