Visitor Agreement.
4WD = Same
2WD = Sequoia
Refinement = LC
Build quality = LC
Resale = LC
Hope the above helps...
Just an FYI.
Ken
Hope these helps
I found the Sequoia to be very capable climbing the pass from the Alma side. On this side of the pass, I used 4L gearing with the center differential locked, and kept the shifter in D gear. The vehicle performed well, and had abundant torque at altitude. It spent most of its time in 2nd gear.
There was another Sequoia at the top of the pass that was almost identical to mine, except it still had original tires.
On the descent, I used 4L in 1st gear. The engine provided ample braking such that I almost never had to use the brakes. I experimented and found that shifting into 2nd also meant riding the brakes.
The Sequoia never bumped skid plates or the trailer receiver along the way. I concluded that the Sequoia could probably handle more difficult terrain, especially with better tires. A word of caution: don’t try to cross this pass during wet conditions or snow. The steepness of the climb would cause all sorts of trouble.
If you read the Owner’s Manual, the procedures for using the Sequoia in 4WD are very confusing. The authors missed the point if they intended the document to convince owners that the Sequoia was designed for rugged four-wheeling. I found the postings on this message board to be more useful than the Owner’s Manual when it came explaining how to operate the Sequoia in 4WD. Don’t get discouraged by all the combinations of levers and buttons. In practice, it is quite simple.
SR5 4WD 4.7L 8cyl........2006...............................2005...............change
Horsepower.....273 hp @ 5400 rpm..........282 hp @ 5400 rpm........-3.2 %
Torque............314 ft-lbs. @ 3400 rpm......325 ft-lbs. @ 3400 rpm...-3.4 %
EPA Mileage
City................15 mpg............................15 mpg........................ 0.0 %
Highway..........17 mpg............................18 mpg........................-5.6 %
True, "your mileage may vary." But they can measure engine output better than 3%. Anybody know what the deal is?
techstaff
techstaff
major safety related issue. on the other hand, we have a '90 forerunner and a 97 corolla and still have original door handles.
anybody else have this problem?
Question
The interior driver side door handle broke on my 2002 toyota Sequoia. I purchased a replacement handle. I've removed the small cover exposing the philips head screw in the center of the door handle bezel and removed the screw. The bezel will not come off to expose the door handle. What is the process to replace the door handle(part 69206-0C030-E0)?
Court
Answer
Slide it towards the rear, it should then come out, remove the plastic clip that connects to the control rod.
Unless you plan to race your Sequioa, you will not see any real gains from aftermarket air filters or intakes. The aftermarket intakes will increase performance in the upper RPM range, but will rob you of low-end torque big time.
I have a 2002 Sequoia and at 37,000 miles the drivers side door handle cracked and then broke off. Now at 40,000 miles the passanger side door handle is cracked and will break off the next time some tries to use the door. This is frustrating for me as a Real Estate Agent. I have people in and out of the car often. I hate to have to tell them wait a second dont open that door! They then ask about the problem and I explain I have not had the time to go in and pay $110.00 for the repair. My first vehicle was a Toyota and have owned them ever since. This one issue has troubled me for many reasons including safety. :confuse:
Has anyone else had this problem? My local service manger is going to look into the issue. I will update this post with that information as soon as I get it.
Robert Bolar
I have a 2002 Sequoia and at 37,000 miles the drivers side door handle cracked and then broke off. Now at 40,000 miles the passenger side door handle is cracked and will break off the next time some tries to use the door. This is frustrating for me as a Real Estate Agent. I have people in and out of the car often. I hate to have to tell them wait a second don't open that door! They then ask about the problem and I explain I have not had the time to go in and pay $110.00 for the repair. My first vehicle was a Toyota and have owned them ever since. This one issue has troubled me for many reasons including safety.
I have an 02 Sequoia SR5 and want a Service Manual for it on CD too. Please get in touch with me. Thank you.
The only brake work was new front calipers, etc as per the TSB @ 17K (never changed a pad, other than the TSB). I'm on my third front windshield (from rock chips off highway), I have rattled off the skid plate covering the front transfer case (warranty repair), rattled the front driverside window out of its carriage (warranty repair), and my kids pulled all the little plastic covers from the seat/seatbelt attachment points (there in a drawer somewhere).
It been a great car... only wish it didn't eat so much gas... only 11-12mpg in town during the winter, but18-21(!)mpg when out on the road.
My father in law wants to get a large loaded 4x4 Toyota SUV to replace the his 03 Expedition that he has been extremely unhappy with (always in the shop) and was interested in the Seq. The invoice price with all the options and stuff he was looking at was around 44k, so I told him he might as well look at the Toyota Land Cruiser too since it comes almost completely loaded for 48k (again, invoice).
Problem is that I've heard the LC is going to be replaced next year with that hideous "FJ Cruiser" thing which he (nor, IMO, anyone else who would have considered buying an LC in the past) would never consider that FJ Cruiser. And I'm thinking the Seq is only a year or two away from being redesigned from the ground up, so I'm trying to figure out if I should advise him to lay low and wait for the redesign?
