Visitor Agreement.
GM if you are listenning, this will be a great place to allow Isuzu to test the concept of a high mpg SUV, which GM can copy if succesful.
Isuzu go for the diesel and hybrid models, it is your only hope to stand out in such a tight market.
Troopers burn alot of oil so I guess this is relevant subject matter.
Both my 1984 Trooper and my 1995 Trooper are big inside and small outside. The 1995 can carry a 18.5 cubic foot refrigerator with the back seat folded and the doors closed. It does not touch the roof or either side when and there is room left over to drive with one up front passenger. Yet, my 1995 Trooper takes less parking lot space than a Camry car, actually only slightly more than a Corolla. And Trooper has more cargo space than a Hummer H2
Am I the only one that saw some bad future news for Isuzu in the US?
Please Keep:
Big sunroof, TOD system, superior build quality, large cargo area, utility truck status (frame on body design), all standard features currently offered.
Please Improve or Add:
CD changer, intake manifold gasket, headlights, lumbar support, shocks, cup holders, D/C outlets.
Also, remember to sue consumer reports in advance for their inevitable slamming of your new product.
Thanks in advance,
Lee
How much worse could Isuzu be hurt by a fuel crisis?
That's just it, the final pin in their US coffin. They might become the world's premiere diesel manufacturer though.
-juice
They get a fluid swap as a cheap attempt to fix whatever may be wrong, but often the tranny fails anyway.
I'm a deferred maintenance kind of guy myself :-)
As to new fluid, in theory it has to be good otherwise they would sell used fluid instead. In practice no doubt there could be some instances of new/old fluid incompatibility or cases where people did the change wrong (e.g. too little added, bad pan gasket reseal, etc.). However, I fail too see the logic of new fluid causing problems by definition.
No doubt changing fluid just as it starts to darken/change smell is the ideal from a fluid purchase standpoint. In a vehicle with an AT dipstick this is easy to check. However, given the lousy Isuzu no dipstick design, routine checking is not so easy. Therefore my practice is to flush about every 3 yrs. Given the price of the fluid and my time versus the cost of a new AT, this just seems like cheap insurance to me.
Just my $.02.
FWIW my AT shifts at a slightly higher rpm from cold starts. I assume this has something to do with the computer control system rather than the ATF properties.
It is intuitively hard to believe that ATF has a multiviscosity rating. There are after all no coiled polymers blended into the fluid are there? Natural skeptic that I am I guess I will research this one some more for myself.
There is a TODECU unit under the driver's seat.
Cut the connector wire for "Front Speed Vehicle Sensor". The wire number depends on model year, so you must find the correct wire number for the front speed sensor for your vehicle model year.
By cutting this wire, when TOD is switched on, torque will be split to 50/50 as soon as the vehicle starts moving. Split is 0/100 when stopped.
Putting a toggle switch there allows you to select between normal TOD mode and 50/50 split mode.
Cautionary note: When the vehicle comes to a stop in this 50/50 split mode, you'd feel a light shock/knock. Also, when TOD is swtiched to 50/50 mode (cutting off normal TOD), the check light under the TOD display flashes and recorded as an error. Both symptoms would not cause any problems according to the dealer.
I don't have a manual, but if someone can help me to identify the wire number for my '99, I'll make this mod as soon as warranty expires.
Here are some wire number info listed in the original message:
UBS73 ('98.5) wire #24 (green/white)
UBS73 ('00) wire #12 (green/white)
UBS69 (unknown yr) wire #16 (green/white)
...Eiji...
It seems to make sense to use a high quality air filter (K&N) and oil filter (Purolator?) to keep the system as clean as possible. From there, the oil has the best chance of doing its job.
I have no idea if the mod will work. I guess it depends on the default setting on the TOD. It if goes to 50/50 when the front speed sensor is lost I guess it would.
Let us know what you find out.
I would be interested in how a toggle switch would work. Good info, thanks.
Thanks for checking the wire location for the '99. Not ready to do the mod yet, but if it's connected directly to the front speed sensor, would disconnecting the sensor do the same thing? Where is the connector location for the sensor? If it's easy to access, I can try disconnecting it and see if it works. It's safer than cutting the wire at the ECU.
Have a question to those who are familiar with this type of mod: Do we have to consider what kind of switch or additional wiring to use for this mod? Do we have to worry about noise interference, etc, as it's connected to the sensor?
Did some checking last night and found a message by a owner of '00 model: He confirmed that the wire number is #12 G/W. Detail: There is a silver TOD unit with two connectors under the (passenger) seat. One with 12 wires and the other with 18 wires. Looking at the larger male connector (B-68), bottom row, 4th wire from left is the #12 (white stripe on green). It's easy to work if you cut tape wrapped around those 18 wires. He's put a switch on the lower side cover below the seat (held by 3 screws).
