Isuzu Trooper
1170171173175176233
    When I want/need the front side windows cleared, I put the fan setting on vent instead of defrost and point the outside vents at the side windows. This seems to work better than the defrost fan setting for clearing the side windows. I've had similar experience on other vehicles.
    Are you using the selections "Outside Air" and "A/C On" when you defrost? I have a 2001 and will venture into the frozen North soon, so I want to know what to expect from my Trooper. Must decide to take the Trooper or the Minivan. Minivan is easier to separate kids and let them watch DVDs. Trooper can be set up for DVDs too, but I give up my elbow room for the player on the armrests. Trooper is awesome in snow, on one previous trip using 1995 Trooper progress stopped up a steep hill on the state highway when we were one of the first to make tracks through 10 inches of new unplowed snow. The one rear wheel (open differential on 1995 Trooper-S) just kept spinning and we were not moving, but all I had to do was switch to 4wd and we were back on our way. Now, if I will have to work hard to keep the windows defogged in my 2001, that is one more reason to take the minivan.
  • sdavitosdavito Member Posts: 71
    The fan in my 2000 started ticking, and stopped working from time to time. Once the fan started blowing, it would work properly until I turned the engine off. It finally stopped working all together, and I had the motor replaced. This solved the problem.
    BTW, the service tech told me that my Trooper was the 2nd or 3rd in the past month to have the same problem.
    David
    The windshield and side windows were fine for driving. I just had to play with the settings to get it right. I found that putting outside air on instead of recirculate and a little cooler helped.
    If you are expecting decent snow on your trip, I would take a 4wd vehicle.
    Also my performance seems to be worse than when new, so I doubt you will have a problem with your 2001. I will have to try to clean the motor out, I really don't like dashboard work. What is the best way to access the fan motor?
  • noisuzu4menoisuzu4me Member Posts: 2
    Owned a 86 TII and got over 225,000 miles out of it. Was so satisfied with it that we bought a 99 Trooper to replace it. But after recent experiences I'll never buy another Isuzu product. So a heads up regarding the troublesome engines (excess oil consumption). Ours was using qt. of oil every 1000 miles but we kept close watch on it and had oil/filter change every 3000. Lot of interstate travel miles on the vehicle - 128,000 miles in Sept. Engine goes leaving my wife stranded 4 hours from home. We have it towed back to local dealership after Isuzu dealership in Vienna, VA gave an estimate of $7,578.00 to replace the engine. Duncan Isuzu in Blacksburg, VA replaced the engine (plus new clutch and starter) for $5,633.00.
    Of course we are way out of warranty and can be thankful for Duncan Isuzu service department. Had bad engine taken apart by ASE certified mechanic (who is an auto service tech teacher) and found a spun #1 rod bearing. Everyone has said this is unusual. BTW – Northern VA dealership said the engine failed due to lack of oil without ever looking in it. Mechanic showed me the engine and he has shown his students as an example of a well maintained engine. Nice tan oil finish, no gunk and great looking inside (except for the failed part).
    Even though out of warranty I sent Isuzu a letter (BTW - address in warranty manual is no longer valid) basically asking for some consideration for the failed engine and also more importantly Isuzu only gives a 12month/12k warranty on the new replacement engine and asked it be bumped up to at least 36mo/36k miles. Tells you how much faith they have in it.
    Got a response letter 6 weeks later and they declined any assistance. That's fine they had no obligation to do anything. Isuzu could have kept me as a future customer by simply extending the warranty and tossing a token to me for inconvenience. Heck $50 would have at least shown me the company wanted to keep me. But they made their decision and mine is to never buy another Isuzu product. Isuzu has lost at least 2 new vehicle purchases over the next couple of years. I'm helping my nephew buy a 4WD within the next month and will definitely not look at Isuzu. I'll buy new in 18-24 months and it will not be an Isuzu product.
