And thanks for straightening me out on sway bar bushings. I knew that. I was calling sway bars the wrong thing. Geez.
-mike
I really need 3rd row seating badly. I like the idea of a split 3rd row - one that will allow an extra seat AND room for a stroller or an enough area for a large ice chest. I'll need the split 2nd row bench to be help get access to a 3rd row. I took a look at the Australian version that fold up to the side. I REALLY like those! I'll order one if they will they fit into the older 1991 Troopers, like mine?
Any help and ideas I can get will be greatly appreciated. I just don't want to have go out and buy a minivan! Getting these seats in will be much cheaper!
Bob
The 3rd row seats as found in the 92 and on Jackaroos in Australia don't fit into the 91. They are too wide for the 91 interior. It would also need some significant cutting and welding to get the attachment points installed. Your best shot would be an aftermarket 3rd row seat.
However, that would leave you with a storage problem as the 3rd row does consume a lot of space even when folded up and not in use.
My suggestion would be to have a think about replacing the 91 with a newer Trooper if you can. The 2nd row seats are wider than the 91 so you should be able to have the 3 child seats across and you will have more storage in the back. You will also then have the option of the split 2nd row too. Even just going to a 92 should do the trick for you.
I've been browsing through a few websites about the place. It looks like the only place on the planet that no longer gets the Trooper is just the Americas and Japan.
In Australia, NZ, UK, SE Asia, Africa, etc, it is still a current product. In fact, Isuzu in Japan has just re-launched it's English website last month and shows the Trooper as a current model.
Some confusing stuff going on with good ol' Isuzu!
-mike
Thank you for your suggestion. I will be looking into the aftermarket 3rd row seats, but I'd like to get a rear seat that faces forward, folds and is easily removable, if possible - and hopefully one that is a split bench. And, I going to have to find a used 2nd row split bench somewhere to replace the OEM bench just to be able to get to the 3rd row seat too. Surely there is another vehicle's 2nd row split bench to be found that (with a bit of machining work, of course) can be made to fit into the 91 trooper.
I really want to keep this 91 Trooper instead of trade up to a more recent year model. I'd rather spend $500 to $800 on new seats to make it more useful, than spend thousands more on a newer Trooper (or a mini-van!). The newer Troopers are nice too, but I especially like the looks, ruggedness, simplicity, roominess, and overall utility of these pre 1992 Troopers. If I can squeeze at least 5 more years of good useful life out of my Trooper with the only cost being for a few modifications and parts, then I will be very happy.
I just hated to see Isuzu rebadge a GM Trailblazer and sell it as a Trooper/Ascender. What made it worse to me was Isuzu denying rumors a few years ago that it was going to replace the Trooper with a GM vehicle.
The other interesting thing I found out off Isuzu's new english website in Japan, is that the Isuzu Thailand factory only produces vehicles for the local market however it contracts its export production, including DMax, to the GM Thailand plant.
Which is where I guess the Australian Rodeo is coming from and where the Jackaroo will come from. The Holden Rodeo has always been a really good pick-up and is the second best selling in the country behind Toyota's Hilux. There's no reason why it can't be number 1. It's just a Toyota perception thing that keeps the Hilux in front.
If Holden marketed the Jackaroo and Frontera the same way it markets the Rodeo, they would have a much bigger slice of the Australian 4WD market.
My insurance should cover repairs but I am leary of how a body shop will do these type repairs. I don't want a bunch of bondo all over and then repaint. I have never seen a repaint that matched the quality of the factory. Anyone tried any of these new dent remover techniques that seems to be a cure all? Think I should just take the insurance $'s and just live with it?
For the record, there was a Montero in the same parking lot that looks a whole lot worst than my Trooper. Plenty of pissed off folks.
When I picked up my 2000 Trooper, it hailed on the day I was picking it up. Later when I got home and the light was right, I could see hail damage. Took it back to the dealer and they used their dent remover on the hail spots. They use an UV light to identify all the hail spots and then went to work. I was very happy with the outcome. If I get out a magnifying glass and look at where they fixed the spots I can see a very slight difference in the "orange peel" of the paint. It is not visible to the naked eye, and no one has ever noticed it. I would give it a try as I was very happy with the outcome of mine.
Does anyone know where I can get the Overlander rack "Feet" for the Trooper, the type that bolt into the recessed rain gutter? I tried Overlander.com but the web site is down. I need to get a rack system in place before my June 1 road trip to Louisiana and the Outer Banks of North Carolina. Any sources would be appreciated.
Nearly 1,000 miles in the "new" Trooper. Lovin' it!