I saw quite a few messages thanking the guy who posted the modification information and reporting that they'd done the mod, but I did not see any messages reporting problems.
Emiura .... This is great news. Can you post the link to the website? Actually, is it in Japanese or English?
I am just imagining?
Sam
re: '99 grade logic...with TOD engaged, it will slow down when off the gas. The design applies power to the wheels all the time, so when you are off the gas it doesn't coast...so when you need power, the wheels have traction/power and can go.
And yes, I never got stuck or anything, but I one time I did slide and slide down a shallow hill in the snow and have minor fender bender. After that I got new tires, and the difference was AMAZING. I was able to drive quite a bit without 4WD where it was required previously, and braking was hugely improved. There is no doubt in my mind that with better tires I wouldn't have hit that guy.
So these days I don't go into a winter without pretty good tread on my tires, it just ain't worth it to skimp.
When it is very cold here in Minnesota I make sure to drive gently for a couple of miles to let everything warm up.
Thanks for the TOD info, we always suspected there was a way to do that (4HI 50/50 lock). By the end of 2003 I will be out of warranty, so maybe I'll give it a try.
Maybe you should post this info on 4x4Wire also?
Steve
Jim
RE was I Saudi military: Nope, I was an engineer for Saudi Aramco in Dhahran. We had a good life, but it's good to be home in the U.S. again.
RE the Landcruiser: If they weren't so ridiculously overpriced here in the U.S., I'd buy another one. For me, they're the holy grail of SUVs. In Saudi in 1999 you could buy a brand-new 1998 base model GS Land Cruiser(latest body style with independent rear suspension) for $24k new. Cheapest in the U.S. was $40k. You can still find 2002 models for around $30k over there, and I can't get a used 2000 for that her in the U.S.! Even adjusting for the difference in the standard equipment, that's huge. And yes, I thought about bringing one back with me, but the U.S. has really cracked down on the gray market vehicles. So, I went for a Trooper.
RE Monroe Reflexes adjusted to Trooper: I seriously doubt if they're tuned to the Trooper specifically. My feeling is that the rears are a tad too stiff, especially on jounce. My wife rode in the back seat a couple of days ago and felt it was a little too "jiggly". IMHO the KYB Monomax's could be a better match to the Trooper.
Hasta la posta.
http://www.bc.wakwak.com/~zig/bbs/index.htm
Someone mentioned there that TOD 50/50 split info is on YahooJAPAN message board, so I did search with "bighorn".
...Eiji...
Re: TOD 50/50 lock, I've always wanted to have this setting, too. I'm glad that I saw earlier exchanges on this topic which prompted me to do searching.
I'll copy the post to 4x4Wire.
...Eiji...
The Trooper (at least my 1995 Trooper) has no middle differential so differences in front and rear drive shaft speed must be resolved at the wheels. This is why you don't want to drive on dry pavement in four wheel drive. Full time 4wd systems have a differential so they don't bind up. I use my 4wd in patchy ice and snow by stop, engage 4Hi, move forward to engage the auto hubs, while still moving in one direction I then shift in and out of 4Hi/2Hi at any speed. Just make sure the front and rear driveshafts are going the same speed by driving in a straight line and letting off the gas and no brakes applied. I use this method for highway driving. It keeps the front hubs engaged all the time so MPG goes down a bit.
-mike
You wouldn't expect I could get through that, would you?
We got about 24-30" of snow here and with my 1.5" OME Lift + 275-70-16 Pirelli Scorpion ATs I have been plowing through/digging in the snow. I had to bust through several 3'+ high walls of snow that the plows nicely left for me!
I found that with 4-lo I would get into a situation where I'd just be spinning all 4 wheels and not gripping. With the TOD I found that If I kept on the gas it would shift around the power allowing the wheels to grip and dig til they found traction.
Can't say enough good stuff about the TOD. I did some nice drifts on turns as well
-mike
I notice this on my Trooper ATF 4L30 unit as well.
-mike
Have you seen the Amsoil synthetic oil info? If true, it is pretty impressive stuff.
Just some possibilities I've been pondering, but I don't have a service manual to go any further with it.
Greg
I still don't see any reason to need a 50/50 split over 40mph, 40mph in 4-low is not that bad.
-mike
Although I got in trouble for guessing before, I would be willing to bet that the lever mechanically changes the gear ratios in the tranfer case. You can feel it change when you move it, and when you move it while moving it grinds a bit as the gear teeth mesh. I think you're wrong about this.
Tom
You may be 100% correct though, I'm not convinced of my own conclusion on this one.
-mike