    Just wanted to let people know what you may be dealing with in the 99 engine. We probably hit the 100K mile mark before a lot people. Wished I'd listened to my wife and got rid of it right after it went over 100k. Live and learn...
  • serranoserrano Member Posts: 107
    Noizuzu4me - sorry to hear about your failed engine and experience. However, the vast majority of owners here seem to have positive experience from their Troopers, to include the '99s. With the exception of oil consumption, which does not seem to affect engine longevity at all, most are getting many miles on their vehicles. You appear to be the statistical abberation.
    Again, sorry it didn't work out for you.
    Tom
  • rwcosrwcos Member Posts: 5
    Isuzu won't be around in four years!!
    Noizuzu4me I hope your replacement engine does not burn oil. Maybe in 18 to 24 months you will be less upset and keep your new engine Trooper longer.
    Is the replacement engine exactly the same? Are there some updated parts inside?
    Keep all paperwork and add to it some evidence of the skill level of the mechanic and shop that did the replacement. With the proper information, I would not hessitate to buy a Trooper with a replaced engine.
    I heard of a guy that forgot to put his oil fill cap back on, stuffed a shirt in place of it. The shirt got pulled in and torn up and spread around enough that he replaced his engine as well.
    if they jump on the diesel bandwagon starting in 2006. Isuzu can compete with its diesels. I would like to see proudly displayed "Isuzu Inside" labels on lots of vehicles. Isuzu can come back with its own SUV and add a diesel version of the GM minivan to that. maybe even a diesel hybrid minivan. It has been my experience that many minivan moms like to worry about the cost of fuel and brag on the MPG they get. So a 40 mpg diesel minivan would sell real well as long as it does not smell bad, and the low sulphur diesel fuel of 2006 will take care of the smell.
    Isuzu must enter its SUV in off road challenges that get publicity in the USA to create a following or they cannot compete in SUVs.
    The slow sales of the Axiom show that people looking for luxery or high performance sporty SUVs don't look to Isuzu, so sell then utility and efficiency instead.
    I would like to see Isuzu become the SUV maker known in the USA for building SUVs that cost very little to operate and last forever on the toughest of trails and routinely outlast the other SUVs in total vehicle miles.
    Let the Isuzu be the simple dependable lovable workhorse passed down from generation to generation while the others are the finicky show horses used mostly as a fashion statement.
    Well, 2 of the good dealers in my area packed up shop. 1 of them, just TODAY, while my TRUCK is in their shop! Go figure. So now they diagnosed my problems, they can't fix em cause they can't get the parts and aren't an Isuzu dealer. This after I waited a month to get my appointment! How is that for luck, on top of it it was there last weekend in the snow, luckily I have the AWD SVX around.
    So now I have to start over at another dealer :(
    Also they said my tranny fluid was dark and that is only in 17K miles, so I'll get that flushed before I hit the next dealer on the list.
    Very discouraging to not be able to get it fixed.
    As for oil consumption, the dealer started an oil consumption test, although I'm sure that since they aren't an Isuzu dealer now, I'm gonna have to start it all over again! Ughhh what a mess.
    -mike
    Dependable and lasting 200K miles isn't good for sales, because it takes people 10 years to buy another one :( That is part of the reason Isuzu is doing so badly, because it takes the loyal owners so long to buy a new one (cause they don't have to)
    -mike
    Isn't the engine covered in the 5/60 powertrain warranty? Mine is up in August.
    Paisan what problem is it in for?
    oops...just realized you said over 100K on the truck.
  • pinoy99pinoy99 Member Posts: 79
    IIRC, 99 do have the 5/60k, warranty, 2000-1 10/100k, 2002 7/70k.
    My 99 did not start consuming oil until about 60k which is about the time I change to 5.38 gears/33" tires(up from 4.30/29") which brought up my highway running rpm to 3k. Truck drinks oil at about half to 1 quart per 1k miles, depending on brand/weight used but consumption is more when the oil gets dirtier. I have more than 150k now. Problem seems to be that the piston ring is sticking due to poor design/drain back which causes carbon build up. Supposedly, late 2000 and up models have the redesigned pistons. Anyway, I am hoping that soaking the pistons with solvent will free the rings and get rid of the carbon. This procedure seems to work on Saturn cars that have similar oil consumption problems. I will do this procedure when I am due for my next oil change since one has to dump the oil after the soak.
