Visitor Agreement.
-mike
"The percentage following the vehicle is the total amount of DEPRECIATION that takes place over FIVE years and 15,000 miles per year."
2. Isuzu Ascender — 68.74%
5. Isuzu Axiom — 66.96%
9. Kia Sorento — 65.57%
It changes to its normal self very suddenly, when the high idle kicks down. I suspect that the engine is running much richer during this period.
Whatever. It's been like this since I've owned it and it just is what it is.
I just had a tranny flush that didn't help. Are these trannys known for harsh downshifts?
Scott
-mike
A previous poster found a new 30K$ 2002 Trooper for +/- 20K$.
I had a similar experience.
LEXBALLER22 posted: egr valve. I took my trooper to the dealer. They charge me $117 to tighten the egr valve and tighten some exhaust problem. And it sounded like a dream.
I'll look into that!
Thule recommends nor more than 30" on the bar spread? So I keep it right around there.
When I added my fairing I had to move it to 4" from the edge of the front door. I never measured from the windshield back. That didn't seem like the best way to fit it and for looks.
It is much easier to get accurate and even spacing measuring my way than from the windshield. I also think it looks much better further back and is slightly easier to load.
My post today is to inform you that my 2001 Trooper LS is no longer mine. I traded it yesterday on a 2001 Montero Ltd w/ 26K on the clock. I put 36k of trouble free miles on the Trooper in a little over 2 years time. I will miss the Trooper but look forward to a rewarding future with the Montero. If Isuzu offered the third row seat here in the US I would still have the Trooper.
By the way, I got $16,500 out of the Trooper (Leather and sunroof) with a cracked windshield (happened last Friday) and a few solid door dings and scratches.
-mike
had a similar noise come up last night on my 97Trooper-S. no performance problems just the noise. happened by my mechanic today. he noticed the EGR pipe had come loose. "was your Check Engine light on?" (nope.) he reattached the coupling and had me on my way in 5 minutes. no charge.
the tube was not separated from the valve; just the coupling had come loose.
(isn't that the 2nd law of thermodynamics: "stuff comes loose"?)
Little Passenger Seats makes one that folds flat against the second row but they don't have head restraints. I got tired of waiting for them to offer the restraints and the last time I called was told that they weren't planning on offering them on that seat.
In Australia, the Montero is sold as a Pajero. It is fairly common to see bits of their bumpers around 4WD beaches and sand dunes.
Have a read -
http://www.exploroz.com.au/Forum/View.asp?ForumQID=4198&Page=- %2FForum%2FDefault%2Easp%3FDisplaySet%3DBoth%26Search%3D1%26Keywo- rds%3Dpajero%2B%26PN%3D2
Otherwise, they're a good vehicle. Enjoy!
Question, the last service the Trooper about 6 months ago at another Isuzu dealer, where a tranny flush was performed. I recall a month ago looking under the Trooper while it was on a lift and noticed the transmission bolt wet with ATF. I know that the last mechanic that worked on the Trooper was an Isuzu tech. Now I am paying out of pocket for a rental. Is there anyway I can prove this and have the dealer that did the tranny service cover my rental cost? I want everyone $.02.
The transmission service guidelines (at least in Australia) specify that the gaskets on the transmission's overflow screw and drain screw be replaced every time the screws are removed.
Could be that didn't happen at your last service, hence the leak. It's mentioned in the link below -
http://www.geocities.com/jackaroo4wdclub/techtalk.html
So far in 50K+ miles on my '00 Trooper I've only had minor problems with it, none related to what I would consider "reliability" factors. If you can find one, jump on it, if not, find a slightly used one for an even bigger discount, and you'll have a vehicle that is slightly broken in.
-mike
You might want to keep some of this under your hat until AFTER Isuzu puts in the new AT. You don't want to give Isuzu any reason not to cover the replacement (e.g. it is the first dealer's fault go get your money from them AND/OR if you noticed a wet drain plug a month ago it is your fault the AT failed as you should have checked the level back then).
