Also - I'd go to that dealer that has $6000 off and offer him 8000 off - forget swaping that engine - Troopers are selling here in Alabama - 3 on the dealers lot earlier this week - this morning one left = S 2wd.- He also had 6000 off painted on window. When I go down to pick mine up I'll ask what they would sell one for = TOD LS or S.
If you're hoping for leather, then you will be disappointed.
Sorry
-mike
-mike
http://www.courtesychevy.com/shop.html
Jim
edit: go to pre-owned, choose isuzu, and search inventory, it's the only isuzu there. LS, 23k miles, sunroof, etc.
Jim
How do I know?
1) Antenna on fender
2) 2-tone
3) no fogs
4) rims
5) black mirrors
6) body color b-pillar
7) No "limited" or "LS" on the C-pillar
8) Clear tail turn signals
Woodgrain is easily added.
If it's a factory roof, I believe in 2000 the S had the moonroof as an option. 2001->2002 the moonroor wasn't an option on the S models.
-mike
-mike
Jim
Jim
-mike
JimmyP1, sorry to give you all the bad news on that Trooper, dude. It would have been a reasonable buy at 18000 if it were the LS. For the S model with all the features mentioned, price should be more like 15,000.
Who's got a link to those OME springs??
Continue hunting, there's bargins out there to be found!!
-mike
Perhaps they did lie. Another possible, though still annoying, explanation is that someone thought it was 4WD even though they didn't know for sure. I'm not excusing that, but it could have been sloppiness or something instead of intentional deception.
I modified Jeeps some years ago, and I'll tell you the safest way to lift a vehicle is a suspension lift, also this is the preferred means to gain clearance for larger tires. Coil spacers are fine as long as you don't go with too tall of spacers, 1" to 3" should be safe.
-mike
Well if you are offroading you will fully compress your vehicle no matter what, and at that point you'll be cursing the OMEs if you go into it thinking they'll let you mount larger tires w/o modifying the bump stops. With that said, I love mine, I keep mine at a slight rake so that when I have my tools and boat trailer on the back it doesn't sag.
I'd do OMEs first for $120 then do the spacers later on.
-mike
1. Suspension lift
2. Body lift
3. Trim your wheel wells to allow for larger tires
--Spacer lifts fall between body and suspension lifts
Stiffer and taller springs will allow for taller tires and will reduce the chances of your suspension bottoming out. That said, I would not recommend installing a suspension lift and taller tires without modifying your bumpstops--that is the only way to be sure that you won't rub your tires. One consideration with that is that by lengthing your bumpstops you are reducing the travel of your suspension upwards.
And several others on here have also stated another shortcoming when installing taller tires and that is the accompanying power loss. The taller tires may look nice, but when it comes to hauling people, gear and/or towing, the power loss caused by the taller tires will be sorely felt.
Many people have posted their experiences with installing taller tires on Troopers. The consensus seems to be that up to 265/75 are no problem with fit, rubbing and minimal (read acceptable) power loss. Many have fit 285/75s on Troopers with no suspension lift and minor rubbing off-road, though with that size tire most owners do lift their Troopers. With 285s and larger power loss is much more noticeable.
-mike
- Trooper runs great and gets 18 mpg ave. on highways and secondary roads
- Oil consumption is about 1/2 quart per 3000 miles (yes, I've put on 3000 miles in two weeks)
- Hidden Hitch mounted easily
- Hoppy wiring harness works perfectly
Still need to sort out the CB antenna when I get a chance. Mike, do you think the rear wing can take the flex load of that antenna? It doesn't look very strong but maybe I'm mistaken.
Again, thanks to all
Sean Reid
I think there's already a writeup on this on Paisans site so I'll just add a few points / tips here. Taking the old shocks off was the hard part. The fronts have a long winded threaded rod on top that I had to fight every inch of the way. Access is relatively easy over the top of the front tire. I cleaned them with a wire brush and sprayed them with a penetrating spray before tackling them. Had to hold the top of the rod with a small crescent to keep it from turning while I worked the nut with a combination wrench. It took a while. Every nut on the old shocks felt like it was welded on and there's not a lot of clearance for wrenching. Wasn't able to use air wrenches because of clearance problems.
I have a full complement of tools, solid intermediate mechanical skills, and have changed lots of shocks. By the time I was done with this job I was thinking I would have been smarter to have taken it into a shop.
One particularly exasperating problem - the boots kept popping off the top of the shock while I was expanding the shock up into the top bracket. Took forever and some elbow grease to get them back on without taking the shock back off the vehicle.
One tool that helped a lot - a slender pry bar with a point on one end. I used it to align the shocks with the holes in the brackets - so the bolts would go through.
Another good idea. When you get the original bolts out, wire brush them and spray them good, then run the nut up and down the both until it turns free. Will make it much easier to reinstall.
Lastly, I wish I would have powerwashed the areas around the shocks before working on them. I was filthy by the time I was done from rubbing against all the tight places on the underside of the Trooper.
After all that I can't wait to get out and try the new shocks!
That's what I was expecting to read, c'mon! Get out there, on and off road!
Jim
I run currently some cheesy blue ones in 80/100w variety and have been pretty happy with them for almost 2 years. In the fogs I run 100w H3s from Walmart.
-mike
-mike
I finally found the source of the rattle by removing this device completely - voila, the rattle was gone. Now, how to fix it with the gizmo in place? I just replaced the wimpy stock spring with a much heavier spring that I found in a hardware store. This heavier spring pushes the white nylon block more firmly into position. Rattle is gone, at least on the rough paved roads we have in the neighborhood. Haven't tried it offroad yet.
Cost - about $2 for the new spring and several hours of trying to figure out the problem.
This simple repair has made the ride much quieter and more pleasant.
Anyone else have this problem? I hope my fix helps you out.
offroader
-mike
A Nissan Patrol (98 model) with a 6" lift from 4WD Systems.
A lot of the problem with the lights is the reflectors, they don't have a very good beam pattern. So I believe you will get a little better with 80/100, but it may not justify the cost?
Now I can enjoy the ride. The OME springs changed the "feel" of the ride from heavy truck like to lighter more agile. What I liked most about my 1984 Trooper-II was how light and responsive it seemed eager to go places. My first impression of my 1995.5 was heavier more effort shifter and overall feel was heavier. With OME springs and RedLineOil synthetic manual transmission oil my 1995.5 feels lighter more eager to go places.
So, if anyone is "on the fence" about the OME springs of the RedLineOil synthetic manual transmission oil, don't hesitate these are simple and inexpensive and they are significant upgrades. If I bought a new Trooper I would put these in at the time of first or second oil change.
Dyslexics of the world, UNTIE! :-)
tidester
SUVs; Aftermarket & Accessories
www.arbusa.com