  • sdc2sdc2 Member Posts: 780
    So they do that "soak" without opening up the engine?
    The procedure is to take out the spark plugs, add solvent(~1 to 2 oz) to each cylinder hole, let sit overnight to ensure that solvent soaks past the rings, crank engine without the plugs but cover holes with rags/towels(to catch excess and/or prevent hydrolock).Reinstall plugs and go for a ride(preferably with few WOT's) to clear it out, then do an oil change.
    disclaimer: procedure is to be done at your own risk.
  • wildbucwildbuc Member Posts: 88
    What I don't understand is why it costs $5600. to get a new engine. Around here (NC), you can have one rebuilt for $2000., and you can get used ones from a salvage yard for less than that. I would also look into the possibility of installing a diesel motor from overseas.
    Go to eBay and type in Isuzu engine. Two diesels are being advertised.
    I have a story about the "soak" method from my dad. Back in the late 1940's to early 1950's he had a car (Studabaker side draft straight eight I think) that needed the soak treatement. Something happened between the time that he put in the solvent and the time he was to restart the engine that prevented him from running it. I think there was a reason he could not start it, bad starter or something, and there was a job change or other distraction and he had a second car to use, anyway, when he got around to trying to start that engine, the solvent was dried and gone. But the carbon which had disolved and moved around was not gone, it was re-hardenned and the engine could not be turned by starter or by wrench and long lever. he ended up taking it apart and using a piece of wood fence post about the diameter of the pistons and a sledge hammer to break each piston free after removing the crank shaft so the pistons could be freed individually. This work took place in a snowy alley no garage or anything like that.
    Short Summary: be absolutely certain to get the engine moving again before the disolved carbon hardens again.
    The replacement engine cost $3,500. The rest is labor($1,175), small parts and then we also had the clutch/pressure plate and a new starter put on at the same time ($650). Given the great condition of the rest of the vehicle we opted for new factory engine instead of rebuilt or used. I actually don't have a grip with the service department at the dealership that did the work. They saved us $2k over the crook/service manager at Isuzu dealership in northern Virginia that was going to take advantage of my wife being 300 miles away from home.
    My grip is Isuzu doesn't understand good customer service relations. In the letter to Isuzu customer service I only asked for some consideration given our maintenance of the vehicle and our 15 years of loyalty. The fact that they will give away $1,500 rebate on a new vehicle but won't even toss a few dollars to a loyal owner shows they haven't figured out what customer service is all about. Todays successful companies know they have to keep their customers happy on both ends ... not just long enough to make a sell.
    And by the way they lost another sale today. A co-worker quizzed me about Isuzu. He is going to buy a 4WD and had heard me brag often about my Isuzu and was thinking seriously about a Rodeo. I told him about my recent experience and he has decided not to even look at an Isuzu. See they don't get it. Consideration was all I asked for -- not paying for my engine. I'm serious when I say a $50 check would have made me happy just to know they at least feel I have some value to them as a loyal customer and owner.
    I had mine replaced, well just the lower half, a "short block". It was about 6-7K for the job at an Isuzu shop. Mine was covered by insurance so I opted for the factory engine. This was not a defect in the engine, but water damage...long story.
    Surprisingly, I burn little to no oil since the replacement 18K miles ago.
    I have had some major service issues with Isuzu and probably wouldn't buy another if I could also. Actually the dealer that replaced the engine was great and if they were still in business I would consider it, however having to change dealers often, get crappy service, etc. has driven me away.
    Although I have had service issues, I love the trooper offroad and in the snow. It has awesome capabilities. It is just that when there is an issue with it, I either have to go to a local shop and pay out of pocket or go to a dealer and take 6 trips and a lot of hassle to get it fixed.
