Visitor Agreement.
I used the RedLineOil telephone help to get a recommendation of what synthetic oil to use. The guy on the phone seemed to know his product well. I told them my reason to go to synthetic was for better protection when towing my 4000 lb. trailer. They recommended RedLine MTL for my manual transmission. MTL is formulated for easier shifting while still being heavy enough for the synchronizers to work.
The effect of the MTL is much easier shifting. Still not as easy as my previous 1984 Trooper-II 4 speed, but a lot better than my 1995.5 5 speed was with the original Isuzu oil in it.
http://www.redlineoil.com
-mike
Going through the manual and then calling around to other ASCE certified shops lowered the cost significantly. The thing that bothers me is that the dealers wouldn't do only the maintenance required by the owner's manual. They added in a lot of extras.
Now I read that many dealers and manufacturers are not giving their vehicle codes to independent repair shops, forcing owners to use the dealer service department. What a mess! No wonder dealers have such a bad reputation. If you are going to force us to use you, please allow us the option of only getting the RECOMMENDED services only and not all the other garbage tacked on.
Sorry for the rant. At least I have a good truck that isn't being recalled every 6 months for repairs or falling apart.
This is only my second tank, and I do a lot of idling...it rained last week with about 85+ temps, so I sat in the A/C for 15-20 minutes at one point. It is hard for me to get an accurate mileage based on driving, but in general it seems down 1-2 mpg.
Can you describe the rattle that you were getting? Was it like a small component rattling loose, or did it sound like something big (like a back door)not quite fitting tightly and drumming away?
The one thing I find most annoying on my Monterey is some drumming type noise coming from the back, over rough paved or hard surfaced roads and tracks. I don't get the noise on gravel or dirt.
I always suspected that it might be either the rear barn doors, or possibly the roof panel (however, the roof panel ribbing should stop that drumming). Haven't been able to figure it out. I'll give the spring solution a go.
If I can get rid of this, then I'd happily say that I have the "closest to perfect" car that I have ever owned.
My local dealers are useless as well. Same deal as you. My (now 108k mile) Trooper was last serviced by the dealer at 15k miles. Ever since at an Independent NAPA repair shop.
They let me call the shots. I tell them "I have 90k on the car, I want you to do X,Y,Z". No BS.
I can't believe a dealer would refuse to quote a price for work on a job-by-job basis. I guess they know the real profit lies in lumping it all together, calling it the 'official xx,xxx mile service,' and charging more for the whole thing than the sum of the parts.
tetonman, what exactly did you mean by "many dealers and manufacturers are not giving their vehicle codes to independent repair shops"? Of what vehicle codes are you speaking?
More info. on the fix. Once the two bolts are removed and the sliding gizmo is off the door, it comes apart without tools. There are four components - the mount or housing, the white nylon/plastic wedge, the rod, and the spring. Actually, I replaced the single factory spring with two springs. I couldn't find a single spring long enough, so I bought two shorter, stiffer springs of the same diameter as the factory spring and mounted them end-to-end on the rod. Once I figured out what to do and found the new springs, the repair took about one minute - literally.
It's a very simple repair. You do not need to be a Master Mechanic to do this. All you need is the wrench or socket to remove the two bolts. Finding the appropriate spring(s) will be the most difficult part of the job.
offroader
I may have to break down and try the two setting. Hmmm, wonder if I set them on the wrong number in the dark with my flashlight. Feels more like a five setting.
For those with Rancho's - did ride change / improve after a break in period?
I've had Ranchos on three other vehicles and never noticed this much difference before (in terms of stiff / harsh ride). Maybe it's because the Trooper had such a cushy ride before.
I run the following settings now:
1/1 When mom or dad is in the car or driving, lincoln-like ride
3/3 Normal everyday driving around town near stock ride
4/3 Normal for my everday driving, at least til I do the T-bars
3/5+ Towing
5+/5+ Offroading
-mike
Basically, boiled down, dealers are not sharing the computer codes necessary for independent shops to diagnose what's going on with the engine. Down the road, this could be very bad news for consumers if something isn't done to fix it.
-mike
Jim
-mike
Manufacturers are not allowed to show any favouritism or exhibit any behaviour that can adversely affect competition. In this case for example, Holden cannot withold technical information from a licensed repairer on the products they sell.
Also, as long as a repair shop is appropriately licensed and hence correctly equipped, they can perform a "log book" service without affecting any manufacturers warranty.
The other thing is that the manufacturers of the diagnostic gear need these codes anyway to program the equipment they sell to the workshops.
So much for standards!
They have received criticism for this. But it is true, for the latest model BMW's the dealer has the advantage. Once the cars age a bit the knowledge seems to trickle down to the Independents.
GL5 does eat the brass synchros
The manual should tell you GL4 or GL5 for your tranny. My subaru uses GL5 in both the gears and the tranny.
-mike
Also the diesel MTs are VERY VERY different than the MTs in our Gas engines. Don't forget we don't have TDIs here in the states
-mike
What you describe doesn't sound like it would be a battery problem. Sounds like there is an electronic failure or something about to fail.
You may have read in this forum about getting diagnostic codes checked at Autozone. You should get that done while your car is still mobile and find out what trouble codes are being displayed. That should then tell you what the problem is.
PS... The Check Engine light won't necessarily come on unless the problem is affecting emmission systems.
