Visitor Agreement.
Wish I could tell you why it reverted back to high after replacing the resistors, but I don't really know. Is your voltage regulator working properly?
-mike
Overall would you folks still recommend a 2000 3.5 trooper? Or is it better to save my coin for a Toyota?
Cons: There is a very real chance you could burn oil and with no warning (at least if you don't check your oil level) lose an engine. You may get no dealer support and finding a new engine could become impossible. Rebuilts and used ones may or may not be available. In fact getting parts for any major rebuild could be difficult and/or pricey.
So with apologies to Dirty Harry "Do you feel lucky punk, well do you?". In otherwords do you want to pay for the certainty of a Toyota or save a bunch of money and get a capable Trooper that likley won't break but if it does it may impractical to fix?
This is actually a question I am wrestling with, as my Trooper was wrecked on Christmas Eve by a guy who didn't see the red light, or the cars turning in front of him.
Everybody is OK, Trooper is not.
let us know how the damage estimate comes out.
What did the front end of the Explorer look like? It doesn't appear that you got moved much on impact.
-mike
As far as not getting moved, my Trooper actually spun 270 degrees on impact...he hit me pretty hard.
I hope to make it to Moab again this year, whatever vehicle I end up with, so there may be an opportunity for somebody to transport from there.
What is the damage estimate? My 2001 Trooper was in a mild accident last year with a Honda Accord at 10mph - $3000k damage. Front bumper, front quarter panel, and new front wheel.
Unfortunately, won't be much to total one these things with the dropping blue book values.
Just went to a car show yesterday in DC, still nothing out there I like better than my Trooper.
-Kevin
This is not the normal mini-clunk that some experience in normal driving. This was so hard, it made the truck shudder a little bit.
Now of course, it is gone and getting it to repeat for the dealer would be impossible. The Check Engine light did not come on either so no code to check.
Any help would be appreciated. Our 99 has 50k with no issues until now. Just regular oil/fluid changes and tires until now... thoughts?
Tetonman
PS> SDC very sorry to hear about your accident. Glad everyone was okay. Paisan's site had a good gallery of wrecked Troopers at one point. Just shows you how great these trucks are in the worst possible situation...
That being said when was the last time you checked your ATF level and condition or for that matter changed the fluid? This is an often overlooked item, especially with the no dipstick design.
http://www.sylvania.com/auto/silverstar.htm
http://www.sylvania.com/bin/carApp/carApp_ver2.pl?flag=model_qual- - - s&make=&make=Isuzu&year=&year=2001&model=Troo- - - per&x=44&y=11
Here's another very good description of the problem jtk152 "Isuzu Rodeo" Oct 23, 2003 8:29pm
Tetonman
Tom
Tony (Wildbuc)
About the butterfly nut, it is in an awkward position and difficult to turn. I have not removed it yet, only turned it to loosen and then to re-tighten it. It seems to be a threaded plug---made of plastic. Be careful not to break it.
I suggest you spend some time at tirerack.com learning about sizing to start before you start selecting rim sizes.
If you don't want to mess with this plug you might consider doing more drain/refill with purified water/run the engine/drain cycles using just the radiator plug drain. Or, you could install a power flush connection.
Like noted I run the engine with each drain and fill cycle. Therefore I get all the old coolant circulated.
I am guessing that at most I am leaving in 1/3rd of the old solution with each drain/fill/run cycle. So if you do the math 3 cycles would mean that 1/27th of the old fluid remains in. This seems good enough to me especially since I do this every 18 months or so.
As to adding antifreeze back in, I first look up the capacity of the system in the owners manual (IIRC it is 9qts). I then calculate how much pure antifreeze I need in total assuming I have none left in the system. I add that much back in and top off with purified water. To the accuracy of the $5 antifreeze tester I bought at Walmart this works.
Just my hopefully helpful $.02.
In summer only A|C sounded and the frequency of the noise depended on the acceleration. My well-known mechanic said that I had to replace the A|C pulley. But the summer is short in my area and I left it so.
Glad you're OK.
http://biz.yahoo.com/rf/040106/autos_isuzu_table_1.html
This is one sad situation and I guess I won't be getting my new Axiom for more than thirty grand (!!!) anytime soon...