  • tkevinblanctkevinblanc Member Posts: 356
    Boy, I hope mine stays in the business. They're right across the street from work and, so far, seem very good. There are lots of Rodeos around here, so I expect them to have enough service work.
    Ugly, ugly, ugly.
  • breakorbreakor Member Posts: 398
    If I thought the manufacturer was at fault, let alone if I had just had to come up with $5000+, I would take a $50 check as an insult.
    In addition, I suppose Isuzu's lawyer would have told them any money they sent you could have been construed as some sort of admition of guilt leaving them liable for the whole repair.
    No doubt this is a lousy situation but you are far from the first person to have a catastrophic engine failure. You are certainly not the only one to have this happen at over TWICE the mileage warranty. While I feel sorry for your wallet, I don't think Isuzu is the total bad guy you are trying to make them out to be.
  • jrr2kjrr2k Member Posts: 35
    Sorry about the truck, noisuzu4me.
    I would guess that customer relations have suffered along with the other Isuzu departments. Similarly, I would not expect highly skilled mechanics to seek out Isuzu as a long term career stratagy. This is bad news for Isuzu owners. These are certainly symptoms of a struggling company.
    But I believe that their product remains an exceptional value compared to their competition. You "throw the dice" with all vehicles you purchase. I think the #1 concern of buyers is vehicle quality; customer service or vehicle service is only a prized offering when the vehicle has failed. If you buy a Jeep Liberty tomorrow, will you be satisfied with the company if their vehicle fails often, but their customer relations department shows you empathy?
    I think the longevity of Honda and Toyota cars have upped the bar so high we all expect near perfection from our low priced machines.
    A correction to a previous post...P.T. Warranty for a 2002 is a mind-blowing 10yr/120000m. Wow!
    For the record 2 of my 3 cars have +225000 miles and I would buy a used Trooper anyday.
    Only my opinions.
    After being a long-time die-hard Isuzu fan, cannot suggest that anyone buy a new one from here on out.
    Apparently my Isuzu dealer that had my truck had the switch turned off by Isuzu themselves on Monday, leaving the customer high-dry with our vehicles at the dealer for repair. I now have a diagnosis by a former Isuzu dealer and a frown from the GM of the dealership. After waiting a month for my appointment and spending $20 in tolls to get my Trooper in for repair, I now must start all over at another dealership for repair.
    So yeah, I'd endorse them as used vehicles, but don't count on any warranty.
    -mike
    Given their shrinking dealer network, wouldn't Isuzu bend over backwards to keep from losing one of their few remaining dealers? Similarly wouldn't a dealer have to really screw up something to get dropped by Isuzu?
    The fact that your dealer gave you no notice and kept you waiting for a month for an appointment leads me to believe that maybe Isuzu was justified in pulling the franchise.
    Or, are you saying that the dealer was just as surprised as you? If that is the case then no dealership is safe and indeed the death of Isuzu as a car company is in sight.
    I can understand you never buying another Isuzu product again. One very bad experience, like a $5,000 bill for a new engine, is enough to sour just about anybody on a vehicle brand.
    However, I'd hope that when talking about Isuzus with other prospective buyers, you tell them about other pieces of information - such as this website where all these Isuzu junkies talk about how much they love their Isuzus. At least until recently, with the additional evidence of Isuzu's impending doom as a retail brand here in the U.S.
    I'm glad our Trooper was out of warranty well before mass numbers of dealers started closing their doors. We had very few warranty issues, all minor, and so far at 97k miles our Trooper has been great.
    Personally, I wouldn't recommend buying a new Isuzu right now. But that does not dampen my enthusiasm for Troopers at all. These are great vehicles, and a used 1992-2002 Trooper is still an unbeatable used SUV value.
