Visitor Agreement.
OME shocks advertise longer extension range and stronger components for more suspension travel and durability especially for off roading.
*** I replaced perfectly good ~10K miles aftermarket Tokico shocks, but not the latest Tokico Trek Master which was not available back then, my goal was a matched set of shocks and springs from OME, I wish OME also provided matched torsion bars. I like the description of the TrekMasters, but would go back to OME after having excellent results once before.
Paison, please post on how well the OME shocks work with your sway away torsion bars. Thank You, BoxTrooper.
Also, I have Rancho 5000 shocks on our 01 TOD LS. So far they seem fine (45K) - also Mike - did you contact Rancho direct to see if they would replace your shocks? - They should if they knew your influence on our vast purchasing power.
Cheers,
Sean
I find the driver seat in my trooper quite comfortbable despite the lack of lumbar support. In fact, the further I drive it, the more comfortable it is. It ain't a Volvo seat (some of those seats go past comfortable and border on, well, I'm not sure what).
Cheers,
Sean
Another Power survey last year found that just 3.5% of Isuzu owners said they'd buy another Isuzu. That was worst of the 37 brands."
http://www.usatoday.com/money/autos/2004-04-20-isuzu_x.htm
Back in the late 80's, early 90's I used to rebuild MX shocks. One thing to keep in mind, motorcycles have spring preload adjustments, compression dampening & rebound adjustments which can be fine tuned with the shim stack inside (dia & thickness). It's very difficult to get "the perfect ride" in a car without external adjustments.
The dirt road you travel daily, is it washboard type rough or Supercross whooped out rough? If it's Supercross style (High speed G-outs) then go for the stiffer OME's. Otherwise I would call Buddy King at ARB, and ask if the difference between the softer ones vs. the stiffer ones, is the compression shim stack. I have the stiff ones now, If I had it to do over again, I would go soft. The rebound is perfect, the compression is too stiff (for me). Check out the video on Mikes site, that is some high speed compression! http://www.isuzu-suvs.com/ see Airborn Trooper:]
1999 Trooper S with Luxury Package
2. What is your engine/transmission/4WD combination?
3.5L V6, 4-speed auto Torque on Demand 4wd.
3. How many miles are on it?
54,000
4. Does it burn oil, and if so, how much?
I get oil changed every 3-4K, low oil light never went on. I did not take measurements of oil level in between.
5. Have you had any problems with the vehicle (excluding routine wear and tear, etc.)?
Faulty bearing in heater fan, shimmying mirror - replaced under warranty
CD changer broke down after 3.5 years
Serpentine belt had a lot of cracks and was replaced at 30K
Replaced battery after 3.5 years
Replaced tires at 45K
6. Can you estimate the total cost of repairs to the vehicle since you've owned it?
Typical for Trooper maintenance costs, no real repairs
Modifications and additions:
- Poly sway bar bushings (a must-have: huge improvement in cornering and overall stability)
- Edelbrock IAS shocks (like them even after 45K)
- Michelin Cross Country tires (a must-have: made a world of difference for handling and ride compared to stock Goodyears)
- K&N Air filter (I don't think it makes a crucial difference)
- Nakamichi MB 75 CD changer (highly recommended, see my review at epinions.com)
We all know Isuzu is in a weak position and this article (which is a little innacurate) probably just made that situation worse.
Sean
I will report on the fronts with the sway-aways, currently I have a weird noise when I hit bumps in the front, so hoping a re-index of the torsion bars along with the new shocks fixes that issue.
-mike
http://www.edmunds.com/townhall/chat/townhallchat.html
6-7pm PT/9-10pm ET. Drop by for live chat with other members. Hope you can join us!
kirstie_h
MODERATOR /ADMINISTRATOR
Review your vehicle
98-99 Acura SLX = 98-99 Trooper LTD ,even in smallest details except badges and a cover of airbag on the steering wheel.
I saw here several Troopers LS imported from the US. All they had the panel.
Cheers,
Sean
But, I tried the same instructions on another one that didn't work.
I need to check this to verify what I'm telling you.
Potato, spud, tater, I guess.
-mike
You missed the point. The Staten Island that was mentioned is a municipality and it wasn't in relation to the island per se. Therefore it is correct to say "live in."