Well, it's been 8 months and I really miss my '99 Trooper. I had sold my boat, and no longer needed it. Hard to justify keeping it, since I probably used less than 10% of its capabilities.
I looked on my shelf, and I found an unused set of VSW variable rate springs. They are set for 25% increased rate over stock initial, and advance to a 45% increased rate as they compress. If anyone is interested, please email me at kensalen@hotmail.com.
(I keep in touch with the new owner of my truck, who now lives in Portland, Oregon. At 50,000 miles, she just had her first problem: check engine light. Since Oregon is a full-service-only state, I suggested she check her fuel cap, which turned out to be loose. End of problem. God, I still love that truck.
-Front and Rear differential fluid
-Transfer case fluid
-Cooloant flush and change
-Re-pack front wheel bearings
-Lube front and rear propshaft (he was familiar)
-Lube Accelerator linkage
-Lube chassis fittings as needed/known
-Check brakes and battery
It's looking like this will cost $300...I'm o.k. with that, as I have a great level of confidence in these guys to "do it right". They did say the re-pack was time consuming, and that there are about 10 plates to take off to do the various fluids. I think this is a pretty good list that keeps me comfortable with at least a minimum level of maintenance. By the way, transmission fluid and spark-plugs show at 100-120,000 miles! I don't think I will go that far, but not right now.
Also, the original 684's are looking sorry. I have priced some BFG A/T at 245-75/16 at $136 locally, $9 per tire for mounting and all. I think this is coming up soon for the truck.
I still love this truck!
-mike
I have recently installed OME springs and Rancho 9000's. Wish that I had done it years ago. Excellent Upgrade!! My debate now is 265/75's vs. 285/75's. Does anyone have any experience with the 285/75 R-16 size on a 1.5" lift?
If you can talk down the price further, great. But if you can't, you're still getting a good deal on a truck that is already a great value to begin with.
Is a trade-in involved with that price quote? I'm always leery of that, as dealers will typically give a great price on the new vehicle and give you less than fair value for the trade-in, or vice versa.
If they will let you watch, you may want to make sure they do not strip the 3 set screws (per side) that hold on the front hub nut. These have to come off to do the wheel bearings. They are very easy to damage and would complicate any subsequent removals.
I would have them at least check the ATF level now. I would also have the flush done before 50k miles. Then again I am nuts about preventative maintenance and even routinely flush my brake and power steering fluids.
As to the plugs, they will likely go 100k miles. The only kicker is that if you leave them in there 4 or 5 years they might tend to freeze in place.
THese are the kinds of diagnostic problems that I take to the dealer. I have been down this road before, and have paid dearly for an independent shop to try to figure out what was wrong, whereas the dealer got it right away. Their hourly rate was higher, but they were a lot quicker so cheaper ultimately.
When I KNOW what the problem is, then I take it somewhere cheaper.
I like em on mine. Other items to consider when trying to get the sway out:
$20 for Poly Urethane Bushings for the sway bars
$?? Poly end-links for the sway bars
~$220 Sway Away Torsion Bars
~$120 OME Coil Springs
I have th OMEs, Poly Bushings on the sway bars, and the Rancho 9000s. I'll be installing the sway-aways over the next 2 weeks so I'll let you know how that works out.
-mike
I have a set of Rancho 9000s on my 99 Trooper, set at 4/4 all the time. I strongly recommend them.
offroader
Thanks for the info. I splurged and spent the extra $50 to get the RS9000 instead of the RSX. That way there will be no wishing I'd bought a firmer or softer shock. I also like the notion of being able to firm up the rear end when the truck is heavily loaded. The RSXs might respond a little more quickly since they are a true gas-charged shock while the RS9000s aren't, but it also seems like the variable valving in the RSX could be a disadvantage in some cases (just personal conjecture).
Paisan, a few questions for you:
- Can you reach your adjustment knobs without having to crawl under the vehicle?
- Can I use the same shocks with the stock springs as with an OME + Sway Away setup? I may consider that setup in the future and would like to not have to replace the shocks.
I'm currently suffering a little buyer's remorse and wondering if I would have been better off to get some cheap Gabriel GasRyder shocks and the OME springs for my $200 instead of the RS9000s. Oh well, too late now.
Shocks can be used with stock or OME setup, same part #s.
As for reaching them the rears can be reached w/o too much effort, a set of work gloves and you can reach behind the tires (easier with stock sized tires, but doable w/ 275-70s) to do the rears. The fronts you really need to reach by getting under the front, but you are less likely to change the fronts due to loading, so it shouldn't be an issue.
The way I look at the auto-adjustable valving is that they are made to be all things for all people all the time, which leads to being mediocre in all situations. With the manually adjustables you can "tune" them to your own liking.
-mike
Kelly Blue Book
98' Trooper 9,050 Rodeo 9,860
99' Trooper 10,305 Rodeo 11,165
Edmunds
98' Trooper 13,671 Rodeo 12,767
99' Trooper 12,868 Rodeo 17,327 !!!!
I need to trade this thing in now, before it gets worse.
If you plan to change out your Isuzu before 100K or 5-6years you are definitely in for a rude awakening. Their resale is almost nothing, so you need to drive em to the ground or at least over 100K. The trade-off is that for those 100K miles it will most likely be trouble free.
-mike