  • troop2shostroop2shos Member Posts: 235
    I don't know - kind of a toss-up to me. You can buy a product that is defective or suffers a catastrophic failure from a reputatable company that's still in business & can get no legitimate satisfaction / mfgr. support, or buy a product that fails from a reputable company that pulls-out or goes out of business...the result is the same. I won't go into the numerous cam sprocket mfg. defect & subsequent failures on Ford V8 SHO's & their total lack of support, but the cost generally exceeds $5k up to a reported $21k. I trust the Isuzu to have fewer repairs & mfg. issues than a domestic brand in general. I would have bought another Trooper again but I couldn't pass up a good deal on a new Forester XT (bought out of state since my local dealer's bid was insulting - they also sell Isuzu & Kia at this GM franchise). I did negotiate for one of their non-Isuzu extended warranties for the Troop. a few months ago - just in case. This dealer's service has been good, however. Time will tell.
    '00 Troop Ltd. w/ still time & mileage left on the powertrain.
    The dealership knew it was going to be loosing it's franchise, in January (mid January). Isuzu decided to pull the plug this particular monday. Reason for the 1 month wait is that they only had 1 Isuzu tech, but i've used this dealer before and their work was top notch.
    Apparently Isuzu dropped them because they haven't sold an Isuzu vehicle in 3 months and maybe 1 or 2 vehicles the months before that. Basically Isuzu is cutting off dealers that don't promote their brand/sell product, since an Isuzu dealership that only does warranty work are a major liability for Isuzu since it only costs them money and doesn't bring any in for them. So unless your dealer is selling isuzus hand over fist, then expect them to get ditched by Isuzu shortly and thus your repair channel.
    On the dealer side, they get no incentives to sell products (low commissions for sales folks, no factory to dealer incentives, lease programs, % financing etc) So basically they are both stonewalling, and the dealers will win in the end cause there are very few Isuzu stand alone dealers I know of.
    That's the scoop folks...
    -mike
  • jimmyp1jimmyp1 Member Posts: 640
    I assume your contact was at this dealer you speak of, Mike? A Chevy dealer here just went to $14k off MSRP no questions asked. Oh, and you can get the financing deals too. That puts a Z71 around $32-34k. Not bad, if the wife will go for it.
    I've been watching our dealer's lot and I think they've only sold 1 Ascender in the 4 months that I've been watching. Sad. I can't understand why Isuzu won't offer incentives on it when the Chevy/GMC versions have plenty of them. Isuzu seems to have some really strange marketing people.
    Jim
    edit: I think we are talking about after the holidays at the earliest now. Is that fair?
    Let's see. Isuzu badges a mediocre GM vehicle as it's flagship vehicle, overprices it compared to its siblings, but offers an big warranty.
    Isuzu starts closing shops that can't sell the Ascender (which is basically all of them, because it's overpriced), so there's no place to go for work under that big warranty if you were one of the unlucky folks that bought one.
    Unfortunately, my '98 Trooper with 45K is probably worth about $8K, half of what I paid for it two years ago. If my dealer goes belly-up, there won't be anywhere within 30 miles to get it fixed.
    Caveat emptor, I guess. But I couldn't have seen this incredible downward spiral myself two years ago.
    Dealers have been closing for at least 2 years now. I am on my 4th. 2 I spoke with had no advance warning of the closure. Isuzu just came in, took their inventory and parts, etc. The one shop that was awesome will still service my truck for out of pocket $$...which is worth it since the Isuzu dealer in the area really blows.
    Isuzu has been slowly going out of business since 2001. It is hard to believe they will actually close up shop, since most automakers go through several re-organizations and buy-outs...they just don't disappear. There has been some talk of Isuzu having a product in 2005? However I can't imagine it selling without much of a dealer network to support it.
  • raydahsraydahs Member Posts: 449
    "But I couldn't have seen this incredible downward spiral myself two years ago"
    How about this one, I've had extremely good luck with Nissan Trucks. So I waited a loooong time for the X-Terra to come out, when it finally came to market in 1999, Nissan was having financial problems with Renault coming to save the day. I was very skeptical about the possibility of a turn around, after all it's "Renault"...look at Nissan now! That guy is brilliant.
