Visitor Agreement.
Jeannine Fallon
PR Director
Edmunds.com
MODERATOR /ADMINISTRATOR
Review your vehicle
Well the Sequoia pulled nearly double the weight in only 4 seconds more. They also rated the Pilot higher in emergency handling, yet the Sequoia had a higher max avoidance maneuver speed. Do I detect a bias with CR?
If it's any comfort to you, the olfactory nerves are extremely sensitive to certain molecules such as sulfur dioxide. You can detect as few as a dozen or so molecules!
Also, any gases in the air outside your vehicle can make it inside. No filtration system can remove individual molecules. Your ventillation intakes are well in front of the exhaust system so that, ordinarily, none of the exhaust can be carried into your vehicle. Occasionally, some will make it in particulalry when you are stopped and a backbreeze transports exhaust gases forward into the vent intake.
I don't see a health or safety hazard.
tidester
SUVs; Aftermarket & Accessories
As for the smell- take it to the dealer and have them check it out for you.
Winning is another story :-)
Did we mention that the Sequoia has a high residual value?
Steve
These days the going rate is in the BILLIONS!
BTW - that reminds me, I should have put in the usual disclaimers along with a recommendation to keep an early warning parrot on board! :-)
tidester
I finally put in my order yesterday to buy an '03 Sequoia. We struck a deal at 700 ove rinvoice for an SR-5 with a few extra options (we're getting, keyless entry, steel wheels, JBL premium sound, dual A/C, tinted glass, luggage rack, power seats, fog lights, daytime running lights). Our price is $32,700 + taxes and lic. Any comments of we got a good price? I would really like to hear from current Sequoia owners.
Arshad
Mileage: 27,000
A few months ago, I started noticing that the oil pressure gauge would drop to zero and below during idle. The dealer checked sending unit, gauge and did a manual pressure check - all checked with in normal specifications. Problem, however, continued. Eventually, both sending unit and gauge were replaced and problem went away. About two weeks ago, same problem returned with one change. Now at idle, accerleration, and highway speed, needle will fall below zero and even fall to the rest postion (as if the ignition switch was off) and stay there for long periods of time - occasionally rising to normal values and then droping to the rest position. This message is not meant to reflect negatively on the dealership - they have been very helpful with this problem. My concerns are: 1)If a problem does indeed exist with in the engine and it can not be solved, I may be at risk for long term damage and significant out-of-pocket expense and 2) when it comes to resale or trade-in time, how will I explain an oil pressure gauge reading of zero at highway speed - even though the dealer says that the truck is fine and there is nothing more to do. I know I would not buy it! I would like some sound advice on how I can protect my truck and my investment.
Willis Scott Mozingo
P.S. Yes, the engine has oil!
Steve
http://www.tundrasolutions.com/photopost/showgallery.php?cat=500&ppuser=5564&thumb=1
Price was $71 plus shipping from Carson Toyota in CA.
You folks sure have a lot of problems with your Sequoias....... I like the odor in OD the best though.....
I, for one, am impressed! Remind Steve to send you "the certificate!" :-)
tidester
Does ANYBODY know what kind of 4WD system is in the Navigator?
Could it be because people are asking their Navigator questions HERE instead of there? ;-)
tidester
I blew my engine when the oil pump blewup in my old chevy. That sucker ran for about 1 mile before it just seized. If you are the highway pulling 3k RPM, it won't take long before that engine dies without oil...
Keep on the dealer..
did you happen to compare your Sequoia with anything else prior to purchase, say, Land Cruiser or Lexus LX470??
Any thoughts?
You may very well be correct about the owners!
We contacted Toyota's regional office about the problem, and can't get a response.
Has anyone experienced the same problem? It might help if we can show that others (beyond the four posters on tundrasolutions). Thanks
