So I expect less of an improvement in my 3.5L than I had in my 3.2L because the high voltage wire loss is not in the 3.5L, but the resistor wires are still there. The kind of improvement is quicker starts, less hesitation before warming up, and smoother stronger engine revs all the way up. Because the duration of the spark is much shorter and with much more energy, more of the fuel is more reliably ignited at the exact instant desired and that allows the engine computer better control which gived a smoother running engine. More torque is available especially at high rpms because the fuel is ignited sooner it has more time to burn completely, emissions will also be lower. If you always drive your Trooper with the lowest RPMs and never push it, you might not notice the extra power, but you will notice the quicker response.
Yes, they work for me. I am currently installing DirectHits on my lawn mower and I might also put them on my backup generator and 6hp outboard motor. Outboard motor will wait until the 90 degree version is available so it fits inside the cover.
I am not selling DirectHits, I just know they wok for me. I think lots of things are snake oil such as oil additives and many have bad side effects, but I used the DirectHits for years and never had a problem. Some things are not snake oil and work real good without side effects such as drop in replacement K&N air filters and higher capacity top of the line oil filters, DirectHits is good thing like them.
A Trooper's spark plugs are very easy to change yourself. If you get DirectHits get the complete kit it is worth it for the best effect.
The offroad.com article was intersting.
DrSpark@DirectHits.com
http://www.pureoil.com/pureone.htm
http://www.knfilters.com/
I called them directly and spoke to someone who wasn't sure if they had an application for it? After checking, he said after 1997 Isuzu moved to a "coil on plug" ignition system. He said that since our ignition system is "plenty strong enough" I would see just as much benefit from just a standard high performance plug.
So I replaced it with a 2001 manual 5 speed Trooper which is a rare find that I am grateful to have the oportuninty to buy. Now I have the coil over plug and I understand that the DirectHits improvement would be smaller than it was on my 1995, but I liked them very much on my 1995 so I would still consider giving them a try in the 2001.
Headers ... I looked at getting headers for my 1995, I even found a place that makes aftermarket stainless exhaust for the Trooper named "Duty" in the UK. The design guy there told me that the Trooper's exhaust is already well optimized and unless I wanted a lot of noise I would not see a performance improvment. On the 1995 there was a single catalytic converter, on the 2001 there is dual exhaust with dual catalytic converters all the way back to the muffler. The 2001 has a growl if you step it down hard.
My question is, how or when do I know to replace my oil pump? The oil dip stick indicates full. With the engine running and looking down through the opened oil cap hole I can see some oil moving about the valves. The engine is not overheating and all other gauges read correctly. On an unrelated note (I think it's unrelated), my starter is about to go out but that should not have anything to do with the oil pressure gauge - should it?
I need help with this one. I know the oil pump runs about $200-$250 but requires MUCHO labor. Can there be something else wrong that would make the oil pressure gauge act up?
Therefore my advice is to ASAP try a real pressure gauge or have a shop do it for you.
The also cleaned my IAC valve...Idle Air Control, with no luck. I guess there are 2 IMG an upper and lower. The upper is a quick fix and lower may be more involved, however either should be easy for a mechanic. They may be stalling you because they cannot isolate the bad gasket at this point.
Got 20.5 MPG on my run from Denver to the San Luis Valley over Labor Day weekend. My speed varied from 75 mph to 40 mph. Went over two small mtn passes: 10k feet & 9k. Had Wife, 3 kids(small) and inside back of Trooper completely loaded to the top.
I'm running Mobile 1 in Engine and diff's, with K&N Air and Oil Filters. Tires are the factory stock 684 Duelers. Shocks: Tokico Trekmaster R/T.
I've even been impressed with my 4 wheeling MPG. After run up highway, spend most of day in and out of 4x4 low, then come back to town - still get 14-15 mpg.
Trooper continues to impress me with ability to run quiet and smooth on the highway, yet can tackle moderate Colorado 4x4 trails with ease.
Likely better places to spend the money like accessories.
I believe the IMG is just a vacuum leak, so varied effects based on temperature and drain on engine could yield different results. If it is driveable, try to go a little longer to see if this problem gets worse? It will be easier to identify at that point.
I managed to squeeze 53,216 out of the stock Duelers and, surprisingly had a bit of tread left.(mostly highway with only occasional off roading). So far I'm blown away by the handling and performance in the rain. I've yet to see how they do in the snow, but in Northeastern Ohio that will soon not be a question!
Have any of you had experience with Toyo tires and if so what has been your reaction thus far?
-mike
http://www.bobistheoilguy.com/images/lucas/lucas.htm
Tom
I would lean towards Mobil 1, it's been tested and certified to industy specifications. http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil1Synth- - - eticGearLubricant.asp
To me that is a far more convincing test than a few gears in a box. And I have used Mobil One for at least 15 years now, with nothing but excellent results.
This is my 1st experience with body shop does anyone had some thing similar? If so what should I look for or request from the body shop and/or GEICO? Any other suggestions would be highly appreciated.