    Ironically GM Vice Chairman Bob Lutz suggested "Renault would be better off sinking a barge full of gold in the middle of the ocean". Looks like he used the same mentallity for Isuzu. http://www.thecarconnection.com/index.asp?article=6648
    I just have to laugh at the whole thing now, and chalk it up to one of life's lessons:)
    That's odd that your '98 is worth $8K, have you checked on the KBB lately? I checked my '00 and found it worth $5-7K MAX.
    -mike
    Nope the dealer where my sales guy is, is still open, just the customer service sux in the repair dept. But I don't see any good deals and wouldn't want you to get stuck with no dealers if Isuzu goes belly up on yah.
    After the holidays is fine with me, I have to bill my computer consulting clients to get the $ for you :) I however did figure out that I've done enough work to pay for the Legacy!!!! :)
    A burban for $34K is not bad at all. I bet I could get my duramax for around the same thing. Can't wait to finish paying off the trooper and give it to my dad! :)
    -mike
    nadaguides.org gives better price estimates.
    Isuzu heavily discounted their lineup before, with folks paying as low as 7.5k off MSRP so one should really take this into account when figuring its resale value.
    In my case, I have too many mods and too much mileage that it will be a keeper. Dealt with Isuzu on 2 warranty issues(leaking pinion seal/axle seal) without any problem even with the offroad mods. I did have same seal fail 60k later and also had the IMG replaced out of warranty/out of pocket.
    My only complaint really is the oil consumption which could have been exagerrated with my mods.
    Did Edmunds: $6,984/$8,544/$10,303. I find that KBB favors the dealers.
    "can't wait to finish paying off the trooper and give it to my dad!"
    Ouch.
    It's true though, I've been a diehard Isuzu fan, but they just can't pull it together :( The next best thing for me is to get an Isuzu engine in a 2500HD Diesel Sierra Crew-cab! :)
    -mike
    What is with all these new SUVs coming out with Hill Descent Control? I was reading on the Volvo board and someone was seriously wondering if it had this feature.
    I have to vent somewhere and here seems like the best place. Is someone taking their XC90 or BMW anywhere near a place that will need hill descent control?
    I have put the Isuzu in 4wd Low and gone down some steep slopes...not because I needed the ultralow gear, but just for fun to see how well it works. If one of these cars gets far enough from home that it needs that feature...how is it getting back?
    Ugh...Thanks.
  • atlgaxtatlgaxt Member Posts: 501
    Interestingly enough when it came time to turn in my leased Rodeo LSE 4wd, two cars that were on our short list were the Axiom and the Subaru Forester XT, which were sold at the same dealership. Although I was interested in the new direct injection engine and they had several on the lot, they tried hard to steer me away from the Axiom. I guess it makes sense now that I hear about the lack of incentives from Isuzu (I am smart enough to know that they were not looking out for me).
    When it came down to it, we went with the Subaru because although we wanted all wheel drive and good interior room, I already have a pick-up and we decided we did not need two trucks. So now after almost a decade of driving Isuzus I have left the fold, with some sense of sadness. I hope that they can pull out of this death spriral, but I am not optimistic.
    As a sidebar, I have moved away from leasing any more cars, but I guess it worked OK for my Rodeo. The residual at the end of the lease was about $4K higher than the car was worth.
    As another sidebar - don't a lot of these vehicles with hill descent control use this as a substitute for not having a low range? I know some with a low range also have this feature, but I am not sure what added benefit this would have, especially if you have ABS. If you are really into going offroad, you would be best off with no ABS, low range and a stick shift.
    Most use it to replace the LOW-range for going down hills. It also helps in ABS equipped vehicles as well. For me, on the Isuzus, the ABS won't kick in on <10mph movement so no issues have been had with ABS on hill decents.