Now back to our regularly scheduled program!
Poly sway bar bushings: Who makes these and where would I find them?
I suspect the SLX I'm looking at needs an exhaust header gasket (erratic idle - near stalling once in awhile). For those of you who've had it done -how much did it cost (parts and labor)?
Sean
Much appreciated..
Brad
-mike
PS: Cost was like $20 from Whitney
I really like my OME shocks. They improved cornering and nose dive (especially after I added my bullbar). They also improved the jarring effect of potholes.
Best feature for me...ability to hold up under extended pounding. When I go fishing in Nantucket, there are several sections where you pound over sand dunes for almost 1/2 hour or more. My truck before and my brothers expedition start to fade and really bounce and not respond well after about 15 minutes. The OMEs never felt like they overheated or lost shocking ability. Once I upgraded everyone in my family wanted to ride with me over the long haul out to the coatue.
sbcooke, care to finish? :0)
-mike
OME Shocks: Do these seem to be the current favorites? My daily drive includes about six miles of dirt road which varies from reasonably smooth to muddy gunk to washboard. I'd also prefer a less "tippy" feel than stock on pavement (in corners). VT doesn't have many straight roads (thankfully!).
wildbuc: I own a motorcycle touring company and chase drivers who work for the company have towed many of our trailers with many different tow vehicles (including a 1999 Trooper). What I ask them to do is to pay close attention to how the engine is being loaded under different conditions (including a lot of mountain road driving). If the tow vehicle isn't laboring, seems to have power in reserve, isn't hunting back and forth between 3rd and 4th, etc. then being in "Drive" is fine (that's our SOP at least). This normally applies on fairly flat terrain where the vehicle is at a steady speed. At the slightest sign of engine lugging, gear hunting, etc. then we go down into third and sometimes even second (in the mountains).
I think this depends greatly on the vehicle and one has to go by sound, feel and experience. The strongest tow vehicle I've owned so far was a 1999 Suburban but the Trooper pulled 3000lbs. just fine. The Suburban (which had a 4.11 rear end) could tow pretty easily in 4th. My one-ton conversion van, however, needs 3rd quite often.
Vehicles with a really good transmission cooler obviously have a bit more flexibility. Given the amount of towing we do (usually on paved backroads) I always prefer to use a vehicle rated for a couple thousand pounds more than the actual tow weight. Two full dress bikes in/on a trailer will give a total tow weight of about 2700 - 3500 lbs. so the Trooper's 5000 lb. tow rating works fine for that load.
I'm also a big fan of using electric brakes on any trailer where the loaded weight is over about 1500 lbs. (ie: In my case, any time I'm towing more than one large bike).
Cheers,
Sean
-mike
I haven't yet installed a transmission cooler although I'm still considering it. My local Isuzu service manager said a cooler is not needed for a 2800-3000 lb trailer, but others have told me different. I would buy one and put it on myself if I thought I could top off the tranmission fluid correctly. I understand you have to be underneath the vehicle with the engine running--not a place for a novice. A private Trooper shop in Raleigh is wanting $175. for a cooler installation (parts and labor), which seems high to me.
Make : ISUZU Model : TROOPER Year : 1993
NHTSA CAMPAIGN ID Number : 04V199000 Recall Date : APR 19, 2004
Component: VEHICLE SPEED CONTROL:CABLES
Potential Number Of Units Affected : 72905
Summary:
ON CERTAIN SPORT UTILITY VEHICLES, THE ACCELERATOR CABLE CAN STICK SO THAT THE ENGINE SPEED WILL NOT IMMEDIATELY DECREASE UPON RELEASE OF THE ACCELERATOR PEDAL.
Consequence:
THIS CAN CAUSE THE ACCELERATOR THROTTLE CABLE TO DELAY RPM AND VEHICLE SPEED REDUCTION FOR SEVERAL SECONDS AFTER THE ACCELERATOR PEDAL IS RELEASED, WHICH IN TURN, CAN LEAD TO A CRASH.
Remedy:
DEALERS WILL REPLACE THE THROTTLE CABLE RUBBER BOOT. OWNER NOTIFICATION IS EXPECTED TO BEGIN DURING MAY 2004. OWNERS SHOULD CONTACT ISUZU AT 1-800-255-6727.