Stan
BTW air bags surprisingly didn’t pop !!!
For example, whe I had repairs done on my 1995 a few years ago, the winshield washer pump housing was broken. It is a plasit part, they tried to glue the impeller housing back together. When I put in washer fluid it all ran right out. The inner fender liner plastic part same story and I did not catch that one, I repaired it later when it fell away at the front corner where a mounting hole was enlarged and rubbed the tire.
You radiator leaked? Was it steam or was it just fluid running on the ground? If no steam I suspect the radiator did not break, but the air conditioning condenser did. If you were running the A/C they might need to also replace the A/C compressor.
If you are already having a > $2500 insurance claim, then go for it and get every possible accident related thing fixed as best you can even if it runs up the price, after the $2500 your insurance rate will be going up anyway.
Rethink your insurance after an accident. I ended up increasing the deductables on mine as high as allowed to $1000 I think. I also had three cars on the same policy and they were going to raise the rates on all three. So I removed the Trooper from the common policy and opened a new policy with the same insurance company and saved hundreds of dollars a year. When the insurance price hike expires after 3 years usually, the insurance rate should come down, but my insurance said it would not go down until the next annual renewal period... Another time to cancel the Trooper policy and put it back on with the other car (we only have tow now) to get the lower rate right away. Again within the same company. If they will not play this with you change insurance companies. We went through all of our insurance policies and raised the deuctables and other optimizations, like years ago comprehensive was dirt cheap, now it is high, so we raised that deductable too.
Best of luck with your Trooper. Let the repair shop know you will be very strict about your acceptance inspection and you will have "before" pictures and hopfully they will not cut corners too much.
as far as radiator, after the crash it was just leaking no steam at all and i was not running a/c.
i appriciate you insurance suggestions, i think i 'll have to do the same i.e. pull the trooper out of the family policy (my wife car on it also) to save some money.
Stan
In case you missed it:
Engine Oil - A slippery subject Part 2
I've used dead dino for 30 years now with excellent results :-)
I was a bit surprised by Bobtheoilguy's test, since I thought he sold and promoted synthetic oils.
I drive em all hard, so I've opted for synthetics in my Trooper. For my race cars that were on dino for most of their lives I stick with the Dino in the motors and Redline in the driveline, since Redline doesn't breakdown the seals like traditional synthetics.
-mike
Well, the lights didn't come on. I checked the following:
- The lights themselves are fine (tested with a 12v battery)
- The switch lights up when pressed. I assume this means it is powered)
- No power to the connector where the lights plug into (in the wheel well).
Any hints will be greatly appreciated.
Sam
Post 3274 and others indicates you need one. pinoy99 Feb 7, 2002 10:30am
Now I have another problem though. I was measuring to see if there is current going to the fog light switch, but I must have shorted something (I smelled it). Now the instrument cluster light (that is controlled by the dimmer switch) doesn't come on at all. Don't see a fuse for it.
Could it be that checking the for light switch shorted the dimmer switch? All other gauges and warning/status lights work.
Sam
It may not be labled like you would expect, I had to pull pretty much all of them to find it.
The private party Troopers have some stuff different that the rental ones, I think this varies by year. But the rental ones are called LS even though they are basically the S model with a few custom differences.
I found that the percentage of Troopers for sale with manual transmission is very low. I had the best luck on cars.com which is essentially a listing of all the local news paper ads in the USA.
Good Luck
boxtrooper
BTW, how reliable is the Trooper compared to say a Toyota SUV ? Sorry to bring this lame issue as I am sure it has been discussed over and over here. Is it reasonable to expect a Trooper to be a daily driver and last 5+ years until 200K + miles ? I try to keep my cars for a while so as to get the most out of them.
-mike
The Trooper takes no more parking space than a Toyota Camry or Chevy Lumina sedan. It turns much tighter than either so can get into those parking spaces. Trooper has excellent visibiity and is very rigid in the frame for excellent towing. Trooper has very good articulation so it is great in the snow or off road.
I added a third row seat from LittlePassengerSeats.com.
I drove my 1984 Trooper 201000+ miles and it was running great when sold.
I drove my 1995 Trooper 140000+ miles when it was running great with no lifter ticking and looked nearly like new inside and out even with kids in and around it very often until it was totalled by the airbags going off from a hard rear ending that crumpled the front end and roof of a large Volvo, the Trooper protected all inside and was still very driveable, but airbag replacement was $6000.
I have my 2001 Trooper with 33K so far and I expect to fill out my 30 years of Troopers with this one lasting untill 2014 and beyond and probably 300K miles or more.
A total price to buy all three Troopers of $47500 for 30 years of faithful service and 500000+ miles is my plan. Try to come anywhere close buying any other family utiliy vehicle that is so much fun to drive.
When my wife had a new minivan we still took the Trooper on any trip where we were wanted the most reliable vehicle.
any info would be appreciated.