    Also some like the 4-runner that have low-range use it because they don't have a hand-brake, only a foot-style parking brake.
    -mike
    It will take some original thinking for Isuzu to not go extinct in the USA.
    Here's a thought from outside the box: Its late 2005 with the new 2006 diesel 27 mpg Trooper and Isuzu changes the dealer paradigm by selling exclusively over the internet in the USA and allowing select non-dealer shops with Isuzu certified mechanics to process warrantee claims. Isuzu could build to suit that way (build your vehicle after they get your order and deliver it to you in a month) as many other industries are trying to do with their products.
    I looked up my 1995 in the condition it was in before being totaled and my current 2001 Trooper.
    1995 was $4200
    2001 was $13200 down $600 in six months, it will be down to zero in 11 more years at that rate, or going back up as a collectable by then, like International Scouts are.
    These KBB numbers agree with the same lookup on Edmunds within a couple hundred dollars.
    If I could have found a 5 speed 1995 when replacing my 1995 I would have done that for the terrific value. But the 2001 is more powerful and a bit quieter. I miss my OME shocks and springs that I had on the 1995, I'll fix that next year along with 265/75 tires to make those big wheel well flares not look like so much overkill.
    Interesting idea. As part of this they would have to have some limited network of showrooms so that someone could go and look and test the vehicles as I for one would not buy a car only through the Internet without having a chance to touch it first.
    I can't understand why Isuzu sells a rebadged product from GM while at the same time they say they have no plans to bring in their new pick-up, which was essentially developed by Isuzu but is only being sold here through Chevy and GMC. If Isuzu is going to survive as a niche player they have to sell their own products (including capitalizing on their expertise with diesels) and selling their new pick-up with an Isuzu diesel or Isuzu gas direct injection engine would be an immediate boost to sales. On the flip side, I think selling the Ascender (or any other rebadged product they may plan to sell in the U.S.) only weakens what remaining value the Isuzu brand has.
    as out of the box as you think or as legal either. http://www.edmunds.com/news/feature/general/45856/article.html
    To read this Board you would sometimes think our resale values are ridiculous low. However, I think Pinoy99 put it in very good perspective when he stated - "Isuzu heavily discounted their lineup before, with folks paying as low as 7.5k off MSRP so one should really take this into account when figuring its resale value".
    That kind of ties in with something I just checked. Namely my 99 is now worth about $7k dollars less than a 99 4runner. IIRC $7k is about what I saved when I bought my Trooper rather than my second choice which was a 4runner. Thus, I am really no worse off resale wise for having bought the Trooper. Plus, the longer I keep the Trooper the more this difference in resale value will decrease. Also I probably save a few bucks in cheaper insurace premiums each year since the Trooper is worth less and stolen less.
    Thus, while Isuzu troubles are not a good thing, they have not really been an issue for me (Note: I of course realize that some of you have outstanding warranty issues, and I wish you luck). Then again, if they really fold up and repair parts disappear, that could change.
    Great article! (I either missed it when it came out or just forgot about it).
    IIRC Mazda in Japan does this. You order on a website or on a web-style site @ a walking showroom, and then your car is delivered a month or 2 later to you directly.
    -mike
  • bsmart1bsmart1 Member Posts: 377
    is still there if you plan to drive it for 5-7 years and have a dealer you still have confidence in. Otherwise find a local independent repair shop that can maintain it for you, and your in good shape. BUT if you planned to resell your Trooper in about 4 years after you bought it, too bad... Most on this board talk of their Troopers as long term commitments, and should have nothing to worry about. Drive it 200k miles and you will have had a bargin! Hey, last time I looked they are still well built vehicles, rugged, solid, and comfortable on the road.
    As much as you'd like to think that, the parts prices on replacement parts is CRAZY, and some stuff is just not feasible to be fixed by a local mechanic :( For the most part your truck should be ok, but god-forbid something major, you are gonna be stuck with a high repair bill IMHO.
    -mike