The LC is smaller than the Seq, but more refined. It is also only a permanent 4x4, but the Seq 4x4 can be driven in RWD mode as well. Of course, the Seq has slightly more power than the LC, seats more people comfortably, and cheaper than the LC.
If your father-in-law can indeed hold on for another couple of years, then he can wait for the MY2008 redo for the Seq. But methinks, its best to just go ahead and buy whatever he wants now, unless the pain of constant repairs on the Expy is manageable.
Good luck
ps: nice to read from other old timers here as well on their '01 history ....
Of the two, the Toyota will be the more reliable. Here is my list of problems with the Ford - Abysmal gas mileage (even for a vehicle this size), chattering plastic parts in the lift gate (fixed this myself), rear axle seals went out at 7000, tires (probably because they were so cheap) made the steering wheel shudder at highway speeds for the first several hundred miles.
This guy has been loyal all his life to domestic trucks. Heck, he owns one of the largest residential contracting/construction in the areas - an industry that you see almost nothing but domestic trucks and SUVs, but he's ready to jump ship.
His 04 Tahoe 4x4 LT has been much better - only a couple things have gone wrong with it, but one of those things was a sudden and complete failure of the brake booster on the highway going 70mph. Thank god it happened when he just wanted to slow down a bit and not when there was a traffic jam ahead or something or he very well might not be alive today! The brake pedal just went straight down to the floor where he still got a tiny bit of stopping power, but he was on the brake pedal all the way and from what he told me it barely stopped any faster than if he'd just let off the gas and coasted.
My wife's 2005 4Runner Limited 4x2 V6 and her identical twin sister's identical (except for the paint color) 4Runner have been completely problem free. We've been averaging an impressive 22.5 mpg with about 60% city, 40% highway, too. Granted the two 4Runners are only a year old each and only have around 12k miles each right now, but I guess that's enough to get her dad to give them a shot.
So I guess we'll see how his experience goes with a Seq or LC.
The question you need to ask yourself is - how much is it worth in the long run for comfort? Your family will likely fit in either vehcile, but if you can afford either - then the choice is yours.
The gas mileage will be significantly better in a Pilot as it is lighter and has a V6, especially around town.
I have had 2 Sequoias and they are gas guzzlers. But it sounds like in your case you need some serious space and the Pilot is small and the 3rd row seat is a bit of a joke. It is all about trade-offs and what works best for you.
I just purchased a 2005 Limited expedition. The Sequoia was much more money for all of the features I wanted, the Expedition has a new and very powerful new engine and is a newer design but the killer feature for me were the power folding 3rd row seats after wrestling with pulling out my Sequoia seats on a regular basis.
Even the second row seats fold truly flat.
They have different personalities. The expedition is probably not quite as plush and solid feeling but handles better and is better on the highway. The turning radius is much better in the expedition- something I found frustrating in the Sequoia. It also seems a bit more high-tech with more features than the Sequoia.
At the end of the day though I guess it came down to the fact that there was a huge difference between the expy limited and seq limited.
A lot of the issues with the expy have been solved through tsb's as its now in its 3rd model year and the tsb list is just as long for the seq as it is for the expy.
Was just wondering, have you thought of using the product call Freedom Fuel Additive?.
The product is guaranty to give you between 8-12% mpg, at the same time keep your engine inside very clean.
IF you like to read more about the product visit the company web site to read more testimony about it. And if you will like to give it a test, please let me know.
http://www.polarmolecular.com/testing. html
It doesn't say that at all.
Their web site says Up to 8-12% increase in fuel economy.
That can mean zero, or even negative benefit.
There's a slew of this stuff in Gas Saving Gizmos & Gadgets.
I just bought a 05 limited Sequoia and had 2 questions. The dealer installed the Eclipse AVN30d nav which is great since they set it up so it can play a movie at anytime but I can't get the rearseat dvd player to play sound through the speakers. I've gone through all the local FM channels and still haven't found the sound. 2nd question is, can they have the sound directly patched through the Eclipse Nav so the sound would be better then FM anyway?? The wireless headphones do get sound from the dvd player. Help would be much appreciated--thanks
However, I can feel that the battery is just about to go. Does anyone have any suggestion about a particular brand? Are the replacement "Toyota batteries" really as good as the original ones? Are they better than the ones we get from Walmart or Sears?
Thank you for any advice.
Yes, those were the original tires that I had, but I cannot remember if they were Dunlop or Bridgestone. I honestly could not tell any major difference when they were both new, because they both feel good. New tires are always softer and cures (hardens) and loses thread over time. So the new tires felt better compared to the original ones, when they were already significantly worn out. HOWEVER, the reason I picked Michelin CT is because that seemed to be the overwhelming choice in this forum, even compared to Michelin LTX.
Toys