Just my $.02.
With mine, you could always clear the problem by turning the engine off for 30 seconds and starting it again. In March, it was doing this at least twice a week.
In Paisan's experience, it was tracked to a blown brake light fuse.
With mine, nothing specific was found. Because we were shutting down immediately when it occured, no DTC's were registered either. It was thought the transmission was reacting to a poorly performing engine because of clogged injectors. The injectors were cleaned at a service at the beginning of April and there has been no problem since.
However, I also had a blown brake light bulb, which I didn't know about, replaced at the same service!!! It's only a slim link with Paisan's experience, but it was there.
1984 TrooperII 1.9L 4cyl 80hp $11K
1995 Trooper-S 3.2L 6cyl 175hp $22K
2006 Trooper-DieselHybrid $33K ?
My cost of driving has been very low. From 1984 to 2006 I will have spent 33K on buying Troopers and put 400K+ miles on them. I have had only scheduled maintenance and normal wear out parts replacememnts. Compare that to buying a "luxery SUV" for $50K+ and having $33K depreciation in the first couple years. Repeat this "luxery SUV" arrangement six times in the same 22 years and pay $200K + repeairs and breakdowns. I bet the cost of buying my two new Troopers is less than the cost of the "luxery SUV" repairs and breakdowns. So I figure Isuzu Troopers may have saved me $200K!!! compared to the "luxery SUV" route.
-mike
Midsize SUV: Toyota 4Runner, Nissan Pathfinder,
Isuzu Trooper.
The electronics on modern cars are getting so complex that anything can be causing the problem.
BTW, my gear indicator on the dash did the same thing. It would hesitate, indicate the wrong selection, sometimes not light up at all.
One other symptom I tested for was what happened when 1st gear was manually selected and held. Accelerating from stop, the trannie continued to shift up to at least 3rd gear. I didn't continue with the test after that.
Let us know how you go with it.
Jim
I don't think anything got bent...but I am not sure how to tell? Maybe an alignment shop? Anything like that would require an insurance claim...which means rates go up.
I guess visual inspection and road test will be enough?
Sbcooke, if the accident was not your fault, your rates aren't going to go up unless you are someone who consistently files claims. At least according to my wife, a State Farm agent.
Tom
Jim
Tom
Fortunately I really didn't get more than a couple of scrapes on the underside of the bumper and some paint on my tow hook. The amount of damage I have gotten off-roading is much worse. It is sad to say that I already have a beater...with only 35K on it.
I'm currently going to a third crossbar using the brackets available at Overlander that bolt to roof as I need a permanent rack to haul everything from canoes to lumber. Like the Yakima system as I can use the tower on other vehicals.
-mike
I did Dutch John, which is rated as Difficult, so I'm pretty happy with that. We had a ton of rednecks watching us with our NY and NJ plates saying "I gotta see this, this should be funny" but each time we impressed
-mike
I'm not against any aftermarket products. Do what you want. What I'm against is people leaving their ball hitch in the receiver because (a) they think it will protect them, and (b) because they feel anyone who rear ends them deserves extra damage to their car.
My whole point is that a trailer hitch is not designed to absorb impact damage like a bumper, and one could end up with a costly repair by routing impact forces through the trailer hitch. One good hit, and you'll drive that receiver clear through the gas tank. If that possibility doesn't concern you, then knock yourself out. Actually, the "bumper protector" thing doesn't really bother me because that's like another bumper. It is unlikely that your protector will go through a radiator like a ball hitch will.
Tom
FYI the front and rear of the frames on the trooper (and almost all frame based vehicles) is perforated at various spots so that if you do whack the frame hard enough, it will collapse.
-mike
-mike
So much for the IIHS tests. My wife backed into a 3 foot cement wall (hit the bumper) and I was rear-ended...both of which caused minimal if any damage to my Trooper.