-mike
I understand that there are two methods of repair:
1- the traditional body shop method - bondo and repaint along with replacement of panels such as the hood.
2- dent removal - a new technique that supposedly does not require repainting.
I have approximately 50 dings all over my Trooper. Anyone familar with the pros and cons of these techniqes? How about the devaluation of a hail damaged Trooper - any examples on pricing? I am sure a perspective Trooper purchaser will want the nicest example he can find and in order to take a not so nice one, the price would have to make the deal enticing. I'm thinking of going for a cash settlement from the insurance company and just live with the dings.
The real bummer is that more hail is predicted here over the next few days.
forgot to pull the key out. After jump start
(Isuzu roadside assistant) I noticed something are
different now from before.
Now it takes longer to get the engine to start,
maybe >3 times longer than before the battery was
dead. Could it be that the battery is too weak.
My car is 4 1/2 year old.
The car used to get started as soon as I turned
the key.
Before I always set the trip odometer to keep
track of the mpg. Every time I started the car
it always showed the trip odometer.
Now it always shows the odometer when I start the car. I need to set it to trip odometer every time
after I started the car.
Odometer does not reset itself to 0, still record the previous trip mileage. It's just annoying to
set it to trip odometer every single time.
If I stop the engine and pull the key and restart
again in a FEW minutes it will show the trip
odometer.
I am wondering if this is a common problem. Would appreciate any feedback on this.
Izooper
-mike
Mine did that trick with the odometer too when the battery was dying as well as taking longer to start.
I think you will also find that the battery was already dying rather than it ran flat when you left the key in. It's not holding much of a charge now when you leave it for any length of time.
Change it soon, or you will be calling roadside assistance again in the not too distant future.
OUCH! Not fun for a struggling self-employer, who just gave a bunch o' dough to the IRS. (Have to keep reminding myself that i was due-i got 220,000mi out of my 91 Accord's original clutch.)
Mechanic said the spring btwn the release bearing and pressure plate broke (i was still in sticker-shock, so i hope i'm remembering this correctly). He said it's a common problem; he's fixed a half dozen of them over the last year or two. His opinion is it's a bad design (a "pull out" mechanism vs. a "push in"). Curious to hear what others' opinions, thoughts, and/or experiences are...
grayarea
atlanta, ga
http://www.isuzudealers.com/
I was wondering if anyone else had this condition. It is a deep throaty engine sound, almost like it is straining, the sound of an old tired engine. This occurs when accelerating (down shift). Once it shifts up to 3rd and 4th, the smooth engine sound comes back. The vehicle is very peppy, just has the sound. When I am parked and I race the engine, the sound is smooth. There's on 16,000 miles on it, I put 1,500 on it as the 2nd owner. The sound gets quieter as the engine is fully warmed up. On slow acceleration, i just get a smooth sound. I thought I had an exhaust leak in the muffler that only sounds when there is greater back pressure. Is this possible? Sound seems to be a quieter since my first oil change to 10W30. Got a little better when I changed again to 5W30. Think I should go to 0W30?? Could it be a valve adjustment is in order? Looking forward to any comments or suggestions.
-mike
alexey
It sounds to me like you could have a suspension not engine, rear diff or AT problem. Right as you come to a stop the suspension is acting to bring the front end back up (it tends to drop when braking), the rear end back down (it tends to rise when braking), and the body and frame back over the wheels (the wheels stop first and inertia means the body stops last).
With a proper working suspension all these movements are very small and controlled. If could be you have something like worn shocks or springs allowing the excessive movement you feel when coming to a complete stop.
Also, have you tried shifting into neutral and then stopping? If the symptoms stay that would seem to rule out the engine and AT.
Just my tenative $.02. I really don't have a firm idea of your problem.
Tom
Thank savvas and Paisan for your input.
Has anyone seen this list?
Wow!!
If I plug in all the options on my Limited Trooper with 51,000 miles and OUTSTANDING CONDITION, I get $12,562 Private Party sell.
Since my Trooper is hail damaged, I plug in AVERAGE CONDITION, and arrive at $10,870
Shoot, if the hail damage estimate is more than $2,000 dollars, I guess I ought to just pocket the money instead of get the dings repaired.
BTW, someone told me a crazy story that I find hard to believe and that is that the hot summer sun might cause hail dings to go away. That heat on the metal causes metal to shrink. Sounds kinda way out to me. Anyone hear anything like that?
With the exception of water (which expands when it freezes), I am unaware of anything that contracts when it's heated.
Tom
Jim
You have 10/120m warranty so it's not really an issue. 2 weeks is about right for a tranny from Isuzu. Heck they are usually so reliable, they probably have to build one in france and ship it over!
-mike