Notes:
CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Dan
92 LS
PS. Carfax can only verify up to 4.9K miles, so that's the chance that I have to take.
A Suburban has roughly 50% more torque than a Trooper, and at a lower rpm too. That will make a world of difference when towing.
Anyone on this list have over 200K on a Trooper? If so, how's it held up?
Cheers,
Sean
More future Isuzu news fanning the rumor flames.
Here's some snipets from
http://www.isuzuperformance.com/isupage/
"2003, Sources within American Isuzu Motors vehicle distribution (US market vehicle distributor) indicate that Isuzu intends to severe all ties with GM by 2007 (this can be confirmed on Isuzu's website in their Three Year Business Plan which states one of its primary recapitalization goal as "Retire GM's shareholding without consideration"), ending all joint ventures, rebadging, parts sharing, and cooperative efforts and purchasing back all of the remaining 12% of stock owned by GM. The Rodeo and Axiom (now made by Subaru at the Lafayette, Indiana plant) will be discontinued at or shortly after the end of the 2004 model year. There will be no serious effort to market the GM made Ascender through the 2005 and 2006 model years, after which Isuzu's contract to sell that vehicle will end. Isuzu plans to introduce at least two completely new models in late 2006, totally designed and manufactured by Isuzu and with no ties to GM."
"February 2004, Sources within American Isuzu Motors public relations and vehicle development departments indicate that the replacement for the Isuzu Trooper will be built on the Isuzu D-Max/Colorado platform in Thailand and that model should be introduced as a 2005 1/2 model year vehicle. Work continues on this vehicle within the Ceritos headquarters of AIM where the vehicle is referred to in house simply as "the new Trooper". Current plans are that the concept car for this vehicle will be introduced at the Detroit Auto Show and later displayed at the Chicago Auto Show. Further plans are to introduce the Thailand made D-Max pickup into the US market, also hopefully in 2006.
Isuzu's PR department was very proud to point out that the 250 HP 6VE1 V6 direct injection engine has received accolades and awards from both Popular Science Magazine and Ward's Automotive. Direct injection is seen as the future for gasoline engines to improve economy, emissions, and power output, and Isuzu's engine has been held out as one of the best in the industry. In addition to this, Isuzu plans to push diesel engine powered models in their SUV lineup as an alternative to other manufacturer's hybrid vehicle offerings. Diesel offers the same environmental benefits with power, drivability, range, and cost that is comparable or favorable to gasoline. The problem is that the US market has not been exposed to many of the better diesel powered vehicles which are almost indistinguishable from their gasoline powered equivalents. The US market has seen mostly very tempermental and difficult to drive, and the reputation of diesel powerplants has suffered in this market as a result of this. General Motors, Ford, and Daimler/Chysler have already expanded their SUV and pickup offerings with diesel offerings (to help them meet tightening CAFE standards) and have begun marketing campaigns to improve the reputation of diesel power in the US, and Isuzu plans to reap the benefits of these efforts by following the promotional campaigns of the US manufacturers with their own campaign to reinforce diesel's improved reputation and point out that Isuzu is the oldest, most experiences diesel manufacturer in the world, offering better quality and higher performing diesel products at lower prices than the US makers.
2005 is seen as the transition year between the old GM dominated Isuzu and the new Isuzu that is free to build, sell, and advertise whatever, wherever, whenever, and in whatever quantity they like. Getting past a tight year which their only offerings will be the rebadged, GM made Ascender, will be the challenge, but they are already on track to surpass their needed sales minimum in the US market by 20,000 units in this fiscal year. The only remaining concern is that now that all decisions will be made by Isuzu in Japan, the US office hopes to be allotted a large enough advertising budget to allow for a serious promotional effort for what amounts to a reintroduction of the marque in the US market."
Bring it on!
BTW - Our 2002 just flipped 30k touble-free miles.
Why haven't JD Power Initial Quality survey people contacted me yet?
Only a week until I'll be taking it to Moab as an "Honorary Isuzu" for ZuZoo VII (May 12-15). This will be my 4th year there.
Hopefully the Tahoe is not too big to wheel...not too many trees out there, so I think I'll be fine.
What ever happened with your bumpers on your truck? Or any other parts for that matter?
-mike
